Hi there,
I reached to generate 6 characters among 26, but I can’t make it become a function or module…
here is my code
Vect_rand = rands (1,26,6);
echo (vect_rand);
List = ["A","B","C","D","E","F","G","H","I","J","K","L","M","N","O","P","Q","R","S","T","U","V","W","X","Y","Z"];
Vect_letters = 0;
for(i=[0:5]) {
//echo (i);
Nb_rand = (Vect_rand[i]);
echo (List[Nb_rand]);
//vect_letters[i]=liste[Nb_rand] ;
Works fine :-)
and
essai = aleatoire (param);
echo (essai);
module aleatoire (p1) {
vect_rand = rands (1,26,6);
Liste = ["A","B","C","D","E","F","G","H","I","J","K","L","M","N","O","P","Q","R","S","T","U","V","W","X","Y","Z"];
for(i=[0:5]) {
//echo (i);
nb_alea = (vect_rand[i]);
echo (liste[nb_alea]);
assign (param[i],Liste[nb_alea]);
//param[i]=Liste[nb_alea];
doesn’t work :-(
Anyone to help me please ?
Try this:
echo (vect_rand);
liste =
param = [ for(i=[0:5]) let( nb_alea = vect_rand[i]) liste[nb_alea] ];
echo(param);
param is built with a list comprehension. It could also be used in a
module, or a return value of a function.
On Tue, 3 Jan 2023 at 10:02, pulsar0952@hotmail.fr wrote:
Hi there,
function or module…
here is my code
echo (vect_rand);
List =
Vect_letters = 0;
for(i=[0:5]) {
//echo (i);
Works fine :-)
and
echo (essai);
Liste =
for(i=[0:5]) {
//echo (i);
doesn’t work :-(
nop head ,
Thank you very much. That’s great.
have a nice day! and happy new year ;-)
Note that the fundamental problems you were having are:
When setting variables, the ?: ternary operator and list comprehensions
are your friends.
Note that you will never generate the first character "A" with that code.
Also the array lookup is not necessary and can be replaced with usage of
ord and chr functions.
Here is a one-liner to do the same thing:
echo([ for(rnd=rands(0,26,6)) chr(ord("A")+rnd) ]);
On Tue, Jan 3, 2023 at 10:57 AM Jordan Brown openscad@jordan.maileater.net
- OpenSCAD variables are immutable. You can only create entire new
arrays, not modify a single entry in an array.
- OpenSCAD variables are limited to the scope they are created in. If
you create a variable inside the body of an "if" or "for", it is visible
only in that block - and for a "for", individually for each iteration.
are your friends.
thank you all for your advices
it works now !
