Which commands would I use to take an object and wrap it around a cylinder?
Say I have something simple like a 3 x 16 x 1/4 rectangular plate and I
want to wrap it around a cylinder, or shape it into a cylinder end-to-end.
Is there something engraved on this plate? Otherwise I'm not seeing the
probem.
There are instances where a pattern can be on a rectangular plate. It
would be nice to be able to wrap that pattern around a cylinder.
probem.
cylinder?
Yes, it would. I've tried, but I never got it to work very well. Basically,
you have to slice the plate into tiny vertical columns and rotate them
around the cylinder. If someone has a better way, I'd love to see it.
probem.
cylinder?
There is a BOSL2 command,
https://github.com/revarbat/BOSL2/wiki/vnf.scad#function-vnf_bend
that can bend a polyhedron (a vertices and faces list) around a
cylinder. But it can't work on geometry. It's pretty difficult to do
something like that to geometry.
On Tue, May 3, 2022 at 10:34 PM Joe Weinpert joe.weinpert@gmail.com wrote:
There are instances where a pattern can be on a rectangular plate. It would be nice to be able to wrap that pattern around a cylinder.
Is there something engraved on this plate? Otherwise I'm not seeing the probem.
Say I have something simple like a 3 x 16 x 1/4 rectangular plate and I want to wrap it around a cylinder, or shape it into a cylinder end-to-end.
I just found a function in the BOSL2 library named cylindrical_extrude().
Been working with it. It is just what I needed. It also has some
brother and sister functions that do similar things.
probem.
cylinder?
