vfat vs mistakes
Gene Heskett
Mon, Apr 5, 2021 12:22 AM
Greetings all;
I figure some here have been bitten by this and may have an idea how to
defend against the file system we have learned to hate.
Is there any defense against the vfat file system telling you a pack of
lies when you go thru the motions of rewriting a file with another of
the same name, issue a sync to make sure its written, unmount it, take
it to the printer to make a new version of a part and 6 hours and 25
meters of filament later you see it building the file you overwrote!
Whats the best way to defend against that waste of time & materials?
Cheers, Gene Heskett
-Ed Howdershelt (Author)
Greetings all; I figure some here have been bitten by this and may have an idea how to defend against the file system we have learned to hate. Is there any defense against the vfat file system telling you a pack of lies when you go thru the motions of rewriting a file with another of the same name, issue a sync to make sure its written, unmount it, take it to the printer to make a new version of a part and 6 hours and 25 meters of filament later you see it building the file you overwrote! Whats the best way to defend against that waste of time & materials? Cheers, Gene Heskett -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Genes Web page <http://geneslinuxbox.net:6309/gene>
Mon, Apr 5, 2021 1:29 AM
I usually put an index number in my file names, and write a new file each
time.  If the previous file was "cover_09.gcode", I rename the next one to
be "cover_10.gcode".
On Sun, Apr 4, 2021 at 7:23 PM Gene Heskett gheskett@shentel.net wrote:
Greetings all;
I usually put an index number in my file names, and write a new file each time. If the previous file was "cover_09.gcode", I rename the next one to be "cover_10.gcode". On Sun, Apr 4, 2021 at 7:23 PM Gene Heskett <gheskett@shentel.net> wrote: > Greetings all; > > I figure some here have been bitten by this and may have an idea how to > defend against the file system we have learned to hate. > > Is there any defense against the vfat file system telling you a pack of > lies when you go thru the motions of rewriting a file with another of > the same name, issue a sync to make sure its written, unmount it, take > it to the printer to make a new version of a part and 6 hours and 25 > meters of filament later you see it building the file you overwrote! > > Whats the best way to defend against that waste of time & materials? > > Cheers, Gene Heskett > -- > "There are four boxes to be used in defense of liberty: > soap, ballot, jury, and ammo. Please use in that order." > -Ed Howdershelt (Author) > If we desire respect for the law, we must first make the law respectable. > - Louis D. Brandeis > Genes Web page <http://geneslinuxbox.net:6309/gene> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Gene Heskett
Mon, Apr 5, 2021 1:38 AM
That would work, but with the limited length,you'd have to put it not
more than 5 chars fromm the beginning. I'll see if I can remember to do
that.
thanks Leonard.
On Sunday 04 April 2021 21:29:54 Leonard Martin Struttmann wrote: > I usually put an index number in my file names, and write a new file > each time. If the previous file was "cover_09.gcode", I rename the > next one to be "cover_10.gcode". > That would work, but with the limited length,you'd have to put it not more than 5 chars fromm the beginning. I'll see if I can remember to do that. thanks Leonard. Cheers, Gene Heskett -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Genes Web page <http://geneslinuxbox.net:6309/gene>
B
bassklampfe
Mon, Apr 5, 2021 6:19 AM
I would recommend to format the SD-Card once using the approved  SD Memory
Card Formatter https://www.sdcard.org/downloads/formatter/  from the SD
Memory Card Association.
/"It is strongly recommended to use the SD Memory Card Formatter to format
SD/SDHC/SDXC Cards rather than using formatting tools provided with
individual operating systems."/
I had similar issues in an other context (transfering data from Windows to
Linux and v.v.) and they vanished after "correctly" formatting the SD-Card.
A second trap is the caching of windows. Make sure, you have correctly
"ejected" the SD-Card in Windows and see the message "You can now remove …"
before removing the SD-Card from the computer. Windows sometimes is very
lazy in writing data back to the storage device.
