Issue with scaling, increase face count for accuracy
K
Katt
Fri, Apr 6, 2018 2:21 PM
Hi guys;
I am using the following code to generate an stl image.
//CODE START*****//
n=5;
//nverts control smoothing of the cad model
nverts=100;
//scales the x-coordinate
scalex=1;
//Compute the 'y' for a given x, n
function f(x)= pow(x,n)/ (pow(x,n)+pow((1-x),n)) + 0.5;
//Generate a symmetric model
verts=concat([for(i=[0:nverts-1]) [scalexi/nverts, f(i/nverts)]],
[for(i=[nverts-1:-1:0]) [scalex
i/nverts, -f(i/nverts)]] );
linear_extrude(height = 0.5){
//Join the vertices to form the required polygon
polygon(verts);
nverts1 = 100;
scalex1 = -2;
function f1(x)=0.5;
verts1=concat([for(i=[0:nverts1-1]) [scalex1i/nverts1, f1(i/nverts1)]],
[for(i=[nverts1-1:-1:0]) [scalex1
i/nverts1, -f1(i/nverts1)]] );
polygon(verts1);
nverts2 = 100;
scalex2 = 2.0;
function f2(x)=1.5;
verts2=concat([for(i=[0:nverts2-1]) [0.99+scalex2i/nverts2,
f2(i/nverts2)]], [for(i=[nverts2-1:-1:0]) [0.99+scalex2
i/nverts2,
-f2(i/nverts2)]] );
polygon(verts2);
//CODE END*****//
  1. The stl shall ideally be symmetric and looks symmetric but when I zoom
    close I see steps on one side but not on the other which means the stl is
    not really symmetric. Why is this so and how to make it accurate? You can
    see them at the curves.
  2. The scale is imprecise. That is, for example, "scalex1 and scalex2" are
    set to 2 (meaning the ends shall end at 1 and at 3) but they are only
    approximate? What is causing this imperfection.
    Because of this, I had to use a scaling number 0.99 instead of 1 in the
    following in the code adjusting segments else would disjoin the stl:
    i/nverts2,
    -f2(i/nverts2)]] );
  3. I would like to get a more precise geometry by probably increasing the
    number of faces of the stl model. Any idea how to do it?
    http://forum.openscad.org/file/t2047/fn.png
    I am interested in the normal vectors on these faces and I am guessing that
    they are approximate and not accurate enough. Any thoughts on this?
Thanks
Hi guys; I am using the following code to generate an stl image. //*******CODE START************// n=5; //nverts control smoothing of the cad model nverts=100; //scales the x-coordinate scalex=1; //Compute the 'y' for a given x, n function f(x)= pow(x,n)/ (pow(x,n)+pow((1-x),n)) + 0.5; //Generate a symmetric model verts=concat([for(i=[0:nverts-1]) [scalex*i/nverts, f(i/nverts)]], [for(i=[nverts-1:-1:0]) [scalex*i/nverts, -f(i/nverts)]] ); linear_extrude(height = 0.5){ //Join the vertices to form the required polygon polygon(verts); } nverts1 = 100; scalex1 = -2; function f1(x)=0.5; verts1=concat([for(i=[0:nverts1-1]) [scalex1*i/nverts1, f1(i/nverts1)]], [for(i=[nverts1-1:-1:0]) [scalex1*i/nverts1, -f1(i/nverts1)]] ); linear_extrude(height = 0.5){ polygon(verts1); } nverts2 = 100; scalex2 = 2.0; function f2(x)=1.5; verts2=concat([for(i=[0:nverts2-1]) [0.99+scalex2*i/nverts2, f2(i/nverts2)]], [for(i=[nverts2-1:-1:0]) [0.99+scalex2*i/nverts2, -f2(i/nverts2)]] ); linear_extrude(height = 0.5){ polygon(verts2); } //*******CODE END************// 1. The stl shall ideally be symmetric and looks symmetric but when I zoom close I see steps on one side but not on the other which means the stl is not really symmetric. Why is this so and how to make it accurate? You can see them at the curves. 2. The scale is imprecise. That is, for example, "scalex1 and scalex2" are set to 2 (meaning the ends shall end at 1 and at 3) but they are only approximate? What is causing this imperfection. Because of this, I had to use a scaling number 0.99 instead of 1 in the following in the code adjusting segments else would disjoin the stl: verts2=concat([for(i=[0:nverts2-1]) [*0.99*+scalex2*i/nverts2, f2(i/nverts2)]], [for(i=[nverts2-1:-1:0]) [*0.99*+scalex2*i/nverts2, -f2(i/nverts2)]] ); 3. I would like to get a more precise geometry by probably increasing the number of faces of the stl model. Any idea how to do it? <http://forum.openscad.org/file/t2047/fn.png> I am interested in the normal vectors on these faces and I am guessing that they are approximate and not accurate enough. Any thoughts on this? Thanks -- Sent from: http://forum.openscad.org/
Sat, Apr 7, 2018 5:19 AM
Interesting...I'll have to look deeper, but the non-symetricality goes away
with the latest snapshot v's with 2015.03-2. Try the snapshot  here
http://www.openscad.org/downloads.html#snapshots  .
For Q3, nverts=200; // etc works.
I'll have to think about Q2.
Interesting...I'll have to look deeper, but the non-symetricality goes away with the latest snapshot v's with 2015.03-2. Try the snapshot here <http://www.openscad.org/downloads.html#snapshots> . For Q3, nverts=200; // etc works. I'll have to think about Q2. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
Sat, Apr 7, 2018 6:24 AM
RE Q2, if you do echo(verts), you see that it goes from 0..0.99, so remove
the -1's and it goes 0..1.
RE Q2, if you do echo(verts), you see that it goes from 0..0.99, so remove the -1's and it goes 0..1. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
Sat, Apr 7, 2018 6:41 AM
Re the asymmetry, OpenSCAD 2015.03-2 had a bug with small numbers.
As you are working in that space, e.g. [0.06, 0.500001],[0.07,
0.500002],[0.08, 0.500005],[0.09, 0.500009], it was not able to consistently
deal with such small scales.
It is fixed in the snapshots.
Re the asymmetry, OpenSCAD 2015.03-2 had a bug with small numbers. As you are working in that space, e.g. [0.06, 0.500001],[0.07, 0.500002],[0.08, 0.500005],[0.09, 0.500009], it was not able to consistently deal with such small scales. It is fixed in the snapshots. ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
