Cylinder in Hull crashes 2016.06.25 (Mac OS 10.9.5)
B
Benjamin
Wed, Jul 13, 2016 1:32 PM
Sorry if this has already been mentioned.
The example below works fine with 2016.03.26. It makes the latest
version quit on Preview and Render.
I've hesitated to attach the problem report, thinking that you might
prefer to reproduce it.
Benjamin
$fn=12;
hull() {
cylinder(r=1, h=6, center=true);
translate([6, 0, 0])
It can be reduced to:
hull() {
cylinder();
Hi, Sorry if this has already been mentioned. The example below works fine with 2016.03.26. It makes the latest version quit on Preview and Render. I've hesitated to attach the problem report, thinking that you might prefer to reproduce it. Benjamin //-------------------------------------------- $fn=12; hull() { cylinder(r=1, h=6, center=true); translate([6, 0, 0]) cylinder(r=1, h=6, center=true); } //-------------------------------------------- It can be reduced to: hull() { cylinder(); }
Wed, Jul 13, 2016 2:34 PM
Hi Benjamin,
Thanks for reporting; development snapshots do have the occasional weird behavior.
This does, however, work for me, so some more info would be very helpful.
I assume it actually crashes, not just quits. Are you able to find a crash log in the console (Console.app) ?
I suspect this to be related to running on a relatively old version of OS X. We do support 10.9, we just don’t have regular tests running in that environment. If you can provide a crash log, it would be easier for me to dig into it.
Benjamin
$fn=12;
hull() {
hull() {
cylinder();
Hi Benjamin, Thanks for reporting; development snapshots do have the occasional weird behavior. This does, however, work for me, so some more info would be very helpful. I assume it actually crashes, not just quits. Are you able to find a crash log in the console (Console.app) ? I suspect this to be related to running on a relatively old version of OS X. We do support 10.9, we just don’t have regular tests running in that environment. If you can provide a crash log, it would be easier for me to dig into it. -Marius > On Jul 13, 2016, at 09:32 AM, Benjamin <benjamin@chaaawa.com> wrote: > > Hi, > > Sorry if this has already been mentioned. > The example below works fine with 2016.03.26. It makes the latest version quit on Preview and Render. > I've hesitated to attach the problem report, thinking that you might prefer to reproduce it. > > Benjamin > > > //-------------------------------------------- > $fn=12; > > hull() { > cylinder(r=1, h=6, center=true); > translate([6, 0, 0]) > cylinder(r=1, h=6, center=true); > } > //-------------------------------------------- > > > > It can be reduced to: > hull() { > cylinder(); > } > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
B
Benjamin
Wed, Jul 13, 2016 3:35 PM
Thanks,
Here is the crash report (on Preview):
Process:        OpenSCAD [790]
Path: /Applications/_3D/OpenSCAD.app/Contents/MacOS/OpenSCAD
Identifier:      org.openscad.OpenSCAD
Version:        2016.06 (2016.06.25)
Code Type:      X86-64 (Native)
Parent Process:  launchd [165]
Responsible:    OpenSCAD [790]
User ID:        501
Date/Time:      2016-07-13 16:45:30.471 +0200
OS Version:      Mac OS X 10.9.5 (13F1808)
Report Version:  11
Anonymous UUID:  A066FB1C-D234-37EC-309A-414D8FE76CF8
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Exception Type:  EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0  libgmp.dylib                      0x0000000103814b5e __gmpn_mul_1 + 94
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0  libsystem_kernel.dylib            0x00007fff8e538662 kevent64 + 10
1  libdispatch.dylib                0x00007fff91ab6421
_dispatch_mgr_invoke + 239
2  libdispatch.dylib                0x00007fff91ab6136
_dispatch_mgr_thread + 52
Thread 2:
0  libsystem_kernel.dylib            0x00007fff8e537e6a
__workq_kernreturn + 10
1  libsystem_pthread.dylib          0x00007fff9527af08
_pthread_wqthread + 330
2  libsystem_pthread.dylib          0x00007fff9527dfb9 start_wqthread
  • 13
Thread 3:
  • 13
Thread 4:
  • 13
Thread 5:
  • 13
Thread 6:
0  libsystem_kernel.dylib            0x00007fff8e533a1a mach_msg_trap + 10
1  libsystem_kernel.dylib            0x00007fff8e532d18 mach_msg + 64
2  com.apple.CoreFoundation          0x00007fff8c624f15
__CFRunLoopServiceMachPort + 181
3  com.apple.CoreFoundation          0x00007fff8c624539 __CFRunLoopRun
  • 1161
    4  com.apple.CoreFoundation          0x00007fff8c623e75
    CFRunLoopRunSpecific + 309
    5  com.apple.AppKit                  0x00007fff96fd405e _NSEventThread
  • 144
    6  libsystem_pthread.dylib          0x00007fff95279899 _pthread_body +
    138
    7  libsystem_pthread.dylib          0x00007fff9527972a _pthread_start
  • 137
    8  libsystem_pthread.dylib          0x00007fff9527dfc9 thread_start + 13
Thread 7:: com.apple.NSURLConnectionLoader
  • 1161
    5  com.apple.Foundation              0x00007fff924acf87
    +[NSURLConnection(Loader) _resourceLoadLoop:] + 348
    6  com.apple.Foundation              0x00007fff924acd8b
    NSThread__main + 1318
    7  libsystem_pthread.dylib          0x00007fff95279899 _pthread_body +
    138
    8  libsystem_pthread.dylib          0x00007fff9527972a _pthread_start
  • 137
    9  libsystem_pthread.dylib          0x00007fff9527dfc9 thread_start + 13
Thread 8:: com.apple.CFSocket.private
0  libsystem_kernel.dylib            0x00007fff8e5379aa __select + 10
1  com.apple.CoreFoundation          0x00007fff8c670a03
__CFSocketManager + 867
2  libsystem_pthread.dylib          0x00007fff95279899 _pthread_body +
138
3  libsystem_pthread.dylib          0x00007fff9527972a _pthread_start
  • 137
    4  libsystem_pthread.dylib          0x00007fff9527dfc9 thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000608000202480  rbx: 0x00007fff5cc1ce28  rcx:
0x0000000000000001  rdx: 0x0000000000000001
rdi: 0x00007fff5cc1cba0  rsi: 0x0000608000016660  rbp:
0x0000000000000000  rsp: 0x00007fff5cc1caa0
r8: 0x0000000000000000  r9: 0x0000000000000001  r10:
0x0000000000000000  r11: 0x000000010380efb0
r12: 0x00007fff5cc1ce10  r13: 0x00007fff5cc1ce30  r14:
0x0000608000447230  r15: 0x00007fff5cc1cdf8
rip: 0x0000000103814b5e  rfl: 0x0000000000010246  cr2:
0x0000000103814b00
Logical CPU:    1
Error Code:      0x00000000
Trap Number:    6
Binary Images:
0x102fde000 -        0x1034f0ff7 +org.openscad.OpenSCAD (2016.06
  • 2016.06.25) <EB07A0F8-4DE3-3CA4-8B1B-5281999C987B>
    0x103700000 -        0x10371ffff +libCGAL.dylib (11.0.2)
<CABAD2E5-F0A9-3540-87CC-E235987AF0C0> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libCGAL.dylib 0x103733000 - 0x1037cbff7 +libmpfr.dylib (6.4) <4CCE9ACD-180C-343C-B202-CBD0C2454F5E> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libmpfr.dylib 0x1037df000 - 0x103889fff +libgmp.dylib (14.1) <044A4679-1C28-3A99-9BC2-5A5121E26749> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libgmp.dylib 0x103899000 - 0x1038a6fff +libopencsg.dylib (0) <F5128B49-A1B2-356D-8D69-17FE4E40C78A> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libopencsg.dylib 0x1038b5000 - 0x1038e2fff +libGLEW.dylib (1.13) <532CE477-AF4A-38E0-8B38-329C4A98DD24> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libGLEW.dylib 0x103919000 - 0x10392afff +libboost_thread.dylib (0) <B63A9489-CB04-3F21-A5B9-62B663E612CA> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libboost_thread.dylib 0x10393d000 - 0x10397bff7 +libboost_program_options.dylib (0) <0FB651AF-8C1C-34C0-8BD5-A08CA322A33E> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libboost_program_options.dylib
    0x1039b5000 -        0x1039c4fff +libboost_filesystem.dylib (0)
<90E15FCB-70F8-3A6D-AFC7-EF8451237494>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/libboost_filesystem.dylib
    0x1039d3000 -        0x1039d5fff +libboost_system.dylib (0)
<A1BC9918-CAF3-3E3B-AD8B-5374A2161186> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libboost_system.dylib 0x1039db000 - 0x103a7ffff +libboost_regex.dylib (0) <BA309DB2-3ADA-3A19-9327-E50FA07A1F67> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libboost_regex.dylib 0x103ad1000 - 0x103c4fff7 +libglib-2.0.dylib (4601.1) <86B9DF14-E583-3D9B-A62E-C8EF2F98D982> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libglib-2.0.dylib 0x103c7e000 - 0x103c8cff7 +libintl.dylib (11.4) <8589D050-5726-33EA-8586-CE9B0DBEC6CE> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libintl.dylib 0x103c91000 - 0x103c91ff9 +cl_kernels (???) <B1782CF9-FABA-4AB9-A82B-CFDEA267557F> cl_kernels 0x103c93000 - 0x103ccefff +org.sparkle-project.Sparkle (1.13.1 git-2afc553 - 1.13.1) <40414915-A48C-3DBB-AACB-5C20BAAE6DA6> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
    0x103d0b000 -        0x103de5ff7 +libharfbuzz.dylib (10201.7)
<9658620F-099D-36AD-A649-C4F3E38233EC>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/libharfbuzz.dylib
0x103e2e000 -        0x103f04fff +libfreetype.dylib (19.3)
<6A1A56D2-3879-389D-88E8-F95C48385F5F>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/libfreetype.dylib
0x103f20000 -        0x103f6cfff +libfontconfig.dylib (11.1)
<89F2C78C-E63A-3F81-A1E9-57F2E1157890>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/libfontconfig.dylib
0x103f7d000 -        0x103f7eff4 +cl_kernels (???)