I would recommend to format the SD-Card once using the approved SD Memory Card Formatter <https://www.sdcard.org/downloads/formatter/> from the SD Memory Card Association. /"It is strongly recommended to use the SD Memory Card Formatter to format SD/SDHC/SDXC Cards rather than using formatting tools provided with individual operating systems."/ I had similar issues in an other context (transfering data from Windows to Linux and v.v.) and they vanished after "correctly" formatting the SD-Card. A second trap is the caching of windows. Make sure, you have correctly "ejected" the SD-Card in Windows and see the message "You can now remove …" before removing the SD-Card from the computer. Windows sometimes is very lazy in writing data back to the storage device. -- Sent from: http://forum.openscad.org/
Gene Heskett
Mon, Apr 5, 2021 8:32 AM
Memory Card Formatter https://www.sdcard.org/downloads/formatter/
Unfortunately, they are addicted to the koolaid from Redmond, and there
is no linux download. Said anotheer way, I wouldn't touch it with a 20
foot fiberglass pole.
100% linux here, and there is already some valuable data on it as its the
card that comes with the ender3. I could back it up I suppose and then
rewrite it. But I'd probably just format it to ext4 if it didn't have to
be read in a 3d printer. I have reformatted this exfat crap to fat32 and
made it work, hasn't seemed to have badly effected any 64Gig cards. Not
that I've noticed anyway. Besides, the sync command on linux is the
insurance policy, and it gets used every time I write to sneakernet
stuffs.
I recently bought one of Siglents best 4 channel 350 mhz sampling scopes,
an extremely capable scope, but also pricy. There was a firmware upgrade
I could download but before the scope could find it, a 64G exfat card
had to be reformatted to fat32. Then it just worked. I'm scope picky,
having had a scope probe in one hand since I saw my first Hickok 505 70
years ago at 16 yo.
Yup folks, I grew up in the heyday of vacuum tubes. If you have a
question about them, I can probably answer it. Including high power
klystrons that need a check for several years income cut before a
replacement can be obtained from Varian or EEV.
On Monday 05 April 2021 02:19:23 bassklampfe wrote: > I would recommend to format the SD-Card once using the approved SD > Memory Card Formatter <https://www.sdcard.org/downloads/formatter/> > from the SD Memory Card Association. > Unfortunately, they are addicted to the koolaid from Redmond, and there is no linux download. Said anotheer way, I wouldn't touch it with a 20 foot fiberglass pole. > /"It is strongly recommended to use the SD Memory Card Formatter to > format SD/SDHC/SDXC Cards rather than using formatting tools provided > with individual operating systems."/ > > I had similar issues in an other context (transfering data from > Windows to Linux and v.v.) and they vanished after "correctly" > formatting the SD-Card. > > A second trap is the caching of windows. Make sure, you have correctly > "ejected" the SD-Card in Windows and see the message "You can now > remove …" before removing the SD-Card from the computer. Windows > sometimes is very lazy in writing data back to the storage device. > 100% linux here, and there is already some valuable data on it as its the card that comes with the ender3. I could back it up I suppose and then rewrite it. But I'd probably just format it to ext4 if it didn't have to be read in a 3d printer. I have reformatted this exfat crap to fat32 and made it work, hasn't seemed to have badly effected any 64Gig cards. Not that I've noticed anyway. Besides, the sync command on linux is the insurance policy, and it gets used every time I write to sneakernet stuffs. I recently bought one of Siglents best 4 channel 350 mhz sampling scopes, an extremely capable scope, but also pricy. There was a firmware upgrade I could download but before the scope could find it, a 64G exfat card had to be reformatted to fat32. Then it just worked. I'm scope picky, having had a scope probe in one hand since I saw my first Hickok 505 70 years ago at 16 yo. Yup folks, I grew up in the heyday of vacuum tubes. If you have a question about them, I can probably answer it. Including high power klystrons that need a check for several years income cut before a replacement can be obtained from Varian or EEV. > > -- > Sent from: http://forum.openscad.org/ Cheers, Gene Heskett -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Genes Web page <http://geneslinuxbox.net:6309/gene>
B
bassklampfe
Mon, Apr 5, 2021 9:38 AM
Gene Heskett wrote
… 100% linux here …
Sorry, but it had been useful, if you had mentioned this fact in your first
post.
