assign()
Jerry Davis
Wed, Oct 28, 2015 2:01 AM
assign() has been deprecated, correct?
I have just noticed that the following MCAD files have assign in them.
fonts.scad:        for(i=[0:resolution-1])
assign(dx=widthcos(360i/resolution),dy=widthsin(360i/resolution))
involute_gears.scad: assign (
polyholes.scad:            assign(d = i + 0.5)
screw.scad:            assign (z = i*offset){
Jerry
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
- Isaac. Asimov
I
Anonymous
- Ken Thompson
assign() has been deprecated, correct? I have just noticed that the following MCAD files have assign in them. fonts.scad: for(i=[0:resolution-1]) assign(dx=width*cos(360*i/resolution),dy=width*sin(360*i/resolution)) involute_gears.scad: assign ( involute_gears.scad: assign ( involute_gears.scad: assign ( involute_gears.scad: assign ( polyholes.scad: assign(d = i + 0.5) screw.scad: assign (z = i*offset){ Jerry -- Extra Ham Operator: K7AZJ Registered Linux User: 275424 Raspberry Pi and Arduino developer *The most exciting phrase to hear in science - the one that heralds new discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov *I* *f you give someone a program, you will frustrate them for a day; if you teach them how to program, you will frustrate them for a lifetime. *- Anonymous *If writing good code requires very little comments, then writing really excellent code requires no comments at all!*- Ken Thompson
CL
Chow Loong Jin
Wed, Oct 28, 2015 4:50 AM
Yeah they're in need of cleanup in that aspect and in others as well. Work's
ongoing in the dev branch.
Kind regards,
Loong Jin
On Tue, Oct 27, 2015 at 07:01:27PM -0700, Jerry Davis wrote: > assign() has been deprecated, correct? > > I have just noticed that the following MCAD files have assign in them. > > fonts.scad: for(i=[0:resolution-1]) > assign(dx=width*cos(360*i/resolution),dy=width*sin(360*i/resolution)) > > involute_gears.scad: assign ( > > involute_gears.scad: assign ( > > involute_gears.scad: assign ( > > involute_gears.scad: assign ( > > polyholes.scad: assign(d = i + 0.5) > > screw.scad: assign (z = i*offset){ Yeah they're in need of cleanup in that aspect and in others as well. Work's ongoing in the dev branch. -- Kind regards, Loong Jin
Jerry Davis
Wed, Oct 28, 2015 1:55 PM
great. I am not privy to when the assign() statement will no longer be in a
future release.
I have found something in Thingiverse that I like. And it has assigns in
there. Is there a recommended method to get rid of the assign's?
(Just leave off the assign? like: assign(x=3) ==> x == 3? or what?
Jerry
- Isaac. Asimov
I
Anonymous
- Ken Thompson
Work's
Kind regards,
Loong Jin
great. I am not privy to when the assign() statement will no longer be in a future release. I have found something in Thingiverse that I like. And it has assigns in there. Is there a recommended method to get rid of the assign's? (Just leave off the assign? like: assign(x=3) ==> x == 3? or what? Jerry -- Extra Ham Operator: K7AZJ Registered Linux User: 275424 Raspberry Pi and Arduino developer *The most exciting phrase to hear in science - the one that heralds new discoveries - is not "Eureka!" but "That's funny...".*- Isaac. Asimov *I* *f you give someone a program, you will frustrate them for a day; if you teach them how to program, you will frustrate them for a lifetime. *- Anonymous *If writing good code requires very little comments, then writing really excellent code requires no comments at all!*- Ken Thompson On Tue, Oct 27, 2015 at 9:50 PM, Chow Loong Jin <hyperair@debian.org> wrote: > On Tue, Oct 27, 2015 at 07:01:27PM -0700, Jerry Davis wrote: > > assign() has been deprecated, correct? > > > > I have just noticed that the following MCAD files have assign in them. > > > > fonts.scad: for(i=[0:resolution-1]) > > assign(dx=width*cos(360*i/resolution),dy=width*sin(360*i/resolution)) > > > > involute_gears.scad: assign ( > > > > involute_gears.scad: assign ( > > > > involute_gears.scad: assign ( > > > > involute_gears.scad: assign ( > > > > polyholes.scad: assign(d = i + 0.5) > > > > screw.scad: assign (z = i*offset){ > > Yeah they're in need of cleanup in that aspect and in others as well. > Work's > ongoing in the dev branch. > > -- > Kind regards, > Loong Jin > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
CL
Chow Loong Jin
Thu, Oct 29, 2015 10:15 AM
future release.
This:
blah () {
assign (x = 3) {
something ();
becomes
blah () {
x = 3;
something ();
Kind regards,
Loong Jin
On Wed, Oct 28, 2015 at 06:55:43AM -0700, Jerry Davis wrote: > great. I am not privy to when the assign() statement will no longer be in a > future release. > > I have found something in Thingiverse that I like. And it has assigns in > there. Is there a recommended method to get rid of the assign's? > (Just leave off the assign? like: assign(x=3) ==> x == 3? or what? This: blah () { assign (x = 3) { something (); } } becomes blah () { x = 3; something (); } -- Kind regards, Loong Jin