<EB54DF94-E8B1-419A-9965-CD270EA43CF5> cl_kernels
0x103f80000 -        0x10414cfff +libqscintilla2.dylib (0)
<B88971DC-3C68-3CF8-B2A9-AF8C279A39DE>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/libqscintilla2.dylib
0x1041cb000 -        0x1041feff7 +org.qt-project.QtPrintSupport
(5.7 - 5.7.0) <67BB0DB0-88B2-3802-92D5-7B326C90AFB0>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport
    0x104229000 -        0x104722ff7 +org.qt-project.QtWidgets (5.7
  • 5.7.0) <E1338AA1-EDCE-3904-B764-D5CC1FB2F8FC>
    /Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
      0x104909000 -        0x104d09ff7 +org.qt-project.QtGui (5.7 -
5.7.0) <65053079-A2E1-3D59-AE88-BEB242E05C97>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
    0x104e4a000 -        0x10535eff7 +org.qt-project.QtCore (5.7 -
5.7.0) <91296610-5A00-30F7-9663-DDF7738C31FF>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
    0x10547b000 -        0x105484ff7 +org.qt-project.QtMacExtras
(5.7 - 5.7.0) <8B3C4F7B-C98D-3A29-9858-DAF34F58768B>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtMacExtras.framework/Versions/5/QtMacExtras
    0x105491000 -        0x105495ff7 +org.qt-project.QtConcurrent
(5.7 - 5.7.0) <AB461D07-E24C-3894-9E0C-DC3B8FCAFCC4>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtConcurrent.framework/Versions/5/QtConcurrent
    0x10549f000 -        0x1054a3fff  com.apple.agl (3.2.3 -
AGL-3.2.3) <21798BC5-8F01-345B-B27B-1037CF71D166>
/System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x1054ac000 -        0x1054aeff7 +libboost_chrono.dylib (0)
<19702DF9-27BD-3562-A001-373C70F97F25>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/libboost_chrono.dylib
0x1054b8000 -        0x10567eff7 +libxml2.dylib (12.4)
<21E63B2A-51D4-3705-A9CE-077D74534E16>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/libxml2.dylib
0x106f79000 -        0x1070eafff +libqcocoa.dylib (0)
<56AF80F9-6AAF-3A4E-97F4-109614288A77>
/Applications/_3D/OpenSCAD.app/Contents/PlugIns/platforms/libqcocoa.dylib
0x107160000 -        0x1071c7ff7 +org.qt-project.QtDBus (5.7 -
5.7.0) <A3B1C34A-7EBC-36D6-B053-9CEE4A3D14CE>
/Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtDBus.framework/Versions/5/QtDBus
    0x10752a000 -        0x107534ff7 +libqdds.dylib (0)
<C030C6EC-3611-3A8D-894F-071C96FB3031> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqdds.dylib 0x107539000 - 0x107540ff7 +libqgif.dylib (0) <551D6575-9920-346E-BE76-3A835199CC08> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqgif.dylib 0x107545000 - 0x10754dfff +libqicns.dylib (0) <72F60B35-25FC-3478-A86D-6CC786A508C2> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqicns.dylib 0x109ae5000 - 0x109aebfff +libqico.dylib (0) <159201A7-AB7A-3174-A3F7-E3954A138C8F> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqico.dylib 0x109af0000 - 0x109b83fff +libqjp2.dylib (0) <E3D63E91-718B-3FF9-8212-FA33DB4B459D> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqjp2.dylib 0x109b9b000 - 0x109bdafff +libqjpeg.dylib (0) <38A4D43B-CDF7-3867-95B6-C51AFCAFB512> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqjpeg.dylib 0x109be4000 - 0x109c36ff7 +libqmng.dylib (0) <E168CE5A-1CC1-3587-9641-7DD2C9F13D74> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqmng.dylib 0x109c47000 - 0x109c4bff7 +libqtga.dylib (0) <576CF0ED-6C64-32C7-99BB-6468A1080D9F> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqtga.dylib 0x109c50000 - 0x109cb4fff +libqtiff.dylib (0) <F086BC43-2567-3B23-B0FA-D458999803BB> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqtiff.dylib 0x109cc2000 - 0x109cc6ff7 +libqwbmp.dylib (0) <9F5B0F44-0AF1-300C-88D2-7C2EE2C8F309> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqwbmp.dylib 0x109ccb000 - 0x109d45fff +libqwebp.dylib (0) <E401A034-2209-3102-BA10-9E7F67BEA588> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqwebp.dylib 0x10a366000 - 0x10a36aff9 libFontRegistryUI.dylib (127.0.1) <80D54383-4576-3B3D-93BD-8C5C861819C6> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib 0x10a371000 - 0x10a37cfff libGPUSupport.dylib (9.6.5) <7262B5E5-AA02-3916-9E78-071502F4F1BE> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib 0x10a804000 - 0x10a8eafef unorm8_bgra.dylib (2.3.58) <A975133F-2E73-3DAF-A08F-B3CC7E9E10CE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib 0x10a92c000 - 0x10b076ff7 libclh.dylib (4.0.3 - 4.0.3) <8D8CFC19-2C05-3D15-A76A-3F390DC03346> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/libclh.dylib 0x10db72000 - 0x10dbe9ff7 com.apple.xquery (1.3.1 - 30) <2F2DC0D6-456F-33A0-8537-E0C651F6817C> /System/Library/PrivateFrameworks/XQuery.framework/XQuery 0x123440000000 - 0x12344086dfff com.apple.GeForceTeslaGLDriver (8.24.17 - 8.2.4) <C7C202BA-F674-3190-8CC1-62738301149C> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/GeForceTeslaGLDriver 0x7fff63c6f000 - 0x7fff63ca2887 dyld (239.5) <1D3130FE-FE7E-3C4C-8E74-EB51895B6BA5> /usr/lib/dyld 0x7fff8ba35000 - 0x7fff8ba38ff7 libdyld.dylib (239.5) <CAE7A50D-F156-3D47-81C0-DC41EB975D38> /usr/lib/system/libdyld.dylib 0x7fff8ba39000 - 0x7fff8ba3dfff libpam.2.dylib (20) <B93CE8F5-DAA8-30A1-B1F6-F890509513CB> /usr/lib/libpam.2.dylib 0x7fff8bc02000 - 0x7fff8bc04fff libRadiance.dylib (1048) <5D66AE6D-1B0B-33CC-91F0-D93AE7016C7B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x7fff8bd4f000 - 0x7fff8bd55fff com.apple.AOSNotification (1.7.0 - 760.4) <8F042A51-E0A9-37E6-A601-0DD6A58A0AC8> /System/Library/PrivateFrameworks/AOSNotification.framework/Versions/A/AOSNotification 0x7fff8bf94000 - 0x7fff8bfbdfff GLRendererFloat (9.6.5) <D216C628-95EC-346C-A4EE-C88A750ADF5F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat 0x7fff8c05c000 - 0x7fff8c0c1ffb com.apple.Heimdal (4.0 - 2.0) <C28DBCAE-01AC-363A-9046-3BD33F225526> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x7fff8c587000 - 0x7fff8c5b3fff com.apple.CoreServicesInternal (184.9 - 184.9) <4DEA54F9-81D6-3EDB-AA3C-1F9C497B3379> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal 0x7fff8c5b4000 - 0x7fff8c799fff com.apple.CoreFoundation (6.9 - 855.17) <729BD6DA-1F63-3E72-A148-26F21EBF52BB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff8c79a000 - 0x7fff8ca6bffc com.apple.CoreImage (9.4.1) <7B28C3F3-8EB3-3150-A55D-EBCDBDCA4977> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage 0x7fff8ca6c000 - 0x7fff8ca93ff7 libsystem_network.dylib (241.4) <0D630D53-C772-3EC5-8257-EFB0ACCE3153> /usr/lib/system/libsystem_network.dylib 0x7fff8cd63000 - 0x7fff8cd8bffb libxslt.1.dylib (13.10) <367D404A-6065-3A8D-A94A-4838F9F9DB4A> /usr/lib/libxslt.1.dylib 0x7fff8cd8f000 - 0x7fff8cd98ffb libsystem_notify.dylib (121.20.1) <9B34B4FE-F5AD-3F09-A5F0-46AFF3571323> /usr/lib/system/libsystem_notify.dylib 0x7fff8cd99000 - 0x7fff8ce7dff7 com.apple.coreui (2.2 - 231.1) <187DF89C-8A64-366D-8782-F90315FA3CD7> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x7fff8ce7e000 - 0x7fff8ceaefff com.apple.IconServices (25 - 25.17) <4751127E-FBD5-3ED5-8510-08D4E4166EFE> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices 0x7fff8cfcf000 - 0x7fff8d17cf27 libobjc.A.dylib (551.1) <AD7FD984-271E-30F4-A361-6B20319EC73B> /usr/lib/libobjc.A.dylib 0x7fff8d186000 - 0x7fff8d186fff com.apple.ApplicationServices (48 - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x7fff8d20b000 - 0x7fff8d214ff7 libcldcpuengine.dylib (2.3.58) <4433A688-94CA-3EE0-BE5B-D982C14EF6DB> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib 0x7fff8d215000 - 0x7fff8d218ffa libCGXType.A.dylib (599.35.13) <7427D788-DC44-303C-AD7C-F92F04C8D9F0> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib 0x7fff8d219000 - 0x7fff8d461ff7 com.apple.CoreData (107 - 481.3) <E78734AA-E3D0-33CB-A014-620BBCAB2E96> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fff8d72a000 - 0x7fff8d745ff7 libCRFSuite.dylib (34) <FFAE75FA-C54E-398B-AA97-18164CD9789D> /usr/lib/libCRFSuite.dylib 0x7fff8d75d000 - 0x7fff8d8f8ff8 com.apple.CFNetwork (673.6 - 673.6) <CAA196FE-BF5A-384F-975E-E0F81359805B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff8d8f9000 - 0x7fff8d90bff7 com.apple.MultitouchSupport.framework (245.13.1 - 245.13.1) <38262B92-C63F-35A0-997D-AD2EBF2F8338> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x7fff8d90c000 - 0x7fff8d916ff7 com.apple.bsd.ServiceManagement (2.0 - 2.0) <2D27B498-BB9C-3D88-B05A-76908A8A26F3> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x7fff8d917000 - 0x7fff8d940ff7 libc++abi.dylib (49.1) <21A807D3-6732-3455-B77F-743E9F916DF0> /usr/lib/libc++abi.dylib 0x7fff8d996000 - 0x7fff8da58ffd com.apple.CoreText (367.23 - 367.23) <C799261E-2E19-3D69-8A8D-098B7DD8D31D> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x7fff8da59000 - 0x7fff8dadafff com.apple.CoreSymbolication (3.0.1 - 141.0.6) <D46DE002-1FEB-38B7-8583-3DF3496274F5> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0x7fff8db26000 - 0x7fff8db2aff7 libheimdal-asn1.dylib (323.92.2) <979AEAA0-59B3-3E99-94B1-9BB9C6C45273> /usr/lib/libheimdal-asn1.dylib 0x7fff8db2b000 - 0x7fff8db70fff libcurl.4.dylib (78.94.1) <88F27F9B-052E-3375-938D-2603E90D8AD5> /usr/lib/libcurl.4.dylib 0x7fff8db71000 - 0x7fff8db8cff7 libPng.dylib (1048) <C14F8741-9F67-32DA-896A-F873705B3EC6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x7fff8dba1000 - 0x7fff8dbbaff7 com.apple.Kerberos (3.0 - 1) <F108AFEB-198A-3BAF-BCA5-9DFCE55EFF92> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x7fff8e011000 - 0x7fff8e03afff com.apple.DictionaryServices (1.2 - 208) <A539A058-BA57-35EE-AA08-D0B0E835127D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x7fff8e444000 - 0x7fff8e44bfff libcompiler_rt.dylib (35) <4CD916B2-1B17-362A-B403-EF24A1DAC141> /usr/lib/system/libcompiler_rt.dylib 0x7fff8e44c000 - 0x7fff8e517fff libvDSP.dylib (423.32) <3BF732BE-DDE0-38EB-8C54-E4E3C64F77A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x7fff8e522000 - 0x7fff8e53eff7 libsystem_kernel.dylib (2422.115.15) <34ABAF79-E147-3C34-B05D-46A566E689CC> /usr/lib/system/libsystem_kernel.dylib 0x7fff8e751000 - 0x7fff8e9fbff5 com.apple.HIToolbox (2.1.1 - 698) <26FF0E2C-1CD7-311F-ACF0-84F3D5273AD6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff8e9fc000 - 0x7fff8ea69ff1 com.apple.ApplicationServices.ATS (360 - 363.6) <828C2711-4577-3F75-B436-3BDF328DFB11> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x7fff8ea6a000 - 0x7fff8ea6eff7 libsystem_stats.dylib (93.90.3) <2304C7C2-BE45-35DE-BCC6-707D61B7AE7E> /usr/lib/system/libsystem_stats.dylib 0x7fff8ea6f000 - 0x7fff8ea7cff4 com.apple.Librarian (1.2 - 1) <F1A2744D-8536-32C7-8218-9972C6300DAE> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian 0x7fff8eaa4000 - 0x7fff8eb95ff9 libiconv.2.dylib (41) <BB44B115-AC32-3877-A0ED-AEC6232A4563> /usr/lib/libiconv.2.dylib 0x7fff8eb96000 - 0x7fff8ec26ff7 com.apple.Metadata (10.7.0 - 800.30) <E107CE36-FBC3-35A5-84E0-864B4178FC5D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x7fff8ec27000 - 0x7fff8ec68fff com.apple.PerformanceAnalysis (1.47 - 47) <95435F84-C251-3C48-B6CD-9EE7A63D6E26> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis 0x7fff8ec9f000 - 0x7fff8eca0fff libsystem_sandbox.dylib (278.11.2) <0C93EB23-7364-3670-B511-212A7A524695> /usr/lib/system/libsystem_sandbox.dylib 0x7fff8eca1000 - 0x7fff8ecdaff7 com.apple.QD (3.50 - 298) <C1F20764-DEF0-34CF-B3AB-AB5480D64E66> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x7fff8ed62000 - 0x7fff8ee33ff1 com.apple.DiskImagesFramework (10.9.6 - 373) <4EA5A3C8-13E2-309C-8FAB-C21A4C316802> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages 0x7fff8eee8000 - 0x7fff8f25fff6 com.apple.JavaScriptCore (9537 - 9537.78.1) <8623A109-9E9D-3E3B-A8E1-6EE447C0110C> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fff8f260000 - 0x7fff8f34efff libJP2.dylib (1048) <19B37CB6-C864-3830-87FE-BB53F8542FB0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x7fff8f34f000 - 0x7fff8f37efd2 libsystem_m.dylib (3047.16) <B7F0E2E4-2777-33FC-A787-D6430B630D54> /usr/lib/system/libsystem_m.dylib 0x7fff8f37f000 - 0x7fff8f38ffff libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib 0x7fff8f3a3000 - 0x7fff8f3a6fff com.apple.TCC (1.0 - 1) <32A075D9-47FD-3E71-95BC-BFB0D583F41C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0x7fff8f3a7000 - 0x7fff8f471ff7 com.apple.LaunchServices (572.32 - 572.32) <A4699DED-5101-3068-94F8-8D0B7A84BC79> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fff8f472000 - 0x7fff8f47cff7 libcsfde.dylib (380.70.2) <3ACB87D7-A81C-3C45-B648-AD27F1B9D841> /usr/lib/libcsfde.dylib 0x7fff8f5c5000 - 0x7fff8f5ccffb libcopyfile.dylib (103.92.1) <CF29DFF6-0589-3590-834C-82E2316612E8> /usr/lib/system/libcopyfile.dylib 0x7fff8f615000 - 0x7fff8f616fff libunc.dylib (28) <62682455-1862-36FE-8A04-7A6B91256438> /usr/lib/system/libunc.dylib 0x7fff8f67e000 - 0x7fff8f680ff3 libsystem_configuration.dylib (596.15) <4998CB6A-9D54-390A-9F57-5D1AC53C135C> /usr/lib/system/libsystem_configuration.dylib 0x7fff8f681000 - 0x7fff8f955fc7 com.apple.vImage (7.0 - 7.0) <D241DBFA-AC49-31E2-893D-EAAC31890C90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x7fff8f963000 - 0x7fff8f998ffc com.apple.LDAPFramework (2.4.28 - 194.5) <5E501783-06E8-390C-AF34-A7FAD402F3E6> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP 0x7fff9029c000 - 0x7fff9029efff libCVMSPluginSupport.dylib (9.6.5) <9DE29AD9-5F59-3B9B-899C-4DED190CB817> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x7fff9029f000 - 0x7fff903a6ff7 com.apple.ImageIO.framework (3.3.0 - 1048) <FDFAFDEA-3559-330F-9578-40F4F62F51B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x7fff903a7000 - 0x7fff903ccff7 com.apple.CoreVideo (1.8 - 117.2) <4674339E-26D0-35FA-9958-422832B39B12> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff90462000 - 0x7fff904a0ff7 libGLImage.dylib (9.6.5) <C242B319-6F4B-3FB3-8FCE-0B77424F0BED> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x7fff904a1000 - 0x7fff912f5ff7 com.apple.WebCore (9537 - 9537.78.1) <56C3D4BF-2495-3FD2-8212-91AF7DF693B8> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore 0x7fff912f6000 - 0x7fff91305ff8 com.apple.LangAnalysis (1.7.0 - 1.7.0) <8FE131B6-1180-3892-98F5-C9C9B79072D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x7fff91312000 - 0x7fff91351fff libGLU.dylib (9.6.5) <7463B411-2DB0-3338-BC8D-403293E2CA34> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x7fff91352000 - 0x7fff91359fff com.apple.NetFS (6.0 - 4.0) <8E26C099-CE9D-3819-91A2-64EA929C6137> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fff91389000 - 0x7fff9139aff7 libz.1.dylib (53) <42E0C8C6-CA38-3CA4-8619-D24ED5DD492E> /usr/lib/libz.1.dylib 0x7fff9139b000 - 0x7fff913e9ff7 com.apple.opencl (2.3.59 - 2.3.59) <E37E2219-6EA7-3666-8DB5-8FC60EFB0BC9> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x7fff9141b000 - 0x7fff9146cff7 com.apple.audio.CoreAudio (4.2.1 - 4.2.1) <07F2B103-AE29-3118-BBC4-9A72E13B013B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fff9146d000 - 0x7fff914f6fff libsystem_c.dylib (997.90.4) <EA812F03-8AD2-3776-AD50-6BEBC90F1F5F> /usr/lib/system/libsystem_c.dylib 0x7fff914fb000 - 0x7fff91533ff7 com.apple.RemoteViewServices (2.0 - 94) <3F34D630-3DDB-3411-BC28-A56A9B55EBDA> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices 0x7fff91534000 - 0x7fff9153dfff com.apple.speech.synthesis.framework (4.7.1 - 4.7.1) <383FB557-E88E-3239-82B8-15F9F885B702> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x7fff9153e000 - 0x7fff9156dff9 com.apple.GSS (4.0 - 2.0) <27FCA2B4-0767-3002-8755-862B19B5CF92> /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x7fff916b0000 - 0x7fff916f2ff7 libauto.dylib (185.5) <F45C36E8-B606-3886-B5B1-B6745E757CA8> /usr/lib/libauto.dylib 0x7fff916f3000 - 0x7fff919ddfff com.apple.CoreServices.CarbonCore (1077.17 - 1077.17) <3A2E92FD-DEE2-3D45-9619-11500801A61C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x7fff919eb000 - 0x7fff919ecff7 libDiagnosticMessagesClient.dylib (100) <4CDB0F7B-C0AF-3424-BC39-495696F0DB1E> /usr/lib/libDiagnosticMessagesClient.dylib 0x7fff919ed000 - 0x7fff91a51fff com.apple.datadetectorscore (5.0 - 354.5) <D4DBCCF4-9622-3AB9-9076-32579FCC2E39> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore 0x7fff91a52000 - 0x7fff91a6dff7 libsystem_malloc.dylib (23.10.1) <A695B4E4-38E9-332E-A772-29D31E3F1385> /usr/lib/system/libsystem_malloc.dylib 0x7fff91ab3000 - 0x7fff91acdfff libdispatch.dylib (339.92.1) <C4E4A18D-3C3B-3C9C-8709-A4270D998DE7> /usr/lib/system/libdispatch.dylib 0x7fff91ace000 - 0x7fff91ad3ff7 libunwind.dylib (35.3) <78DCC358-2FC1-302E-B395-0155B47CB547> /usr/lib/system/libunwind.dylib 0x7fff91ad7000 - 0x7fff91b8fff7 com.apple.DiscRecording (8.0 - 8000.4.6) <CDAAAD04-A1D0-3C67-ABCC-EFC9E8D44E7E> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording 0x7fff922e0000 - 0x7fff922e6ff7 libsystem_platform.dylib (24.90.1) <3C3D3DA8-32B9-3243-98EC-D89B9A1670B3> /usr/lib/system/libsystem_platform.dylib 0x7fff9230a000 - 0x7fff9230ffff com.apple.DiskArbitration (2.6 - 2.6) <A4165553-770E-3D27-B217-01FC1F852B87> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x7fff923e5000 - 0x7fff92437fff libc++.1.dylib (120) <4F68DFC5-2077-39A8-A449-CAC5FDEE7BDE> /usr/lib/libc++.1.dylib 0x7fff92438000 - 0x7fff92445fff com.apple.Sharing (132.2 - 132.2) <F983394A-226D-3244-B511-FA51FDB6ADDA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing 0x7fff92446000 - 0x7fff92746ff7 com.apple.Foundation (6.9 - 1056.17) <E0B0FAF6-5CA8-3EEB-8BF2-104C0AEEF925> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff92790000 - 0x7fff92930ff7 GLEngine (9.6.5) <30643C97-7EBB-36EE-BEEA-13844EA0F680> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine 0x7fff929b5000 - 0x7fff929ddffb libRIP.A.dylib (599.35.13) <944F001B-C045-3784-8720-38D6F1272845> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib 0x7fff92a56000 - 0x7fff92a59fff com.apple.help (1.3.3 - 46) <AE763646-D07A-3F9A-ACD4-F5CBD734EE36> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x7fff92a67000 - 0x7fff92bcdfff libGLProgrammability.dylib (9.6.5) <53BCF254-3014-33DC-94EF-72C7270F14F2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x7fff92bce000 - 0x7fff92bf5ffb libsystem_info.dylib (449.1.4) <12CD9E42-8CEE-3A8D-B006-F8A6EB98804D> /usr/lib/system/libsystem_info.dylib 0x7fff92bf6000 - 0x7fff92c06ffb libsasl2.2.dylib (170) <C8E25710-68B6-368A-BF3E-48EC7273177B> /usr/lib/libsasl2.2.dylib 0x7fff92c55000 - 0x7fff92df1ff3 com.apple.QuartzCore (1.8 - 332.4) <CFB972D1-FA37-380C-9A47-2A67A84B7442> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x7fff92df8000 - 0x7fff92df9ffb libremovefile.dylib (33) <3543F917-928E-3DB2-A2F4-7AB73B4970EF> /usr/lib/system/libremovefile.dylib 0x7fff92f57000 - 0x7fff9308dff5 com.apple.WebKit (9537 - 9537.78.2) <EB8D3D78-92E7-3B67-8AAF-B51A181461E0> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit 0x7fff93144000 - 0x7fff9319dff7 libTIFF.dylib (1048) <923096A6-02CC-311D-9596-1961430C0EF7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x7fff9319e000 - 0x7fff93211fff com.apple.securityfoundation (6.0 - 55122.3) <0AFCF575-97C3-3458-A72E-39DA07804EB9> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x7fff93212000 - 0x7fff9327ffff com.apple.SearchKit (1.4.0 - 1.4.0) <B9B8D510-A27E-36B0-93E9-17146D9E9045> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x7fff93286000 - 0x7fff93287fff liblangid.dylib (117) <9546E641-F730-3AB0-B3CD-E0E2FDD173D9> /usr/lib/liblangid.dylib 0x7fff9340a000 - 0x7fff9342efff libxpc.dylib (300.90.2) <AB40CD57-F454-3FD4-B415-63B3C0D5C624> /usr/lib/system/libxpc.dylib 0x7fff9342f000 - 0x7fff9342ffff com.apple.Accelerate (1.9 - Accelerate 1.9) <509BB27A-AE62-366D-86D8-0B06D217CF56> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x7fff93430000 - 0x7fff934b9fff com.apple.ColorSync (4.9.0 - 4.9.0) <B756B908-9AD1-3F5D-83F9-7A0B068387D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x7fff93566000 - 0x7fff93570ff7 com.apple.CrashReporterSupport (10.9 - 539) <B25A09EC-A021-32EC-86F8-05B4837E0EDE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport 0x7fff93571000 - 0x7fff93571fff com.apple.Carbon (154 - 157) <EFC1A1C0-CB07-395A-B038-CFA2E71D3E69> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x7fff93572000 - 0x7fff93574fff com.apple.EFILogin (2.0 - 2) <8D651894-B7AD-3F23-9B93-472EEA3D292F> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin 0x7fff93575000 - 0x7fff93587fff com.apple.ImageCapture (9.0 - 9.0) <BE0B65DA-3031-359B-8BBA-B9803D4ADBF4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x7fff93588000 - 0x7fff9358cfff com.apple.CommonPanels (1.2.6 - 96) <6B434AFD-50F8-37C7-9A56-162C17E375B3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x7fff938d1000 - 0x7fff938deff7 libxar.1.dylib (202) <5572AA71-E98D-3FE1-9402-BB4A84E0E71E> /usr/lib/libxar.1.dylib 0x7fff93e0c000 - 0x7fff93e0effb libutil.dylib (34) <DAC4A6CF-A1BB-3874-9569-A919316D30E8> /usr/lib/libutil.dylib 0x7fff93ea6000 - 0x7fff93ea6ff7 libkeymgr.dylib (28) <3AA8D85D-CF00-3BD3-A5A0-E28E1A32A6D8> /usr/lib/system/libkeymgr.dylib 0x7fff93ea7000 - 0x7fff93eb0ffd com.apple.CommonAuth (4.0 - 2.0) <BD720379-757B-305C-A7BE-E00E680F8218> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x7fff93eb1000 - 0x7fff93eb1fff com.apple.Cocoa (6.8 - 20) <E90E99D7-A425-3301-A025-D9E0CD11918E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x7fff9424b000 - 0x7fff94286fff com.apple.bom (14.0 - 193.1) <EF24A562-6D3C-379E-8B9B-FAE0E4A0EF7C> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom 0x7fff94287000 - 0x7fff94288ff7 libSystem.B.dylib (1197.1.1) <F727296D-D066-31BD-A9F9-5CAA1BD7A6A7> /usr/lib/libSystem.B.dylib 0x7fff942df000 - 0x7fff942edfff com.apple.opengl (9.6.5 - 9.6.5) <4FAEADD8-EEB3-3FD9-ADC6-BA65806228CC> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x7fff9430c000 - 0x7fff94c3512b com.apple.CoreGraphics (1.600.0 - 599.35.13) <142EF2C9-6B8F-3ACB-9C46-B20628DFE134> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x7fff94c36000 - 0x7fff94c3eff7 com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <98BBB3E4-6239-3EF1-90B2-84EA0D3B8D61> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x7fff94c3f000 - 0x7fff94c44fff libmacho.dylib (845) <1D2910DF-C036-3A82-A3FD-44FF73B5FF9B> /usr/lib/system/libmacho.dylib 0x7fff94cd5000 - 0x7fff94cddffc libGFXShared.dylib (9.6.5) <FCCD0CD3-02FD-3A79-B048-A14745D76CC8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x7fff95118000 - 0x7fff95120ff3 libCGCMS.A.dylib (599.35.13) <2B9BCBE1-4376-374E-B5C1-75672854B5D8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib 0x7fff9516d000 - 0x7fff95179ff7 com.apple.OpenDirectory (10.9 - 173.90.1) <383F96FF-1DF3-37E8-8540-03A697C873F6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x7fff9517a000 - 0x7fff95262ff7 libxml2.2.dylib (26.8) <75424553-B02C-37FB-BCDD-19A288D3F306> /usr/lib/libxml2.2.dylib 0x7fff95263000 - 0x7fff95267ff7 libcache.dylib (62) <BDC1E65B-72A1-3DA3-A57C-B23159CAAD0B> /usr/lib/system/libcache.dylib 0x7fff95268000 - 0x7fff9526bfff libCoreVMClient.dylib (58.1) <EBC36C69-C896-3C3D-8589-3E9023E7E56F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x7fff9526c000 - 0x7fff95277fff libGL.dylib (9.6.5) <A5F36623-33E8-379D-A423-8F873018CD79> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x7fff95278000 - 0x7fff9527fff7 libsystem_pthread.dylib (53.1.4) <AB498556-B555-310E-9041-F67EC9E00E2C> /usr/lib/system/libsystem_pthread.dylib 0x7fff95280000 - 0x7fff9536afff libsqlite3.dylib (158) <00269BF9-43BE-39E0-9C85-24585B9923C8> /usr/lib/libsqlite3.dylib 0x7fff953eb000 - 0x7fff953ebfff com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <F8D0CC77-98AC-3B58-9FE6-0C25421827B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x7fff9552f000 - 0x7fff95576ffb libFontRegistry.dylib (127.0.1) <F267F500-6E4A-3BE3-97C1-08AAA649E02E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x7fff955cd000 - 0x7fff95625ff7 com.apple.Symbolication (1.4 - 129.0.2) <3DCCAB8A-6FA1-3BB9-B4D3-A3CBDB3BDF04> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication 0x7fff95665000 - 0x7fff956b3fff libcorecrypto.dylib (161.1) <F3973C28-14B6-3006-BB2B-00DD7F09ABC7> /usr/lib/system/libcorecrypto.dylib 0x7fff95a7d000 - 0x7fff95ad8ffb com.apple.AE (665.5 - 665.6) <9B17E7B7-D493-346A-827E-6DF1474E4977> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x7fff95af0000 - 0x7fff95b43fff com.apple.ScalableUserInterface (1.0 - 1) <CF745298-7373-38D2-B3B1-727D5A569E48> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface 0x7fff95b44000 - 0x7fff95cfcffb libicucore.A.dylib (511.36) <9AAC5980-2C1F-3B86-8A16-DB533F5E7C84> /usr/lib/libicucore.A.dylib 0x7fff95d02000 - 0x7fff95d8dff7 libCoreStorage.dylib (380.70.2) <BD993BC8-ED54-3DC1-B28B-3B6AC77E8E5C> /usr/lib/libCoreStorage.dylib 0x7fff95d8e000 - 0x7fff95e88fff libFontParser.dylib (111.1.6) <77253632-B3F6-3151-ABA0-C1EF458668A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x7fff95e89000 - 0x7fff95e8aff7 libsystem_blocks.dylib (63) <FB856CD1-2AEA-3907-8E9B-1E54B6827F82> /usr/lib/system/libsystem_blocks.dylib 0x7fff95fba000 - 0x7fff95fbafff com.apple.CoreServices (59 - 59) <7A697B5E-F179-30DF-93F2-8B503CEEEFD5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x7fff95fcd000 - 0x7fff95fd5fff libsystem_dnssd.dylib (522.92.3) <1418DF66-01BE-3A87-8553-09EAA945F4FE> /usr/lib/system/libsystem_dnssd.dylib 0x7fff95fd6000 - 0x7fff95fe1fff libkxld.dylib (2422.115.15) <8850BC2B-EB64-3B0F-8047-DCC113021292> /usr/lib/system/libkxld.dylib 0x7fff95fe2000 - 0x7fff95fe3ff7 com.apple.print.framework.Print (9.0 - 260) <EE00FAE1-DA03-3EC2-8571-562518C46994> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x7fff95fe4000 - 0x7fff960a8ff7 com.apple.backup.framework (1.5.5 - 1.5.5) <CA77A4FC-7B76-30C7-94BE-FF4B8140D05A> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup 0x7fff9610e000 - 0x7fff9611bff0 libbz2.1.0.dylib (29) <0B98AC35-B138-349C-8063-2B987A75D24C> /usr/lib/libbz2.1.0.dylib 0x7fff961da000 - 0x7fff96209fff com.apple.DebugSymbols (106 - 106) <E1BDED08-523A-36F4-B2DA-9D5C712F0AC7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols 0x7fff9620a000 - 0x7fff96222ff7 com.apple.GenerationalStorage (2.0 - 160.3) <64749B08-0212-3AC8-9B49-73D662B09304> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage 0x7fff96223000 - 0x7fff96227ff7 libGIF.dylib (1048) <53A30C22-410C-3DFF-9236-0CC56D2E64A5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x7fff965fa000 - 0x7fff96686ff7 com.apple.ink.framework (10.9 - 207) <8A50B893-AD03-3826-8555-A54FEAF08F47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x7fff96687000 - 0x7fff96691fff libcommonCrypto.dylib (60049) <8C4F0CA0-389C-3EDC-B155-E62DD2187E1D> /usr/lib/system/libcommonCrypto.dylib 0x7fff9671b000 - 0x7fff96afcffe libLAPACK.dylib (1094.5) <7E7A9B8D-1638-3914-BAE0-663B69865986> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x7fff96b4b000 - 0x7fff96b67fff libresolv.9.dylib (54) <11C2C826-F1C6-39C6-B4E8-6E0C41D4FA95> /usr/lib/libresolv.9.dylib 0x7fff96baf000 - 0x7fff96d1dff7 libBLAS.dylib (1094.5) <DE93A590-5FA5-32A2-A16C-5D7D7361769F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x7fff96dac000 - 0x7fff96e0fffb com.apple.SystemConfiguration (1.13.1 - 1.13.1) <339A2A90-DA25-33AF-88E5-2FB38A758FEE> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x7fff96e10000 - 0x7fff97986ff7 com.apple.AppKit (6.9 - 1265.21) <9DC13B27-841D-3839-93B2-3EDE66157BDE> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff97987000 - 0x7fff97a37ff7 libvMisc.dylib (423.32) <049C0735-1808-39B9-943F-76CB8021744F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x7fff97a38000 - 0x7fff97a85ff2 com.apple.print.framework.PrintCore (9.0 - 428) <8D8253E3-302F-3DB2-9C5C-572CB974E8B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x7fff97a86000 - 0x7fff97a9fff7 com.apple.Ubiquity (1.3 - 289) <C7F1B734-CE81-334D-BE41-8B20D95A1F9B> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity 0x7fff97b7f000 - 0x7fff97bf6fff com.apple.CoreServices.OSServices (600.4 - 600.4) <6BC86B46-AFD3-3F06-8659-2C954CBEBD43> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x7fff97bfa000 - 0x7fff97bfcff7 libquarantine.dylib (71) <7A1A2BCB-C03D-3A25-BFA4-3E569B2D2C38> /usr/lib/system/libquarantine.dylib 0x7fff97c51000 - 0x7fff97c51ffd libOpenScriptingUtil.dylib (157.1) <D3B6E577-3CDB-3139-9B94-19496DFA7318> /usr/lib/libOpenScriptingUtil.dylib 0x7fff97c8f000 - 0x7fff97de3ff3 com.apple.audio.toolbox.AudioToolbox (1.10 - 1.10) <69B273E8-5A8E-3FC7-B807-C16B657662FE> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x7fff97e59000 - 0x7fff97e9eff6 com.apple.HIServices (1.23 - 468) <FD17FE8C-A355-3B6B-B8B7-E56E5C595EDE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x7fff97e9f000 - 0x7fff97ea2ffc com.apple.IOSurface (91.3 - 91.3) <E93485CC-12B1-318E-BAE3-AB532B264935> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x7fff9800a000 - 0x7fff9800affd com.apple.audio.units.AudioUnit (1.10 - 1.10) <68B21135-55A6-3563-A3D6-3E692A7DEB7F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x7fff9826d000 - 0x7fff986a0ffb com.apple.vision.FaceCore (3.0.0 - 