Gene Heskett wrote > … 100% linux here … Sorry, but it had been useful, if you had mentioned this fact in your first post. -- Sent from: http://forum.openscad.org/
Ray West
Mon, Apr 5, 2021 11:03 AM
get yourself a raspberry pi and octoprint, never bother with a plimsoll
network again for you 3d printer.
stuffs.
years ago at 16 yo.
get yourself a raspberry pi and octoprint, never bother with a plimsoll network again for you 3d printer. On 05/04/2021 09:32, Gene Heskett wrote: > On Monday 05 April 2021 02:19:23 bassklampfe wrote: > >> I would recommend to format the SD-Card once using the approved SD >> Memory Card Formatter <https://www.sdcard.org/downloads/formatter/> >> from the SD Memory Card Association. >> > Unfortunately, they are addicted to the koolaid from Redmond, and there > is no linux download. Said anotheer way, I wouldn't touch it with a 20 > foot fiberglass pole. > >> /"It is strongly recommended to use the SD Memory Card Formatter to >> format SD/SDHC/SDXC Cards rather than using formatting tools provided >> with individual operating systems."/ >> >> I had similar issues in an other context (transfering data from >> Windows to Linux and v.v.) and they vanished after "correctly" >> formatting the SD-Card. >> >> A second trap is the caching of windows. Make sure, you have correctly >> "ejected" the SD-Card in Windows and see the message "You can now >> remove …" before removing the SD-Card from the computer. Windows >> sometimes is very lazy in writing data back to the storage device. >> > 100% linux here, and there is already some valuable data on it as its the > card that comes with the ender3. I could back it up I suppose and then > rewrite it. But I'd probably just format it to ext4 if it didn't have to > be read in a 3d printer. I have reformatted this exfat crap to fat32 and > made it work, hasn't seemed to have badly effected any 64Gig cards. Not > that I've noticed anyway. Besides, the sync command on linux is the > insurance policy, and it gets used every time I write to sneakernet > stuffs. > > I recently bought one of Siglents best 4 channel 350 mhz sampling scopes, > an extremely capable scope, but also pricy. There was a firmware upgrade > I could download but before the scope could find it, a 64G exfat card > had to be reformatted to fat32. Then it just worked. I'm scope picky, > having had a scope probe in one hand since I saw my first Hickok 505 70 > years ago at 16 yo. > > Yup folks, I grew up in the heyday of vacuum tubes. If you have a > question about them, I can probably answer it. Including high power > klystrons that need a check for several years income cut before a > replacement can be obtained from Varian or EEV. > >> -- >> Sent from: http://forum.openscad.org/ > > Cheers, Gene Heskett
Rob Ward
Mon, Apr 5, 2021 11:18 AM
At least RPi+OctoPrint (a liberating experience) is open source and your suggestions are listened to.
Cheers, RobW
there
20
provided
correctly
then
to
and
Not
stuffs.
scopes,
upgrade
70
years ago at 16 yo.
