John David
Thu, Feb 12, 2026 12:41 AM
I am trying to use a hashmap that will work in both OpenSCAD and
PythonSCAD, but I keep getting errors that the function is not found. Has
anyone had success in calling OpenSCAD code from PythonSCAD, which includes
a hashmap?
A snippet of the code is as follows:
OpenSCAD:
Color_Table =
hashmap(items=[ // the laser color parameters (name,power,feed,color)
["L00",[1.0,1.0,0x000000]],
["L01",[1.0,1.0,0x0000FF]],
["L02",[1.0,1.0,0xFF0000]],
["L29",[1.0,1.0,0xFFDB66]],
["T1",[0.0,0.0,0xF36926]],
["T2",[0.0,0.0,0x0C96D9]]
function Color_Table_to_color(name) = Color_Table[name][2];
I have also tried making the color table a function (function Color_Table()
Any suggestions?
a hashmap?
OpenSCAD:
Color_Table =
Any suggestions?
Thu, Feb 12, 2026 12:54 AM
OpenSCAD proper does not have a hashmap() function and does not have
anything called a "hashmap". It does have objects, which are probably
similar:
Color_Table = object([ // the laser color parameters (name,power,feed,color)
I have no idea whether obejcts are integrated into PythonSCAD, or
whether PythonSCAD exports a hashmap() function into OpenSCAD.
similar:
John David
Thu, Feb 12, 2026 3:26 AM
I've used hashmaps with BOSL2 in the past, but thought hm was part of the
OpenSCAD primitives. That is why I tried it.
I just tried your object code, and it failed as well. I'll keep looking
for similar functionality that works for both code bases.
Thank you!
On Wed, Feb 11, 2026 at 7:54 PM Jordan Brown openscad@jordan.maileater.net
similar:
I have no idea whether obejcts are integrated into PythonSCAD, or whether
Thank you!
On Wed, Feb 11, 2026 at 7:54 PM Jordan Brown <openscad@jordan.maileater.net>
> similar:
JL
Jamie Larkby-Lahet
Thu, Feb 12, 2026 4:02 AM
Thank you!
similar:
you can use search() to treat a vector of key vaue pairs as a map. object()
is in the dev builds only at this time.
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Other_Language_Features#search
On Wed, Feb 11, 2026, 21:27 John David via Discuss <
> Thank you!
>> similar:
Thu, Feb 12, 2026 4:24 AM
looking for similar functionality that works for both code bases.
I have no idea whether it integrates with PythonSCAD.
It definitely works in OpenSCAD development snapshots, but it is
considered an "experimental" feature and so you must enable it using
Preferences/Features.
GS
Guenther Sohler
Thu, Feb 12, 2026 7:07 AM
In PythonSCAD you can leverage all features which comes with python,
So also hashes(python dicts)
This sample works:
hash.py:
def colorhash(key):
Color_Table ={
"L00": [1.0,1.0,0x000000],
"L01":[1.0,1.0,0x0000FF],
"L02":[1.0,1.0,0xFF0000],
"L29":[1.0,1.0,0xFFDB66],
"T1":[0.0,0.0,0xF36926],
"T2":[0.0,0.0,0x0C96D9]}
return Color_Table[key]
hash.scad:
use <hash.py>
echo(colorhash("L02"));
PythonSCAD aims to be 100% openscad compatible. so I has OpenSCAD objects,
but Python dicts are powerful anyway.
Look into hash.scad and see the ease how to export python functions ito
SCAD code.
Cheers
On Thu, Feb 12, 2026 at 1:54 AM Jordan Brown via Discuss <
similar:
This sample works:
hash.py:
def colorhash(key):
Color_Table ={
hash.scad:
use <hash.py>
SCAD code.
Cheers
> similar:
John David
Sat, Feb 14, 2026 5:36 AM
Sorry I did not see this before I spent a lot of time messing from the
OpenSCAD side today. I'll go back and give the python to openscad side a
try.
BTW, I got something similar to this working from pure OpenSCAD, but the
colorhash is immutable and I was planning to allow the user to be able to
set the power and feeds associated with the colormap.
Anyway, I'll give the python-first a try later.
EBo --
On Thu, Feb 12, 2026 at 2:07 AM Guenther Sohler via Discuss <
This sample works:
hash.py:
def colorhash(key):
Color_Table ={
hash.scad:
use <hash.py>
SCAD code.
Cheers
similar:
try.
EBo --
> This sample works:
> hash.py:
> def colorhash(key):
> Color_Table ={
> hash.scad:
> use <hash.py>
> SCAD code.
> Cheers
>> similar:
John David
Sat, Feb 14, 2026 5:37 AM
BTW, I am getting the error "
ERROR: File not trusted
'/home/ebo/.local/share/OpenSCAD/libraries/tabbed-box/colormap.py'
Any idea how to turn that off?
try.
EBo --
This sample works:
hash.py:
def colorhash(key):
Color_Table ={
hash.scad:
use <hash.py>
objects, but Python dicts are powerful anyway.
SCAD code.
Cheers
similar:
> try.
> EBo --
>> This sample works:
>> hash.py:
>> def colorhash(key):
>> Color_Table ={
>> hash.scad:
>> use <hash.py>
>> SCAD code.
>> Cheers
>>> similar:
GS
Guenther Sohler
Sat, Feb 14, 2026 5:46 AM
yes, of course,
just launch PythonSCAD with --trust-python
many folks actually install this option into the desktop symbol ...
try.
EBo --
This sample works:
hash.py:
def colorhash(key):
Color_Table ={
hash.scad:
use <hash.py>
SCAD code.
Cheers
similar:
yes, of course,
> Parsing design (AST generation)...
>> try.
>> EBo --
>>> This sample works:
>>> hash.py:
>>> def colorhash(key):
>>> Color_Table ={
>>> hash.scad:
>>> use <hash.py>
>>> SCAD code.
>>> Cheers
>>>> similar:
John David
Sat, Feb 14, 2026 5:48 AM
Figured it out. hash.py need "from openscad import *" to run. Now it does.
try.
EBo --
This sample works:
hash.py:
def colorhash(key):
Color_Table ={
hash.scad:
use <hash.py>
SCAD code.
Cheers
similar:
>> try.
>> EBo --
>>> This sample works:
>>> hash.py:
>>> def colorhash(key):
>>> Color_Table ={
>>> hash.scad:
>>> use <hash.py>
>>> SCAD code.
>>> Cheers
>>>> similar:
