Import STL binary files
Jerry Davis
Sun, Jun 7, 2015 1:51 AM
I downloaded something from Thingiverse, and wanted to import it into
OpenSCAD, and it won't import.
I looked at the documentation, and I couldn't find anything saying that
importing binary STL files wasn't possible.
Would this be a bug, or it just doesn't work?
Jerry
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
- Isaac. Asimov
I
Anonymous
- Ken Thompson
I downloaded something from Thingiverse, and wanted to import it into OpenSCAD, and it won't import. I looked at the documentation, and I couldn't find anything saying that importing binary STL files wasn't possible. Would this be a bug, or it just doesn't work? Jerry -- Extra Ham Operator: K7AZJ Registered Linux User: 275424 Raspberry Pi and Arduino developer *The most exciting phrase to hear in science - the one that heralds new discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov *I* *f you give someone a program, you will frustrate them for a day; if you teach them how to program, you will frustrate them for a lifetime. *- Anonymous *If writing good code requires very little comments, then writing really excellent code requires no comments at all!*- Ken Thompson
Sun, Jun 7, 2015 12:18 PM
How? What happens? How did you import exactly? What OpenSCAD version
is it?
Is there a difference when using F5 vs. F6?
( https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#Why_is_my_imported_STL_file_only_showing_up_with_F5_but_not_F6.3F )
The import handles both binary and ascii STL's.
Without further information, I'd say the file is broken. There's a
small chance it might be a bug, but to check that, the actual file
is needed.
On 06/07/2015 03:51 AM, Jerry Davis wrote: > I downloaded something from Thingiverse, and wanted to import it > into OpenSCAD, and it won't import. > How? What happens? How did you import exactly? What OpenSCAD version is it? Is there a difference when using F5 vs. F6? ( https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#Why_is_my_imported_STL_file_only_showing_up_with_F5_but_not_F6.3F ) > I looked at the documentation, and I couldn't find anything saying > that importing binary STL files wasn't possible. > The import handles both binary and ascii STL's. > Would this be a bug, or it just doesn't work? > Without further information, I'd say the file is broken. There's a small chance it might be a bug, but to check that, the actual file is needed. ciao, Torsten.
I
Ivo
Sun, Jun 7, 2015 12:52 PM
That isn't actually in the manual. How can we fix the manual ? Is it in
github ?
Cheers, Ivo
View this message in context: http://forum.openscad.org/Import-STL-binary-files-tp12813p12821.html
tp3 wrote > The import handles both binary and ascii STL's. That isn't actually in the manual. How can we fix the manual ? Is it in github ? Cheers, Ivo -- View this message in context: http://forum.openscad.org/Import-STL-binary-files-tp12813p12821.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sun, Jun 7, 2015 3:14 PM
github ?
It's on wikibooks: https://en.wikibooks.org/wiki/OpenSCAD_User_Manual
Actually from user perspective I don't see much need to explain this,
OpenSCAD is supposed to import STL files. How those are generated or
internally structured should not matter and users should not need to
care.
I guess the error handling could be improved a lot, especially the
fact that most import errors are only shown once and then "cached" is
not very user friendly. I think there's already an issue on github
for that...
But if you have a good idea how to explain the details, it's easy to
add to the wiki based manual.
On 06/07/2015 02:52 PM, Ivo wrote: > tp3 wrote >> The import handles both binary and ascii STL's. > > That isn't actually in the manual. How can we fix the manual ? Is it in > github ? > It's on wikibooks: https://en.wikibooks.org/wiki/OpenSCAD_User_Manual Actually from user perspective I don't see much need to explain this, OpenSCAD is supposed to import STL files. How those are generated or internally structured should not matter and users should not need to care. I guess the error handling could be improved a lot, especially the fact that most import errors are only shown once and then "cached" is not very user friendly. I think there's already an issue on github for that... But if you have a good idea how to explain the details, it's easy to add to the wiki based manual. ciao, Torsten.
Sun, Jun 7, 2015 10:50 PM
Wiki updated.