At least RPi+OctoPrint (a liberating experience) is open source and your suggestions are listened to. Cheers, RobW On 5 April 2021 9:03:07 pm AEST, Ray West <raywest@raywest.com> wrote: >get yourself a raspberry pi and octoprint, never bother with a plimsoll > >network again for you 3d printer. > >On 05/04/2021 09:32, Gene Heskett wrote: >> On Monday 05 April 2021 02:19:23 bassklampfe wrote: >> >>> I would recommend to format the SD-Card once using the approved SD >>> Memory Card Formatter <https://www.sdcard.org/downloads/formatter/> >>> from the SD Memory Card Association. >>> >> Unfortunately, they are addicted to the koolaid from Redmond, and >there >> is no linux download. Said anotheer way, I wouldn't touch it with a >20 >> foot fiberglass pole. >> >>> /"It is strongly recommended to use the SD Memory Card Formatter to >>> format SD/SDHC/SDXC Cards rather than using formatting tools >provided >>> with individual operating systems."/ >>> >>> I had similar issues in an other context (transfering data from >>> Windows to Linux and v.v.) and they vanished after "correctly" >>> formatting the SD-Card. >>> >>> A second trap is the caching of windows. Make sure, you have >correctly >>> "ejected" the SD-Card in Windows and see the message "You can now >>> remove …" before removing the SD-Card from the computer. Windows >>> sometimes is very lazy in writing data back to the storage device. >>> >> 100% linux here, and there is already some valuable data on it as its >the >> card that comes with the ender3. I could back it up I suppose and >then >> rewrite it. But I'd probably just format it to ext4 if it didn't have >to >> be read in a 3d printer. I have reformatted this exfat crap to fat32 >and >> made it work, hasn't seemed to have badly effected any 64Gig cards. >Not >> that I've noticed anyway. Besides, the sync command on linux is the >> insurance policy, and it gets used every time I write to sneakernet >> stuffs. >> >> I recently bought one of Siglents best 4 channel 350 mhz sampling >scopes, >> an extremely capable scope, but also pricy. There was a firmware >upgrade >> I could download but before the scope could find it, a 64G exfat card >> had to be reformatted to fat32. Then it just worked. I'm scope picky, >> having had a scope probe in one hand since I saw my first Hickok 505 >70 >> years ago at 16 yo. >> >> Yup folks, I grew up in the heyday of vacuum tubes. If you have a >> question about them, I can probably answer it. Including high power >> klystrons that need a check for several years income cut before a >> replacement can be obtained from Varian or EEV. >> >>> -- >>> Sent from: http://forum.openscad.org/ >> >> Cheers, Gene Heskett >_______________________________________________ >OpenSCAD mailing list >To unsubscribe send an email to discuss-leave@lists.openscad.org
CA
Tue, Apr 6, 2021 9:07 AM
Cheers, RobW
I second that, I have a 6 year old RPi+OctoPrint that still works fine
for my use, it is accessed over WiFi. I use both Kubuntu and Win10 for
modelling, but the RPi controls the printer.
I am guessing the recent versions of OctoPrint work even better.
On 05.04.2021 13:18, Rob Ward wrote: > At least RPi+OctoPrint (a liberating experience) is open source and your > suggestions are listened to. > Cheers, RobW I second that, I have a 6 year old RPi+OctoPrint that still works fine for my use, it is accessed over WiFi. I use both Kubuntu and Win10 for modelling, but the RPi controls the printer. I am guessing the recent versions of OctoPrint work even better. Carsten Arnholm
Rob Ward
Tue, Apr 6, 2021 11:57 AM
I use Ubuntu Mate with OpenSCAD as a self contained AppImage file and it works straight out of the Zip. Combined with Cura, Marlin and Octoprint it is a pleasure to use. All up to date on a  RPi3B and a GT-2560. Breathed new life into my proprietary hardware Robox carcass after I gutted it of anything I could not control 100%.
Cheers, RobW
your
Cheers, RobW
I use Ubuntu Mate with OpenSCAD as a self contained AppImage file and it works straight out of the Zip. Combined with Cura, Marlin and Octoprint it is a pleasure to use. All up to date on a RPi3B and a GT-2560. Breathed new life into my proprietary hardware Robox carcass after I gutted it of anything I could not control 100%. Cheers, RobW On 6 April 2021 7:07:41 pm AEST, Carsten Arnholm <arnholm@arnholm.org> wrote: >On 05.04.2021 13:18, Rob Ward wrote: >> At least RPi+OctoPrint (a liberating experience) is open source and >your >> suggestions are listened to. >> Cheers, RobW > >I second that, I have a 6 year old RPi+OctoPrint that still works fine >for my use, it is accessed over WiFi. I use both Kubuntu and Win10 for >modelling, but the RPi controls the printer. > >I am guessing the recent versions of OctoPrint work even better. > >Carsten Arnholm >_______________________________________________ >OpenSCAD mailing list >To unsubscribe send an email to discuss-leave@lists.openscad.org
