I finally got around to updating to the latest and greatest. We wait for a slow time to avoid nasty surprises when we are on deadline.
Very nice - especially “text”, which eliminates about half of my STL hacking. (we pause for polite giggling as this reveals how long it’s been since we upgraded).
But, on that topic - I have extensive needs to import fairly large STL files and either incorporate them into designs, or use OpenSCAD to do simple modifications (for example, carving away pieces). Alas, I believe that memory limitations are making this infeasible for many of the STL files I need to process. So, I end up writing a lot of ad hoc STL-modification programs (in Java, mostly) to do what I need. It’s not that difficult, but it’s tedious.
I would appreciate clues on how to MAXIMIZE the amount of memory available to OpenSCAD, and also some better diagnostics when OpenSCAD fails to open an STL file. All I see now is “could not open file”, when the file is perfectly well formatted, but perhaps large. Other programs open the file just fine. I’m assuming it’s a memory problem - but no error message tells me that. No reason is given, at all - simply “could not open”.
So:
a) how do I find our why an .stl file fails to open, and
b) if it is a memory issue, how do I maximize the amount of memory available
to OpenSCAD to use when opening .stl files?
Kenneth Sloan
KennethRSloan@gmail.com mailto:KennethRSloan@gmail.com
Vision is the art of seeing what is invisible to others.
Just opening the file (only import statement, nothing else) already
fails?
memory available to OpenSCAD to use when opening .stl files?
Without looking at the details, the only suggestion would be to
check if it's a 64 bit OpenSCAD running on a 64 bit System.
Can you share some specific example cases with all the files?
Yes - just :
import(“file.stl”, convexity=10);
fails
I’ll try to create a concrete example, and perhaps experiment to nail down whether or not it’s a size issue.
Since file size is an issue (potentially) - please send (privately) an e-mail address to receive instructions on fetching the files.
But…I’m on deadline for the next few days and don’t have a lot of time to spend working on this - sorry.
I’ll try…
Kenneth Sloan
fails?
