Hi all,
I have a few issues that crept up all of a sudden with my PC running
OpenScad.
This started off randomly when I opened the program after work the other day
after having spent and evening prior working on a project. The app loads the
editor, the console and the code from the selected project but no
render/preview window. Hitting F5 or the option in the menu appears to run
fine in the console but thats as far as it gets. Hitting F6 however stats
the render and gets to approx 475/1000 before the app closes and drops an
error in my event viewer which doesn't show much of anything:
Faulting application name: openscad.exe, version: 0.0.0.0, time stamp:
0x564d2b59
Faulting module name: openscad.exe, version: 0.0.0.0, time stamp: 0x564d2b59
Exception code: 0x40000015
Fault offset: 0x0000000000f9801a
Faulting process id: 0x3258
Faulting application start time: 0x01d44d3fbf0520be
Faulting application path:
C:\Users\John\Downloads\OpenSCAD-2015.03-2-x86-64\openscad-2015.03-2\openscad.exe
Faulting module path:
Report Id: 2a5e9b25-c4a5-4ce5-a059-2940edba4ee2
Faulting package full name:
Faulting package-relative application ID:
I have tried the whole uninstall>reboot>install routine many times and even
using the binary, not the installer. Falling back on my Sysadmin methods I
decided to try and run the app from the CLI as my user and as admin and this
is where I am finally seeing some details that I need some insight on.
Running the app from the CLI I get this after opening a new or existing
project:
GLEW Error: Missing GL version
I know that GL is up to date and my drivers have been both reinstalled and
then updated when the results were the same. Render shows this in the CLI
(the first line is on open of the .scad file, the rest on crash):
CGAL error: assertion violation!
Expression : object_list_
File : ../src/OGL_helper.h
Line : 571
Explanation:
Refer to the bug-reporting instructions at
http://www.cgal.org/bug_report.html
I tried to open Help>Library Info and get this:
terminate called after throwing an instance of 'std::logic_error'
what(): basic_string::_M_construct null not valid
Finally I tried to run "openscad.exe --info" and got this and the app failed
to load at all:
C:\Users\John\Downloads\OpenSCAD-2015.03-2-x86-64\openscad-2015.03-2>openscad.exe
--info
C:\Users\John\Downloads\OpenSCAD-2015.03-2-x86-64\openscad-2015.03-2>OpenSCAD
Version: 2015.03-2
System information: Windows 8 (v6.2.0.0) 8 CPUs 15.90 GB RAM
Compiler: GCC "5.2.0" 64bit
Boost version: 1_57
Eigen version: 3.2.5
CGAL version, kernels: 4.5, Cartesian<Gmpq>, Extended_cartesian<Gmpq>, Epeck
OpenCSG version: OpenCSG 1.4.0
Qt version: 5.5.1
QScintilla version: 2.8.4
MingW build: MingW64
GLib version: 2.44.1
Application Path:
C:/Users/John/Downloads/OpenSCAD-2015.03-2-x86-64/openscad-2015.03-2
Documents Path: C:\Users\John\Documents
Resource Path:
User Library Path: C:/Users/John/Documents/OpenSCAD/libraries
User Config Path: C:\Users\John\AppData\Local/OpenSCAD
Backup Path: C:/Users/John/Documents/OpenSCAD/backups
OPENSCADPATH: <not set>
OpenSCAD library path:
C:/Users/John/Downloads/OpenSCAD-2015.03-2-x86-64/openscad-2015.03-2\libraries
OPENSCAD_FONT_PATH: <not set>
OpenSCAD font path:
OpenGL Program Validation results:
Validation successful.
GLEW version: 1.12.0
OpenGL Version: 4.5.13539 Compatibility Profile Context 24.20.13017.1009
GL Renderer: Radeon RX 580 Series
GL Vendor: ATI Technologies Inc.
RGBA(8888), depth(24), stencil(8)
GL_ARB_framebuffer_object: yes
GL_EXT_framebuffer_object: yes
GL_EXT_packed_depth_stencil: yes
GL context creator: WGL
PNG generator: lodepng
OS info: Microsoft(TM) Windows(TM) 6 2 9200 0x24bd0e4 amd64
Machine: 8664
Sorry for the long post, my sysadmin work taught me that there is no such
thing as too much information.
Do you get the same errors with a development snapshot of OpenSCAD?
http://www.openscad.org/downloads.html#snapshots
On Sat, Sep 15, 2018 at 5:53 PM tangerine0469
stapleton.hosting@gmail.com wrote:
Hi all,
OpenScad.
0x564d2b59
project:
Line : 571
Explanation:
to load at all:
--info
Version: 2015.03-2
Boost version: 1_57
Qt version: 5.5.1
Application Path:
Resource Path:
OpenSCAD font path:
Machine: 8664
Is your project doing any import()'s?
