t-bird sort filters
Sun, Dec 14, 2025 7:56 PM
Got an unusual prob with this list and t-bird msg filters
1: t-bird has no List-ID choice so I can't filter this List-ID to my
local_folder/OpenSCAD directory
2: that leaves to,from,cc,bcc containing "lists.openscad.org" which has
worked for a couple years
    with move_to, and mark unread as the do options
3: it quit working after about noonish 11/25. I didn't change anything
till today but I now have
325 msgs It now marks as unread, but refuses to move them even after I
choose from tools/run on
folder with the inbox selected.
Did you change anything in the headers on about that date?  The rest of
my 30 some rules still work.
Thank you.
Cheers, Gene Heskett, CET.
  • Louis D. Brandeis
Got an unusual prob with this list and t-bird msg filters 1: t-bird has no List-ID choice so I can't filter this List-ID to my local_folder/OpenSCAD directory 2: that leaves to,from,cc,bcc containing "lists.openscad.org" which has worked for a couple years     with move_to, and mark unread as the do options 3: it quit working after about noonish 11/25. I didn't change anything till today but I now have 325 msgs It now marks as unread, but refuses to move them even after I choose from tools/run on folder with the inbox selected. Did you change anything in the headers on about that date?  The rest of my 30 some rules still work. Thank you. Cheers, Gene Heskett, CET. -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author, 1940) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Don't poison our oceans, interdict drugs at the src.
Michael Marx (spintel)
Mon, Dec 15, 2025 1:35 AM
Nothing intentionally changed with the Mailing-list.
My Outlook rules are working, based on 'sent to' 'discuss@lists.openscad.org' & '[OpenSCAD]' in subject.
('sent to' in Outlook must be generic, to,cc etc as it works with the following)
Note that some people do reply-all, and if your address was in the conversation,
you may get a reply 'To' your address, with the Mailing-list 'cc'.
As you can see in your message below, the From/To still contains 'list.openscad.org'.
Unfortunately, I'm not t-bird expert.
From: gene heskett via Discuss [mailto:discuss@lists.openscad.org]
Sent: Monday, December 15, 2025 6:57 AM
Cc: gene heskett
Subject: [OpenSCAD] t-bird sort filters
Thank you.
  • Louis D. Brandeis
Nothing intentionally changed with the Mailing-list. My Outlook rules are working, based on 'sent to' 'discuss@lists.openscad.org' & '[OpenSCAD]' in subject. ('sent to' in Outlook must be generic, to,cc etc as it works with the following) Note that some people do reply-all, and if your address was in the conversation, you may get a reply 'To' your address, with the Mailing-list 'cc'. As you can see in your message below, the From/To still contains 'list.openscad.org'. Unfortunately, I'm not t-bird expert. _____ From: gene heskett via Discuss [mailto:discuss@lists.openscad.org] Sent: Monday, December 15, 2025 6:57 AM To: discuss@lists.openscad.org Cc: gene heskett Subject: [OpenSCAD] t-bird sort filters Got an unusual prob with this list and t-bird msg filters 1: t-bird has no List-ID choice so I can't filter this List-ID to my local_folder/OpenSCAD directory 2: that leaves to,from,cc,bcc containing "lists.openscad.org" which has worked for a couple years with move_to, and mark unread as the do options 3: it quit working after about noonish 11/25. I didn't change anything till today but I now have 325 msgs It now marks as unread, but refuses to move them even after I choose from tools/run on folder with the inbox selected. Did you change anything in the headers on about that date? The rest of my 30 some rules still work. Thank you. Cheers, Gene Heskett, CET. -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author, 1940) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Don't poison our oceans, interdict drugs at the src.
F
frechefuchs
Mon, Dec 15, 2025 7:32 AM
Am 14.12.25 um 20:56 schrieb gene heskett via Discuss:
I'm filtering by List-Id for years with Thunderbird.  In the header
selection, there is an item 'Customize' which can be used to add missing
header filters.  Next time, the custom filter appears in the header
selection among the other pre-defined ones.
(At least, that's how I recall me having the List-Id filter available.)
Regards,
frechefuchs
Am 14.12.25 um 20:56 schrieb gene heskett via Discuss: > Got an unusual prob with this list and t-bird msg filters > 1: t-bird has no List-ID choice so I can't filter this List-ID to my > local_folder/OpenSCAD directory I'm filtering by List-Id for years with Thunderbird. In the header selection, there is an item 'Customize' which can be used to add missing header filters. Next time, the custom filter appears in the header selection among the other pre-defined ones. (At least, that's how I recall me having the List-Id filter available.) Regards, frechefuchs
Douglas Miller
Mon, Dec 15, 2025 10:18 AM
It doesn't have that choice by default, but you can add it:
Tools > Message Filters > New
Then click the down-arrow to display the list of choices (Subject, From,
Body, etc.), scroll that list all the way to the bottom, and click
"Customize". Then you can add List-ID to the list of choices.
On 12/14/2025 2:56 PM, gene heskett wrote: > Got an unusual prob with this list and t-bird msg filters > 1: t-bird has no List-ID choice so I can't filter this List-ID to my > local_folder/OpenSCAD directory It doesn't have that choice by default, but you can add it: Tools > Message Filters > New Then click the down-arrow to display the list of choices (Subject, From, Body, etc.), scroll that list all the way to the bottom, and click "Customize". Then you can add List-ID to the list of choices.
Mon, Dec 15, 2025 3:04 PM
Done, looks like it works.  Thanks a bunch.
nnCheers, Gene Heskett, CET.
  • Louis D. Brandeis
On 12/15/25 05:25, Douglas Miller via Discuss wrote: > On 12/14/2025 2:56 PM, gene heskett wrote: >> Got an unusual prob with this list and t-bird msg filters >> 1: t-bird has no List-ID choice so I can't filter this List-ID to my >> local_folder/OpenSCAD directory > It doesn't have that choice by default, but you can add it: > > Tools > Message Filters > New > > Then click the down-arrow to display the list of choices (Subject, > From, Body, etc.), scroll that list all the way to the bottom, and > click "Customize". Then you can add List-ID to the list of choices. Done, looks like it works.  Thanks a bunch. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org nnCheers, Gene Heskett, CET. -- "There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order." -Ed Howdershelt (Author, 1940) If we desire respect for the law, we must first make the law respectable. - Louis D. Brandeis Don't poison our oceans, interdict drugs at the src.
