The problem is not that they include the last value, though one can debate
that decision. The problem is that [0:-1] counts from the end instead of
giving you the empty list. And the solution, without any changes to
OpenSCAD, is to simply write your code with a step size of 1 as
[0:1:len(list)-1]
which will do the right thing in all cases. No special casing or tests are
needed. Just always put in that step size of 1.
But the problem I'm struggling with is that I'm running code that has
libraries so there are hundreds of lines of code, and I get this warning
that somewhere in my code I have the flipped range order. How the heck am I
supposed to find it and fix it? Is there a way to get the deprecation to be
an actual warning so that "stop on first warning" will stop and give me a
trace? Because otherwise it can be quite the guessing game.
nophead wrote
The problem with OpenSCAD ranges is they include the last value, so you
can
never have a loop that doesn't do any iterations, you have to check for
that first. When iterating over the indices of a list you need [0 :
len(list) -1] but then if the list is empty you get [0 : -1] which I think
warns and then iterates backwards. All other languages I know use half
open
ranges, so can have zero elements and don't need the -1.
Using the new C style loops is a work around for that.
On Wed, 22 May 2019 at 17:41, A. Craig West <
It occurs to me that I haven't checked this since I switched to more
recent builds. It was certainly the behavior in the 2015 version, but
that
is much less relevant now 😊.
I shall give this a try. Hopefully thingiverse will start using the new
version for their customiser, as that has been the only thing keeping me
back on that one...
On Wed, 22 May 2019, 12:32 Torsten Paul, <
On 22.05.19 15:15, A. Craig West wrote:
len(v) == 0 ? [] :
[ for (o = v)...]
This has nothing to do with ranges as far as I can see. Can
you elaborate on why that is needed? If there's a bug then
it can only be fixed if it's reported.
v = [];
echo([for (a = v) a]);
Works fine and reports an empty list which is what I would
expect. So in which case is that len() needed?
[0:1:len(list)-1]
> can
> open
> acraigwest@
>> that
>> back on that one...
> Torsten.Paul@
>>> > len(v) == 0 ? [] :
>>> > [ for (o = v)...]
>>> v = [];
>>> ciao,
>>> Torsten.
>>> _______________________________________________
>>> OpenSCAD mailing list
> Discuss@.openscad
>>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
> Discuss@.openscad
> Discuss@.openscad