What happens with just:
cube();
sphere();
Using the Snapshot I get the following when doing an F6:
C:\Users\John\Downloads\OpenSCAD-2018.09.05-x86-64\openscad-2018.09.05>GLEW
File : ../src/ext/CGAL/OGL_helper.h
Line : 572
Explanation:
Trying to get the info from Help>Library Information I get the following:
A critical Error was caught. The application may have become unstable:
cube();
sphere();
When I try the basic shapes I get this:
cube(20);
sphere(20);
Console after F5:
Saved backup file:
C:/Users/John/Documents/OpenSCAD/backups/unsaved-backup-lHOvRHJL.scad
Geometries in cache: 2
Geometry cache size in bytes: 62800
CGAL Polyhedrons in cache: 0
CGAL cache size in bytes: 0
Normalized CSG tree has 2 elements
Compile and preview finished.
Total rendering time: 0 hours, 0 minutes, 0 seconds
F6
Line : 572
Explanation:
but no render/preview window
Chicken/Egg, is the lack of the window causing the error, or an OpenGL error
prevent the window opening...hmm
It was working and you haven't upgraded the graphics card?
It has the taste of a graphics driver issue...
error
That's the thing, There were zero changes made to the machine. I lock mine
down from auto-updates due to watching the horrors they cause at the data
center I do advanced implementations at. Not a domain controlled computer
but I have picked the auto updates clean through LGPO, services and
scheduled tasks lol.
I was feeling the same thing so thats when I decided to try and update them,
reboot, test. When that failed I removed entirely and rolled back to the
known good ones and no dice. I have two newish (6 month old or less) rx
580's, not running any advanced features like Eyenfinity or crossfire, no
overclocking, not coin mining, etc. I will admit that I am more of an
OS/Hardware/Server Software flavor of IT guy and GPU drivers are not on my
nice list but to literally break overnight like that is beyond strange.
I attached a copy of my code for the part I was working on. You can ignore
the commented out render() as that was a test I ran to see if it could do so
without crashing the app. Adding render() to the part certainly locks it up
while it does so but it doesn't crash nor fix the issue so I commented it
out.
This is still very clearly a work in progress so ignore the ugly
code/appearance.
For reference my machine is this:
FX-8350 CPU
16GB ram
dual rx580
Liquid loop CPU cooler
Raid 10 primary HDD using Perc h700 with BBU and 1GB Memory
4 monitors
All tests were run with nothing else running outside of normal OS services
for maximum resource availability
shield.scad http://forum.openscad.org/file/t2341/shield.scad
That previews & renders on my W7/64 system with 2015.03-2/64.
F6:
Saved backup file:
C:/Users/MeB/Documents/OpenSCAD/backups/unsaved-backup-gqHp8060.scad
Geometries in cache: 2255
Geometry cache size in bytes: 849072
CGAL Polyhedrons in cache: 8
CGAL cache size in bytes: 45322736
Total rendering time: 0 hours, 4 minutes, 41 seconds
Simple: no
Vertices: 6460
Halfedges: 19380
Edges: 9690
Halffacets: 6472
Facets: 3236
Volumes: 2
WARNING: Object may not be a valid 2-manifold and may need repair!
Rendering finished.
Same on a recent development snapshot.
OpenGL Version: 4.5.13539 *Compatibility Profile Context 24.20.13017.1009 *
Hmm, In GL 3.3 Core specification, Appendix E, it is said that a GL context
that doesn't support deprecated features is called a forward compatible
context,
https://www.opengl.org/discussion_boards/showthread.php/175052-Forward-compatible-vs-Core-profile
There appears to be an issue with OpenGL >3.0, but this is above my head.
IS anyone else using Dual Radeon RX 580?
When I checked using taskman, nothing aside from the normal windows desktop
services. On a whim I opened the app and moved it to another monitor (Each
card has two displays plugged into them, arranged in an 1 over 3 array) and
closed it so windows remembered which one to render it on when opened
next... Turns out the moment I opened it on the primary display (last test)
suddenly it rendered just fine.
I took it and repeated the process on each monitor again and boom, works
like a charm now. Best guess here is that the one card crapped out/hiccuped
and being as windows persistence was in play it got caught in a loop until
moving it around the cards cleared it up. Still kinda like voodoo but I will
take it as a win.
Thank you for the help, prods in the right direction and trying to figure it
out. Seems like this experience will definitely be useful on a rainy day.
That's good.
Are you getting 'WARNING: Object may not be a valid 2-manifold and may need
repair!'?
If so I suspect the
linear_extrude(ild,true) translate([-(ild * 1),-(ild * 21),ild])
rotate([0,0,45]) square([fd,fd],true);
Is coplanar with the rest.
You should also see this
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#What_are_those_strange_flickering_artifacts_in_the_preview?
re preview artifacts.
But i presume you are still working on it.