3.0.0) <F42BFC9C-0B16-35EF-9A07-91B7FDAB7FC5> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore 0x7fff986a1000 - 0x7fff986b9fff com.apple.openscripting (1.4.1 - 157.1) <2C6C6498-D88E-3D9B-B933-9873890F382E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x7fff9874e000 - 0x7fff989acff2 com.apple.RawCamera.bundle (5.06 - 753) <7315ED29-77A1-3990-9054-F00B96527C06> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera 0x7fff98ec3000 - 0x7fff98f0aff7 libcups.2.dylib (372.6) <CBD2F0CF-FA10-36E1-A1D5-1B946B45B3B3> /usr/lib/libcups.2.dylib 0x7fff98f0b000 - 0x7fff98f2fff7 libJPEG.dylib (1048) <3C999DC3-8A51-3CA9-9AB8-7F9DBA278FE6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x7fff98f30000 - 0x7fff991a0ffd com.apple.security (7.0 - 55471.14.40) <58F50B4A-FC1E-3AE0-A5DB-DD737E50AC17> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fff991a1000 - 0x7fff991d6fff libssl.0.9.8.dylib (52.8.4) <3F8ADCC3-AE3F-371C-A4D5-FF219D33E507> /usr/lib/libssl.0.9.8.dylib 0x7fff991d9000 - 0x7fff991e4ff7 com.apple.NetAuth (5.0 - 5.0) <C811E662-9EC3-3B74-808A-A75D624F326B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x7fff99263000 - 0x7fff99340fff libcrypto.0.9.8.dylib (52.8.4) <E03DB1E7-4CC6-3338-B67D-F69BE2FB28FC> /usr/lib/libcrypto.0.9.8.dylib 0x7fff99341000 - 0x7fff993adfff com.apple.framework.IOKit (2.0.1 - 907.100.14) <10932113-9F7E-38A0-A158-A019A555CAC3> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff9943a000 - 0x7fff99441ff8 liblaunch.dylib (842.92.1) <A40A0C7B-3216-39B4-8AE0-B5D3BAF1DA8A> /usr/lib/system/liblaunch.dylib 0x7fff99442000 - 0x7fff99459ff7 com.apple.CFOpenDirectory (10.9 - 173.90.1) <D7F2E159-CF6B-3EB1-9806-3BC59E63D24F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x7fff9946d000 - 0x7fff9959dff7 com.apple.desktopservices (1.8.3 - 1.8.3) <225BEC20-F8E0-3F22-9560-890A1A5B9050> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x7fff9959e000 - 0x7fff995afff7 libsystem_asl.dylib (217.1.4) <655FB343-52CF-3E2F-B14D-BEBF5AAEF94D> /usr/lib/system/libsystem_asl.dylib 0x7fff995b0000 - 0x7fff995b2ff7 com.apple.securityhi (9.0 - 55005) <0CB82072-BA4B-357B-BE46-A96D317C1D91> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x7fff996d6000 - 0x7fff996e2ffb com.apple.AppleFSCompression (56.92.2 - 1.0) <16542F97-9D21-317D-8A50-4C34AAD35F41> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression 0x7fff996e3000 - 0x7fff99708ff7 com.apple.ChunkingLibrary (2.0 - 155.1) <B845DC7A-D1EA-31E2-967C-D1FE0C628036> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary 0x7fff99709000 - 0x7fff9970afff com.apple.TrustEvaluationAgent (2.0 - 25) <334A82F4-4AE4-3719-A511-86D0B0723E2B> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent 0x7fff9970d000 - 0x7fff9973efff com.apple.MediaKit (15 - 709) <23E33409-5C39-3F93-9E73-2B0E9EE8883E> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 1
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 4652
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=242.9M resident=65.5M(27%)
swapped_out_or_unallocated=177.4M(73%)
Writable regions: Total=146.6M written=15.2M(10%) resident=67.2M(46%)
swapped_out=0K(0%) unallocated=79.4M(54%)
REGION TYPE                      VIRTUAL
CG backing stores                  8760K
CG image                            80K
CG raster data                      104K
CG shared images                    212K
CoreImage                            8K
IOKit                              46.2M
IOKit (reserved)                      4K        reserved VM address
space (unallocated)
Kernel Alloc Once                    8K
MALLOC                            62.8M
MALLOC (admin)                      32K
Memory Tag 242                      12K
Memory Tag 251                        8K
OpenCL                              20K
OpenGL GLSL                        1664K
SQLite page cache                  256K
STACK GUARD                        56.0M
Stack                              11.2M
VM_ALLOCATE                        16.5M
__DATA                            43.1M
__IMAGE                            528K
__LINKEDIT                        75.6M
__TEXT                            167.3M
__UNICODE                          544K
mapped file                        51.2M
shared memory                        68K
TOTAL                            541.9M
TOTAL, minus reserved VM space    541.9M
On 13/07/16 16:34, Marius Kintel wrote:
Hi Benjamin,
Benjamin
$fn=12;
hull() {
hull() {
cylinder();
Thanks, Here is the crash report (on Preview): Process: OpenSCAD [790] Path: /Applications/_3D/OpenSCAD.app/Contents/MacOS/OpenSCAD Identifier: org.openscad.OpenSCAD Version: 2016.06 (2016.06.25) Code Type: X86-64 (Native) Parent Process: launchd [165] Responsible: OpenSCAD [790] User ID: 501 Date/Time: 2016-07-13 16:45:30.471 +0200 OS Version: Mac OS X 10.9.5 (13F1808) Report Version: 11 Anonymous UUID: A066FB1C-D234-37EC-309A-414D8FE76CF8 Crashed Thread: 0 Dispatch queue: com.apple.main-thread Exception Type: EXC_BAD_INSTRUCTION (SIGILL) Exception Codes: 0x0000000000000001, 0x0000000000000000 Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 libgmp.dylib 0x0000000103814b5e __gmpn_mul_1 + 94 Thread 1:: Dispatch queue: com.apple.libdispatch-manager 0 libsystem_kernel.dylib 0x00007fff8e538662 kevent64 + 10 1 libdispatch.dylib 0x00007fff91ab6421 _dispatch_mgr_invoke + 239 2 libdispatch.dylib 0x00007fff91ab6136 _dispatch_mgr_thread + 52 Thread 2: 0 libsystem_kernel.dylib 0x00007fff8e537e6a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff9527af08 _pthread_wqthread + 330 2 libsystem_pthread.dylib 0x00007fff9527dfb9 start_wqthread + 13 Thread 3: 0 libsystem_kernel.dylib 0x00007fff8e537e6a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff9527af08 _pthread_wqthread + 330 2 libsystem_pthread.dylib 0x00007fff9527dfb9 start_wqthread + 13 Thread 4: 0 libsystem_kernel.dylib 0x00007fff8e537e6a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff9527af08 _pthread_wqthread + 330 2 libsystem_pthread.dylib 0x00007fff9527dfb9 start_wqthread + 13 Thread 5: 0 libsystem_kernel.dylib 0x00007fff8e537e6a __workq_kernreturn + 10 1 libsystem_pthread.dylib 0x00007fff9527af08 _pthread_wqthread + 330 2 libsystem_pthread.dylib 0x00007fff9527dfb9 start_wqthread + 13 Thread 6: 0 libsystem_kernel.dylib 0x00007fff8e533a1a mach_msg_trap + 10 1 libsystem_kernel.dylib 0x00007fff8e532d18 mach_msg + 64 2 com.apple.CoreFoundation 0x00007fff8c624f15 __CFRunLoopServiceMachPort + 181 3 com.apple.CoreFoundation 0x00007fff8c624539 __CFRunLoopRun + 1161 4 com.apple.CoreFoundation 0x00007fff8c623e75 CFRunLoopRunSpecific + 309 5 com.apple.AppKit 0x00007fff96fd405e _NSEventThread + 144 6 libsystem_pthread.dylib 0x00007fff95279899 _pthread_body + 138 7 libsystem_pthread.dylib 0x00007fff9527972a _pthread_start + 137 8 libsystem_pthread.dylib 0x00007fff9527dfc9 thread_start + 13 Thread 7:: com.apple.NSURLConnectionLoader 0 libsystem_kernel.dylib 0x00007fff8e533a1a mach_msg_trap + 10 1 libsystem_kernel.dylib 0x00007fff8e532d18 mach_msg + 64 2 com.apple.CoreFoundation 0x00007fff8c624f15 __CFRunLoopServiceMachPort + 181 3 com.apple.CoreFoundation 0x00007fff8c624539 __CFRunLoopRun + 1161 4 com.apple.CoreFoundation 0x00007fff8c623e75 CFRunLoopRunSpecific + 309 5 com.apple.Foundation 