View this message in context: http://forum.openscad.org/Import-STL-binary-files-tp12813p12839.html
Wiki updated. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Import-STL-binary-files-tp12813p12839.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Jerry Davis
Mon, Jun 8, 2015 12:46 AM
I am running version: version 2015.04.21 (git 167b882)
on osx yosemite (10.10.3)
I downloaded the STL files from this:
http://www.thingiverse.com/thing:798225/#files
Of, course Jp1.stl loaded ok. It is ascii
None of the rest of them did.
Both Meshlab and Blender loaded them fine.
Jerry
Jerry
- Isaac. Asimov
I
Anonymous
- Ken Thompson
is it?
is needed.
I am running version: version 2015.04.21 (git 167b882) on osx yosemite (10.10.3) I downloaded the STL files from this: http://www.thingiverse.com/thing:798225/#files Of, course Jp1.stl loaded ok. It is ascii None of the rest of them did. Both Meshlab and Blender loaded them fine. Jerry Jerry -- Extra Ham Operator: K7AZJ Registered Linux User: 275424 Raspberry Pi and Arduino developer *The most exciting phrase to hear in science - the one that heralds new discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov *I* *f you give someone a program, you will frustrate them for a day; if you teach them how to program, you will frustrate them for a lifetime. *- Anonymous *If writing good code requires very little comments, then writing really excellent code requires no comments at all!*- Ken Thompson On Sun, Jun 7, 2015 at 5:18 AM, Torsten Paul <Torsten.Paul@gmx.de> wrote: > On 06/07/2015 03:51 AM, Jerry Davis wrote: > >> I downloaded something from Thingiverse, and wanted to import it >> > > into OpenSCAD, and it won't import. > >> >> How? What happens? How did you import exactly? What OpenSCAD version > is it? > > Is there a difference when using F5 vs. F6? > ( > https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#Why_is_my_imported_STL_file_only_showing_up_with_F5_but_not_F6.3F > ) > > I looked at the documentation, and I couldn't find anything saying >> > > that importing binary STL files wasn't possible. > >> >> The import handles both binary and ascii STL's. > > Would this be a bug, or it just doesn't work? >> >> Without further information, I'd say the file is broken. There's a > small chance it might be a bug, but to check that, the actual file > is needed. > > ciao, > Torsten. > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Jerry Davis
Mon, Jun 8, 2015 1:41 AM
I just downloaded the latest version.
Same thing. No hits, no runs, no errors.
Saved backup file:
/Users/jdawg/Documents/OpenSCAD/backups/unsaved-backup-xJL95893.scad
Geometries in cache: 1
Geometry cache size in bytes: 47384
CGAL Polyhedrons in cache: 0
CGAL cache size in bytes: 0
Normalized CSG tree has 1 elements
Compile and preview finished.
Total rendering time: 0 hours, 0 minutes, 0 seconds
Jerry
- Isaac. Asimov
I
Anonymous
- Ken Thompson
Jerry
Jerry
- Isaac. Asimov
I
Anonymous
- Ken Thompson
is it?
is needed.
I just downloaded the latest version. Same thing. No hits, no runs, no errors. Saved backup file: /Users/jdawg/Documents/OpenSCAD/backups/unsaved-backup-xJL95893.scad Compiling design (CSG Tree generation)... Compiling design (CSG Products generation)... Geometries in cache: 1 Geometry cache size in bytes: 47384 CGAL Polyhedrons in cache: 0 CGAL cache size in bytes: 0 Compiling design (CSG Products normalization)... Normalized CSG tree has 1 elements Compile and preview finished. Total rendering time: 0 hours, 0 minutes, 0 seconds Jerry -- Extra Ham Operator: K7AZJ Registered Linux User: 275424 Raspberry Pi and Arduino developer *The most exciting phrase to hear in science - the one that heralds new discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov *I* *f you give someone a program, you will frustrate them for a day; if you teach them how to program, you will frustrate them for a lifetime. *- Anonymous *If writing good code requires very little comments, then writing really excellent code requires no comments at all!