Weird behaviour of commandline parameters
JK
Jan Koupil
Fri, Aug 14, 2020 7:32 AM
Hi all,
I am generating a set of tiles and I am using the (windows) commandline
to do it. My typical cmd command is:
"c:\Program Files\OpenSCAD\openscad.com" -o stl\tile_6_3.stl -D "x=6" -D
"y=3" cmdline_tile.scad
The cmdline_tile.scad file contains this code:
$fn = 30;
use <tile_module.scad>;
// dQ
midHeight = 38;
slopeN = [-95 / 12 * y, -57 / 12 * x, 32];
tile (slopeN, h = midHeight);
And this produces an error:
WARNING: Ignoring unknown variable 'y', in file cmdline_tile.scad, line 6.
WARNING: undefined operation (number * undefined) in file
WARNING: Ignoring unknown variable 'x', in file cmdline_tile.scad, line 6.
And of course the result is empty...
If I add echo before the slopeN= […] assignment, the variables show
themselves to be existent:
echo (x=x, y=y);
which produces this output line:
ECHO: x = 6, y = 3
again followed by the error claiming that variable 'y' is unknown etc.
What is, however, unexplainable for me, is the fact that the command on
last line works, if I build the slope vector inline:
tile (n = [-95 / 12 * y, -57 / 12 * x, 32], h = midHeight);
This does not raise any warning and builds the expected tile. Why? And
why I cannot build the vector and then use it?
(OK, I have a workaround now but I am not happy with the path)
Jan
Hi all, I am generating a set of tiles and I am using the (windows) commandline to do it. My typical cmd command is: "c:\Program Files\OpenSCAD\openscad.com" -o stl\tile_6_3.stl -D "x=6" -D "y=3" cmdline_tile.scad The cmdline_tile.scad file contains this code: $fn = 30; use <tile_module.scad>; // dQ midHeight = 38; slopeN = [-95 / 12 * y, -57 / 12 * x, 32]; tile (slopeN, h = midHeight); And this produces an error: WARNING: Ignoring unknown variable 'y', in file cmdline_tile.scad, line 6. WARNING: undefined operation (number * undefined) in file cmdline_tile.scad, line 6 WARNING: Ignoring unknown variable 'x', in file cmdline_tile.scad, line 6. WARNING: undefined operation (number * undefined) in file cmdline_tile.scad, line 6 And of course the result is empty... If I add echo before the slopeN= […] assignment, the variables show themselves to be existent: echo (x=x, y=y); which produces this output line: ECHO: x = 6, y = 3 again followed by the error claiming that variable 'y' is unknown etc. What is, however, unexplainable for me, is the fact that the command on last line works, if I build the slope vector inline: tile (n = [-95 / 12 * y, -57 / 12 * x, 32], h = midHeight); This does not raise any warning and builds the expected tile. Why? And why I cannot build the vector and then use it? (OK, I have a workaround now but I am not happy with the path) Jan
O
OzAtMichael
Fri, Aug 14, 2020 7:44 AM
'-D' adds that text to the end of the file (in memory).
so you get this
$fn = 30;
// dQ
midHeight = 38;
x=6;y=3;
Try that in the GUI
The magic source is
$fn = 30;
// dQ
midHeight = 38;
x=0; y=0;
x=6;y=3;
If you want to know why, ask, but I'll answer tomorrow, I have a glass of red calling to me...
From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of Jan Koupil
Sent: Fri, 14 Aug 2020 17:32
Subject: [OpenSCAD] Weird behaviour of commandline parameters
Hi all,
command is:
$fn = 30;
// dQ
midHeight = 38;
If I add echo before the slopeN = [.] assignment, the variables show themselves to be existent:
echo (x=x, y=y);
ECHO: x = 6, y = 3
Jan
'-D' adds that text to the end of the file (in memory). so you get this $fn = 30; use <tile_module.scad>; // dQ midHeight = 38; slopeN = [-95 / 12 * y, -57 / 12 * x, 32]; tile (slopeN, h = midHeight); x=6;y=3; Try that in the GUI The magic source is $fn = 30; use <tile_module.scad>; // dQ midHeight = 38; x=0; y=0; slopeN = [-95 / 12 * y, -57 / 12 * x, 32]; tile (slopeN, h = midHeight); x=6;y=3; If you want to know why, ask, but I'll answer tomorrow, I have a glass of red calling to me... _____ From: Discuss [mailto:discuss-bounces@lists.openscad.org] On Behalf Of Jan Koupil Sent: Fri, 14 Aug 2020 17:32 To: discuss@lists.openscad.org Subject: [OpenSCAD] Weird behaviour of commandline parameters Hi all, I am generating a set of tiles and I am using the (windows) commandline to do it. My typical cmd command is: "c:\Program Files\OpenSCAD\openscad.com" -o stl\tile_6_3.stl -D "x=6" -D "y=3" cmdline_tile.scad The cmdline_tile.scad file contains this code: $fn = 30; use <tile_module.scad>; // dQ midHeight = 38; slopeN = [-95 / 12 * y, -57 / 12 * x, 32]; tile (slopeN, h = midHeight); And this produces an error: WARNING: Ignoring unknown variable 'y', in file cmdline_tile.scad, line 6. WARNING: undefined operation (number * undefined) in file cmdline_tile.scad, line 6 WARNING: Ignoring unknown variable 'x', in file cmdline_tile.scad, line 6. WARNING: undefined operation (number * undefined) in file cmdline_tile.scad, line 6 And of course the result is empty... If I add echo before the slopeN = [.] assignment, the variables show themselves to be existent: echo (x=x, y=y); which produces this output line: ECHO: x = 6, y = 3 again followed by the error claiming that variable 'y' is unknown etc. What is, however, unexplainable for me, is the fact that the command on last line works, if I build the slope vector inline: tile (n = [-95 / 12 * y, -57 / 12 * x, 32], h = midHeight); This does not raise any warning and builds the expected tile. Why? And why I cannot build the vector and then use it? (OK, I have a workaround now but I am not happy with the path) Jan -- This email has been checked for viruses by AVG. https://www.avg.com
Fri, Aug 14, 2020 10:22 AM
Variables are initialized in order, modules called afterwards,
so if you want to use -D variables to calculate others, you
need to give them some initial value in the script before use.
a = 3;
b = a + 2;
echo(a, b);
openscad -Da=1 ...
On 14.08.20 09:32, Jan Koupil wrote: > This does not raise any warning and builds the expected tile. > Why? And why I cannot build the vector and then use it? Variables are initialized in order, modules called afterwards, so if you want to use -D variables to calculate others, you need to give them some initial value in the script before use. a = 3; b = a + 2; echo(a, b); openscad -Da=1 ... ciao, Torsten.
