Re: [OpenSCAD] Version 2015.01.10 crashes during STL export
K
keithparker
Wed, Jan 14, 2015 10:49 PM
Apologies to all for repeating the topic... Same bug/symptom here.
Cheers
View this message in context: http://forum.openscad.org/Version-2015-01-10-crashes-during-STL-export-tp11014p11046.html
Apologies to all for repeating the topic... Same bug/symptom here. Cheers -- View this message in context: http://forum.openscad.org/Version-2015-01-10-crashes-during-STL-export-tp11014p11046.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Thu, Jan 15, 2015 5:20 AM
With the same design? If not, would you mind sharing it.
I’ve got a fix in the works, currently doing testing.
On Jan 14, 2015, at 17:49 PM, keithparker <crabltd@gmail.com> wrote: > Apologies to all for repeating the topic... Same bug/symptom here. > With the same design? If not, would you mind sharing it. I’ve got a fix in the works, currently doing testing. -Marius
K
keithparker
Sat, Jan 17, 2015 6:55 PM
I put the script in my Post: 'STL-output fail in 2015.01.13'
Cheers
View this message in context: http://forum.openscad.org/Version-2015-01-10-crashes-during-STL-export-tp11014p11068.html
I put the script in my Post: 'STL-output fail in 2015.01.13' Cheers -- View this message in context: http://forum.openscad.org/Version-2015-01-10-crashes-during-STL-export-tp11014p11068.html Sent from the OpenSCAD mailing list archive at Nabble.com.