*- Ken Thompson On Sun, Jun 7, 2015 at 5:46 PM, Jerry Davis <jdawgaz@gmail.com> wrote: > I am running version: version 2015.04.21 (git 167b882) > > on osx yosemite (10.10.3) > > I downloaded the STL files from this: > http://www.thingiverse.com/thing:798225/#files > > Of, course Jp1.stl loaded ok. It is ascii > None of the rest of them did. > > Both Meshlab and Blender loaded them fine. > > Jerry > > > Jerry > > -- > Extra Ham Operator: K7AZJ > Registered Linux User: 275424 > Raspberry Pi and Arduino developer > > > *The most exciting phrase to hear in science - the one that heralds new > discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov > > *I* > *f you give someone a program, you will frustrate them for a day; if you > teach them how to program, you will frustrate them for a lifetime. *- > Anonymous > > > *If writing good code requires very little comments, then writing really > excellent code requires no comments at all!*- Ken Thompson > > On Sun, Jun 7, 2015 at 5:18 AM, Torsten Paul <Torsten.Paul@gmx.de> wrote: > >> On 06/07/2015 03:51 AM, Jerry Davis wrote: >> >>> I downloaded something from Thingiverse, and wanted to import it >>> >> > into OpenSCAD, and it won't import. >> >>> >>> How? What happens? How did you import exactly? What OpenSCAD version >> is it? >> >> Is there a difference when using F5 vs. F6? >> ( >> https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#Why_is_my_imported_STL_file_only_showing_up_with_F5_but_not_F6.3F >> ) >> >> I looked at the documentation, and I couldn't find anything saying >>> >> > that importing binary STL files wasn't possible. >> >>> >>> The import handles both binary and ascii STL's. >> >> Would this be a bug, or it just doesn't work? >>> >>> Without further information, I'd say the file is broken. There's a >> small chance it might be a bug, but to check that, the actual file >> is needed. >> >> ciao, >> Torsten. >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > >
Mon, Jun 8, 2015 6:29 AM
I downloaded Jp2.stl (binary)
I imported it OK. It is way off center, use the View-All button to find it.
I assume the same issue with the others.
http://forum.openscad.org/file/n12847/Jp2.jpg
View this message in context: http://forum.openscad.org/Import-STL-binary-files-tp12813p12847.html
I downloaded Jp2.stl (binary) I imported it OK. It is way off center, use the View-All button to find it. I assume the same issue with the others. <http://forum.openscad.org/file/n12847/Jp2.jpg> ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Import-STL-binary-files-tp12813p12847.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Jerry Davis
Mon, Jun 8, 2015 2:04 PM
duh. I see them all. they are at about 800 mm.
non issue. Well, now I know what VIEW ALL means!
Jerry
- Isaac. Asimov
I
Anonymous
- Ken Thompson
On Sun, Jun 7, 2015 at 11:29 PM, MichaelAtOz oz.at.michael@gmail.com
duh. I see them all. they are at about 800 mm. non issue. Well, now I know what VIEW ALL means! Jerry -- Extra Ham Operator: K7AZJ Registered Linux User: 275424 Raspberry Pi and Arduino developer *The most exciting phrase to hear in science - the one that heralds new discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov *I* *f you give someone a program, you will frustrate them for a day; if you teach them how to program, you will frustrate them for a lifetime. *- Anonymous *If writing good code requires very little comments, then writing really excellent code requires no comments at all!*- Ken Thompson On Sun, Jun 7, 2015 at 11:29 PM, MichaelAtOz <oz.at.michael@gmail.com> wrote: > I downloaded Jp2.stl (binary) > > I imported it OK. It is way off center, use the View-All button to find it. > > I assume the same issue with the others. > > <http://forum.openscad.org/file/n12847/Jp2.jpg> > > > > ----- > Unless specifically shown otherwise above, my contribution is in the > Public Domain; To the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. This work is > published globally via the internet. :) Inclusion of works of previous > authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ > -- > View this message in context: > http://forum.openscad.org/Import-STL-binary-files-tp12813p12847.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Mon, Jun 8, 2015 4:03 PM
hm, perhaps auto-View All on load would make sense :)
On Jun 8, 2015, at 10:04 AM, Jerry Davis <jdawgaz@gmail.com> wrote: > duh. I see them all. they are at about 800 mm. > non issue. Well, now I know what VIEW ALL means! > hm, perhaps auto-View All on load would make sense :) -Marius
