I'm currently helping a girls high school class to develop a bracelet
which is able to charge a battery by solar cells and give that energy to
a smartphone.
They asked me to do a 3d sketch to play with the design. Here is what I
have so far:
diameter=200;
width=40;
height=10;
roundness=4;
$fn=100;
color("DeepSkyBlue")
minkowski()
sphere(r=roundness);
hull()
cylinder(h=height / 2 - roundness, d=width / 2);
translate([diameter, 0, 0])
translate([diameter * 1 / 4, 0, 0])
cylinder(h=height - roundness, d=width);
translate([diameter * 3 / 4, 0, 0])
I would like to have the lenght of the bracelet the exact value of
"diameter", as well as the middle part should not be greater than
"width" and "height". I did a few experiments by subtracting from these
values but it is not easy to get a exact result. What should I do?
Bonus question: Besides that the bracelet will be printed flat with
NinjaFlex to be bendable, I would like to have it already bended in the
preview. How can I do that?
Regards
Blog: http://bastard-fdb.blogspot.de/
Gallery: http://gallery.port23.de/v/bastard/
Wiki: http://wiki.port23.de/wiki/Benutzer:Bastard
Stefan Krister schrieb am 06.05.2015 um 10:43:
a resize([length, width, height]) did it.
That was a challenge ...
Step by step in a for loop I sliced (via an intersection) the long
object and got many slices. Then I rotate each slice and transform it to
the right place along a circle.
At the end, I got this:
Regards
to
Not sure how that works and it sounds complicated. I admit the result
looks good, though....
I guess what would be really cool is to perform all modelling just like
you did in some other 3d parameter space, and then simply describe how
the 3d parameter space transforms into ordinary 3d cartesian space. In
this case the parameter space would be cylindrical...
Yes being able to curve 3D space would be useful.
you did in some other 3d parameter space, and then simply describe how the
3d parameter space transforms into ordinary 3d cartesian space. In this
Strong I feel the force within you is...
View this message in context: http://forum.openscad.org/minkowski-how-to-keep-exact-dimensions-tp12593p12608.html
Of course being able to arbitrarily curve 4D space - time would be even
better. I believe if you get it right using negative energy you can travel
backwards in time.
Public Domain; To the extent possible under law, I have waived all
copyright and related or neighbouring rights to this work. This work is
published globally via the internet. :) Inclusion of works of previous
authors is not included in the above.
On Thu, 7 May 2015 12:36:26 +0100
<grin/> +1
it to the right place along a circle.
result looks good, though....
like you did in some other 3d parameter space, and then simply
describe how the 3d parameter space transforms into ordinary 3d
cartesian space. In this case the parameter space would be
cylindrical...
Why do your people ask if someone's ready right before you are going to
do something massively unwise? -- Delenn - "The War without End"
gosh, that's beautiful! thank you for that!
yvette
Am 07.05.2015 um 18:05 schrieb Yvette S. Hirth, CCP, CDP:
I wonder, no one want's the code I wrote ...
Regards
