I'm in the process of moving some of my development workover to some virtual
machines. As a consequence I am running OpenSCAD via a x-windows server
(Xming).
The VM is running Ubuntu 14.04 and I've installed OpenSCAD 2015.03-1. When
OpenSCAD is run on the Ubuntu desktop the File menu appears at the top of
the screen. From here I can export to STL.
However, when I run OpenSCAD over x-windows I don't get the top menu and the
only way I export to STL is to enable the editor pane, where there is
button. I would rather not have the editor window open as I'm using an
external editor.
Would it be possible to add or move the 'Export to STL' button to the
console pane?
Regards, Ian.
View this message in context: http://forum.openscad.org/Running-OpenSCAD-with-Xwindows-tp13639.html
external editor.
console pane?
This is probably the Ubuntu bug again. Ubuntu messes with the normal menus.
Maybe the procedure from the FAQ helps to workaround the issue:
external editor.
console pane?
menus.
If that doesn't work then I would try using a different window manager
on the ubuntu system, like XFCE.
Similar to what these folks did
http://ubuntuforums.org/showthread.php?t=2190722
don bright
hmbright@fastmail.fm
Hi Torsten,
Thank you very much for the link.
Using QT_QPA_PLATFORMTHEME= openscad works.. So I will use that for now.
I'm not comfortable with removing the appmenu-qt5 package as I'm not
sure what other side effects there may be.
Regards, Ian
external editor.
console pane?
