Hi William,
I am trying to understand what you are doing.
Interfering means that either one of the cube or the file does not work ?
what's your seen behaviour ?
I am not used to path or file but I believe it should be the
current name of the script, but this does not exist.
The used python script in openscad is just a string and does not have a
filename(python does not know the path of your editor console)
Did you intend to write new content to the script file while you execute it
Cheers
On Wed, Sep 6, 2023 at 4:28 AM William F. Adams via Discuss <
To: OpenSCAD General Discussion discuss@lists.openscad.org
Cc:
Bcc:
Date: Wed, 6 Sep 2023 02:28:18 +0000 (UTC)
Subject: [OpenSCAD] Re: The nature of Python in OpenSCAD and future
plans/features
Experimenting a bit more, the following sort of worked:
import os
h = 1
w = 2
d = 3
fn = os.path.basename(name)
string = ("cube" + str(w) + str(d) + str(h))
f = open(fn, "a")
f.write(string)
cube([w,d,h]).output()
f.close()
but I'm still mystified as to why:
fn = os.path.basename(file)
didn't work.
From: "William F. Adams via Discuss" discuss@lists.openscad.org
Cc: "William F. Adams" willadams@aol.com
Bcc:
plans/features
Guenther Sohler guenther.sohler@gmail.com wrote:
Interfering means that either one of the cube or the file does not work ? >what's your seen behaviour ?
Execution en toto was blocked by the error.
I am not used to path or file but I believe it should >be the current name of the script, but this does not exist.
Correct, OIC.
The used python script in openscad is just a string and >does not have a filename(python does not know the path of your editor console)
Oh.
Did you intend to write new content to the script file while you execute it ?
Yes. I wanted to write out a file which has the same name, but a different file extension.
I'm looking at your other mail and will see what I can puzzle out.
