I'm a new user to OpenSCAD (but not to coding). I downloaded the following
model from Thingiverse:
Parametric Balloon Nozzle https://www.thingiverse.com/thing:2820765
When I open the SCAD file the designer included, it takes 1 min 22 seconds
just to show it. At first I thought the software had crashed, but it was
just taking a long time to show the model.
Any time I make a change to a parameter, it again takes a long time to
render. I've worked with other models and they render in seconds on my
computer (Intel Core i7).
Also, when I try to print the STL from Thingiverse (slicing via Cura),
something screws up the printer and it doesn't extrude any filament!
Looking through the posts I can see that there are ways to simplify a model,
but as a new user to this software, I could use some suggestions.
File is attached. Thank you for any help!
BalloonRocketNozzle.scad
http://forum.openscad.org/file/t3178/BalloonRocketNozzle.scad
I reduced the facet count ($fn) from 120 to 60 and it takes seconds to preview and render, even after a change.
On Monday, March 29, 2021, 7:14:50 PM EDT, JeffHaas <jeff.jh.haas@gmail.com> wrote:
I'm a new user to OpenSCAD (but not to coding). I downloaded the following model from Thingiverse:
When I open the SCAD file the designer included, it takes 1 min 22 seconds just to show it. At first I thought the software had crashed, but it was just taking a long time to show the model.
Any time I make a change to a parameter, it again takes a long time to render. I've worked with other models and they render in seconds on my computer (Intel Core i7).
Also, when I try to print the STL from Thingiverse (slicing via Cura), something screws up the printer and it doesn't extrude any filament!
Looking through the posts I can see that there are ways to simplify a model, but as a new user to this software, I could use some suggestions.
Also replace Oskar's older library functions with these
module fillet(r) {
offset(r = -r) {
offset(delta = r) {
module rounding(r) {
offset(r = r) {
offset(delta = -r) {
Which use the newer built-in offset() which is much faster.
Well under 1s even with $fn=120. (but only use such high $fn for the final
render, not in dev.)
The answer is to replace the inefficient inset() and outset() modules with
references to offset(). This code was written for a very old OpenSCAD that
didn't have offset(). With this change it displays in 0.3 s for me with
$fn=120, and render takes 2.5s. See attached code.
http://forum.openscad.org/file/t2477/BalloonRocketNozzle.scad
following
<https://www.thingiverse.com/thing:2820765>
model,
<http://forum.openscad.org/file/t3178/BalloonRocketNozzle.scad>
discuss-leave@.openscad
HOW do I turn off this list? I already removed myself from the
list-server (I think!) 600+ emails per week, most that don't concern
me, is a bit too much for my little brain.
Thanks,
David:
Did you send an email to "discuss-leave@lists.openscad.org"
Thanks,
David replied to me that he did send that discuss-leave email (he failed
to hit Reply All, something I often forget to do with this email system).
So the question would be "did his email make it" and "is that facility
working"
On 3/29/2021 9:44 PM, jon wrote:
David:
me, is a bit too much for my little brain.Thanks,
I'm emailing him.
Sent: Tue, 30 Mar 2021 12:55
To: OpenSCAD general discussion; David Merchant
Subject: [OpenSCAD] Re: Get no more of these emails?
working"
David:
Thanks,
Thank you everyone for the fast replies!
These tips solved the issue, now it is blazingly fast. I'm testing how
these print, and the first one went fine, so later I plan to upload a
"remix" of the files to Thingiverse that includes these suggestions for
improvements (with full credit to the posts on this forum) as well as
corrected STLs.
Later I'll work my way through the tutorials.
Thanks again for the help.