0x00007fff924acf87 +[NSURLConnection(Loader) _resourceLoadLoop:] + 348 6 com.apple.Foundation 0x00007fff924acd8b __NSThread__main__ + 1318 7 libsystem_pthread.dylib 0x00007fff95279899 _pthread_body + 138 8 libsystem_pthread.dylib 0x00007fff9527972a _pthread_start + 137 9 libsystem_pthread.dylib 0x00007fff9527dfc9 thread_start + 13 Thread 8:: com.apple.CFSocket.private 0 libsystem_kernel.dylib 0x00007fff8e5379aa __select + 10 1 com.apple.CoreFoundation 0x00007fff8c670a03 __CFSocketManager + 867 2 libsystem_pthread.dylib 0x00007fff95279899 _pthread_body + 138 3 libsystem_pthread.dylib 0x00007fff9527972a _pthread_start + 137 4 libsystem_pthread.dylib 0x00007fff9527dfc9 thread_start + 13 Thread 0 crashed with X86 Thread State (64-bit): rax: 0x0000608000202480 rbx: 0x00007fff5cc1ce28 rcx: 0x0000000000000001 rdx: 0x0000000000000001 rdi: 0x00007fff5cc1cba0 rsi: 0x0000608000016660 rbp: 0x0000000000000000 rsp: 0x00007fff5cc1caa0 r8: 0x0000000000000000 r9: 0x0000000000000001 r10: 0x0000000000000000 r11: 0x000000010380efb0 r12: 0x00007fff5cc1ce10 r13: 0x00007fff5cc1ce30 r14: 0x0000608000447230 r15: 0x00007fff5cc1cdf8 rip: 0x0000000103814b5e rfl: 0x0000000000010246 cr2: 0x0000000103814b00 Logical CPU: 1 Error Code: 0x00000000 Trap Number: 6 Binary Images: 0x102fde000 - 0x1034f0ff7 +org.openscad.OpenSCAD (2016.06 - 2016.06.25) <EB07A0F8-4DE3-3CA4-8B1B-5281999C987B> /Applications/_3D/OpenSCAD.app/Contents/MacOS/OpenSCAD 0x103700000 - 0x10371ffff +libCGAL.dylib (11.0.2) <CABAD2E5-F0A9-3540-87CC-E235987AF0C0> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libCGAL.dylib 0x103733000 - 0x1037cbff7 +libmpfr.dylib (6.4) <4CCE9ACD-180C-343C-B202-CBD0C2454F5E> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libmpfr.dylib 0x1037df000 - 0x103889fff +libgmp.dylib (14.1) <044A4679-1C28-3A99-9BC2-5A5121E26749> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libgmp.dylib 0x103899000 - 0x1038a6fff +libopencsg.dylib (0) <F5128B49-A1B2-356D-8D69-17FE4E40C78A> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libopencsg.dylib 0x1038b5000 - 0x1038e2fff +libGLEW.dylib (1.13) <532CE477-AF4A-38E0-8B38-329C4A98DD24> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libGLEW.dylib 0x103919000 - 0x10392afff +libboost_thread.dylib (0) <B63A9489-CB04-3F21-A5B9-62B663E612CA> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libboost_thread.dylib 0x10393d000 - 0x10397bff7 +libboost_program_options.dylib (0) <0FB651AF-8C1C-34C0-8BD5-A08CA322A33E> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libboost_program_options.dylib 0x1039b5000 - 0x1039c4fff +libboost_filesystem.dylib (0) <90E15FCB-70F8-3A6D-AFC7-EF8451237494> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libboost_filesystem.dylib 0x1039d3000 - 0x1039d5fff +libboost_system.dylib (0) <A1BC9918-CAF3-3E3B-AD8B-5374A2161186> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libboost_system.dylib 0x1039db000 - 0x103a7ffff +libboost_regex.dylib (0) <BA309DB2-3ADA-3A19-9327-E50FA07A1F67> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libboost_regex.dylib 0x103ad1000 - 0x103c4fff7 +libglib-2.0.dylib (4601.1) <86B9DF14-E583-3D9B-A62E-C8EF2F98D982> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libglib-2.0.dylib 0x103c7e000 - 0x103c8cff7 +libintl.dylib (11.4) <8589D050-5726-33EA-8586-CE9B0DBEC6CE> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libintl.dylib 0x103c91000 - 0x103c91ff9 +cl_kernels (???) <B1782CF9-FABA-4AB9-A82B-CFDEA267557F> cl_kernels 0x103c93000 - 0x103ccefff +org.sparkle-project.Sparkle (1.13.1 git-2afc553 - 1.13.1) <40414915-A48C-3DBB-AACB-5C20BAAE6DA6> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle 0x103d0b000 - 0x103de5ff7 +libharfbuzz.dylib (10201.7) <9658620F-099D-36AD-A649-C4F3E38233EC> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libharfbuzz.dylib 0x103e2e000 - 0x103f04fff +libfreetype.dylib (19.3) <6A1A56D2-3879-389D-88E8-F95C48385F5F> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libfreetype.dylib 0x103f20000 - 0x103f6cfff +libfontconfig.dylib (11.1) <89F2C78C-E63A-3F81-A1E9-57F2E1157890> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libfontconfig.dylib 0x103f7d000 - 0x103f7eff4 +cl_kernels (???) <EB54DF94-E8B1-419A-9965-CD270EA43CF5> cl_kernels 0x103f80000 - 0x10414cfff +libqscintilla2.dylib (0) <B88971DC-3C68-3CF8-B2A9-AF8C279A39DE> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libqscintilla2.dylib 0x1041cb000 - 0x1041feff7 +org.qt-project.QtPrintSupport (5.7 - 5.7.0) <67BB0DB0-88B2-3802-92D5-7B326C90AFB0> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtPrintSupport.framework/Versions/5/QtPrintSupport 0x104229000 - 0x104722ff7 +org.qt-project.QtWidgets (5.7 - 5.7.0) <E1338AA1-EDCE-3904-B764-D5CC1FB2F8FC> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets 0x104909000 - 0x104d09ff7 +org.qt-project.QtGui (5.7 - 5.7.0) <65053079-A2E1-3D59-AE88-BEB242E05C97> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui 0x104e4a000 - 0x10535eff7 +org.qt-project.QtCore (5.7 - 5.7.0) <91296610-5A00-30F7-9663-DDF7738C31FF> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore 0x10547b000 - 0x105484ff7 +org.qt-project.QtMacExtras (5.7 - 5.7.0) <8B3C4F7B-C98D-3A29-9858-DAF34F58768B> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtMacExtras.framework/Versions/5/QtMacExtras 0x105491000 - 0x105495ff7 +org.qt-project.QtConcurrent (5.7 - 5.7.0) <AB461D07-E24C-3894-9E0C-DC3B8FCAFCC4> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtConcurrent.framework/Versions/5/QtConcurrent 0x10549f000 - 0x1054a3fff com.apple.agl (3.2.3 - AGL-3.2.3) <21798BC5-8F01-345B-B27B-1037CF71D166> /System/Library/Frameworks/AGL.framework/Versions/A/AGL 0x1054ac000 - 0x1054aeff7 +libboost_chrono.dylib (0) <19702DF9-27BD-3562-A001-373C70F97F25> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libboost_chrono.dylib 0x1054b8000 - 0x10567eff7 +libxml2.dylib (12.4) <21E63B2A-51D4-3705-A9CE-077D74534E16> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/libxml2.dylib 0x106f79000 - 0x1070eafff +libqcocoa.dylib (0) <56AF80F9-6AAF-3A4E-97F4-109614288A77> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/platforms/libqcocoa.dylib 0x107160000 - 0x1071c7ff7 +org.qt-project.QtDBus (5.7 - 5.7.0) <A3B1C34A-7EBC-36D6-B053-9CEE4A3D14CE> /Applications/_3D/OpenSCAD.app/Contents/Frameworks/QtDBus.framework/Versions/5/QtDBus 0x10752a000 - 0x107534ff7 +libqdds.dylib (0) <C030C6EC-3611-3A8D-894F-071C96FB3031> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqdds.dylib 0x107539000 - 0x107540ff7 +libqgif.dylib (0) <551D6575-9920-346E-BE76-3A835199CC08> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqgif.dylib 0x107545000 - 0x10754dfff +libqicns.dylib (0) <72F60B35-25FC-3478-A86D-6CC786A508C2> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqicns.dylib 0x109ae5000 - 0x109aebfff +libqico.dylib (0) <159201A7-AB7A-3174-A3F7-E3954A138C8F> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqico.dylib 0x109af0000 - 0x109b83fff +libqjp2.dylib (0) <E3D63E91-718B-3FF9-8212-FA33DB4B459D> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqjp2.dylib 0x109b9b000 - 0x109bdafff +libqjpeg.dylib (0) <38A4D43B-CDF7-3867-95B6-C51AFCAFB512> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqjpeg.dylib 0x109be4000 - 0x109c36ff7 +libqmng.dylib (0) <E168CE5A-1CC1-3587-9641-7DD2C9F13D74> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqmng.dylib 0x109c47000 - 0x109c4bff7 +libqtga.dylib (0) <576CF0ED-6C64-32C7-99BB-6468A1080D9F> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqtga.dylib 0x109c50000 - 0x109cb4fff +libqtiff.dylib (0) <F086BC43-2567-3B23-B0FA-D458999803BB> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqtiff.dylib 0x109cc2000 - 0x109cc6ff7 +libqwbmp.dylib (0) <9F5B0F44-0AF1-300C-88D2-7C2EE2C8F309> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqwbmp.dylib 0x109ccb000 - 0x109d45fff +libqwebp.dylib (0) <E401A034-2209-3102-BA10-9E7F67BEA588> /Applications/_3D/OpenSCAD.app/Contents/PlugIns/imageformats/libqwebp.dylib 0x10a366000 - 0x10a36aff9 libFontRegistryUI.dylib (127.0.1) <80D54383-4576-3B3D-93BD-8C5C861819C6> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resources/libFontRegistryUI.dylib 0x10a371000 - 0x10a37cfff libGPUSupport.dylib (9.6.5) <7262B5E5-AA02-3916-9E78-071502F4F1BE> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib 0x10a804000 - 0x10a8eafef unorm8_bgra.dylib (2.3.58) <A975133F-2E73-3DAF-A08F-B3CC7E9E10CE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib 0x10a92c000 - 0x10b076ff7 libclh.dylib (4.0.3 - 4.0.3) <8D8CFC19-2C05-3D15-A76A-3F390DC03346> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/libclh.dylib 0x10db72000 - 0x10dbe9ff7 com.apple.xquery (1.3.1 - 30) <2F2DC0D6-456F-33A0-8537-E0C651F6817C> /System/Library/PrivateFrameworks/XQuery.framework/XQuery 0x123440000000 - 0x12344086dfff com.apple.GeForceTeslaGLDriver (8.24.17 - 8.2.4) <C7C202BA-F674-3190-8CC1-62738301149C> /System/Library/Extensions/GeForceTeslaGLDriver.bundle/Contents/MacOS/GeForceTeslaGLDriver 0x7fff63c6f000 - 0x7fff63ca2887 dyld (239.5) <1D3130FE-FE7E-3C4C-8E74-EB51895B6BA5> /usr/lib/dyld 0x7fff8ba35000 - 0x7fff8ba38ff7 libdyld.dylib (239.5) <CAE7A50D-F156-3D47-81C0-DC41EB975D38> /usr/lib/system/libdyld.dylib 0x7fff8ba39000 - 0x7fff8ba3dfff libpam.2.dylib (20) <B93CE8F5-DAA8-30A1-B1F6-F890509513CB> /usr/lib/libpam.2.dylib 0x7fff8bc02000 - 0x7fff8bc04fff libRadiance.dylib (1048) <5D66AE6D-1B0B-33CC-91F0-D93AE7016C7B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x7fff8bd4f000 - 0x7fff8bd55fff com.apple.AOSNotification (1.7.0 - 760.4) <8F042A51-E0A9-37E6-A601-0DD6A58A0AC8> /System/Library/PrivateFrameworks/AOSNotification.framework/Versions/A/AOSNotification 0x7fff8bf94000 - 0x7fff8bfbdfff GLRendererFloat (9.6.5) <D216C628-95EC-346C-A4EE-C88A750ADF5F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat 0x7fff8c05c000 - 0x7fff8c0c1ffb com.apple.Heimdal (4.0 - 2.0) <C28DBCAE-01AC-363A-9046-3BD33F225526> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal 0x7fff8c587000 - 0x7fff8c5b3fff com.apple.CoreServicesInternal (184.9 - 184.9) <4DEA54F9-81D6-3EDB-AA3C-1F9C497B3379> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal 0x7fff8c5b4000 - 0x7fff8c799fff com.apple.CoreFoundation (6.9 - 855.17) <729BD6DA-1F63-3E72-A148-26F21EBF52BB> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x7fff8c79a000 - 0x7fff8ca6bffc com.apple.CoreImage (9.4.1) <7B28C3F3-8EB3-3150-A55D-EBCDBDCA4977> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage 0x7fff8ca6c000 - 0x7fff8ca93ff7 libsystem_network.dylib (241.4) <0D630D53-C772-3EC5-8257-EFB0ACCE3153> /usr/lib/system/libsystem_network.dylib 0x7fff8cd63000 - 0x7fff8cd8bffb libxslt.1.dylib (13.10) <367D404A-6065-3A8D-A94A-4838F9F9DB4A> /usr/lib/libxslt.1.dylib 0x7fff8cd8f000 - 0x7fff8cd98ffb libsystem_notify.dylib (121.20.1) <9B34B4FE-F5AD-3F09-A5F0-46AFF3571323> /usr/lib/system/libsystem_notify.dylib 0x7fff8cd99000 - 0x7fff8ce7dff7 com.apple.coreui (2.2 - 231.1) <187DF89C-8A64-366D-8782-F90315FA3CD7> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI 0x7fff8ce7e000 - 0x7fff8ceaefff com.apple.IconServices (25 - 25.17) <4751127E-FBD5-3ED5-8510-08D4E4166EFE> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices 0x7fff8cfcf000 - 0x7fff8d17cf27 libobjc.A.dylib (551.1) <AD7FD984-271E-30F4-A361-6B20319EC73B> /usr/lib/libobjc.A.dylib 0x7fff8d186000 - 0x7fff8d186fff com.apple.ApplicationServices (48 - 48) <3E3F01A8-314D-378F-835E-9CC4F8820031> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x7fff8d20b000 - 0x7fff8d214ff7 libcldcpuengine.dylib (2.3.58) <4433A688-94CA-3EE0-BE5B-D982C14EF6DB> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib 0x7fff8d215000 - 0x7fff8d218ffa libCGXType.A.dylib (599.35.13) <7427D788-DC44-303C-AD7C-F92F04C8D9F0> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib 0x7fff8d219000 - 0x7fff8d461ff7 com.apple.CoreData (107 - 481.3) <E78734AA-E3D0-33CB-A014-620BBCAB2E96> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x7fff8d72a000 - 0x7fff8d745ff7 libCRFSuite.dylib (34) <FFAE75FA-C54E-398B-AA97-18164CD9789D> /usr/lib/libCRFSuite.dylib 0x7fff8d75d000 - 0x7fff8d8f8ff8 com.apple.CFNetwork (673.6 - 673.6) <CAA196FE-BF5A-384F-975E-E0F81359805B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x7fff8d8f9000 - 0x7fff8d90bff7 com.apple.MultitouchSupport.framework (245.13.1 - 245.13.1) <38262B92-C63F-35A0-997D-AD2EBF2F8338> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport 0x7fff8d90c000 - 0x7fff8d916ff7 com.apple.bsd.ServiceManagement (2.0 - 2.0) <2D27B498-BB9C-3D88-B05A-76908A8A26F3> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement 0x7fff8d917000 - 0x7fff8d940ff7 libc++abi.dylib (49.1) <21A807D3-6732-3455-B77F-743E9F916DF0> /usr/lib/libc++abi.dylib 0x7fff8d996000 - 0x7fff8da58ffd com.apple.CoreText (367.23 - 367.23) <C799261E-2E19-3D69-8A8D-098B7DD8D31D> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText 0x7fff8da59000 - 0x7fff8dadafff com.apple.CoreSymbolication (3.0.1 - 141.0.6) <D46DE002-1FEB-38B7-8583-3DF3496274F5> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication 0x7fff8db26000 - 0x7fff8db2aff7 libheimdal-asn1.dylib (323.92.2) <979AEAA0-59B3-3E99-94B1-9BB9C6C45273> /usr/lib/libheimdal-asn1.dylib 0x7fff8db2b000 - 0x7fff8db70fff libcurl.4.dylib (78.94.1) <88F27F9B-052E-3375-938D-2603E90D8AD5> /usr/lib/libcurl.4.dylib 0x7fff8db71000 - 0x7fff8db8cff7 libPng.dylib (1048) <C14F8741-9F67-32DA-896A-F873705B3EC6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x7fff8dba1000 - 0x7fff8dbbaff7 com.apple.Kerberos (3.0 - 1) <F108AFEB-198A-3BAF-BCA5-9DFCE55EFF92> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos 0x7fff8e011000 - 0x7fff8e03afff com.apple.DictionaryServices (1.2 - 208) <A539A058-BA57-35EE-AA08-D0B0E835127D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices 0x7fff8e444000 - 0x7fff8e44bfff libcompiler_rt.dylib (35) <4CD916B2-1B17-362A-B403-EF24A1DAC141> /usr/lib/system/libcompiler_rt.dylib 0x7fff8e44c000 - 0x7fff8e517fff libvDSP.dylib (423.32) <3BF732BE-DDE0-38EB-8C54-E4E3C64F77A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x7fff8e522000 - 0x7fff8e53eff7 libsystem_kernel.dylib (2422.115.15) <34ABAF79-E147-3C34-B05D-46A566E689CC> /usr/lib/system/libsystem_kernel.dylib 0x7fff8e751000 - 0x7fff8e9fbff5 com.apple.HIToolbox (2.1.1 - 698) <26FF0E2C-1CD7-311F-ACF0-84F3D5273AD6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x7fff8e9fc000 - 0x7fff8ea69ff1 com.apple.ApplicationServices.ATS (360 - 363.6) <828C2711-4577-3F75-B436-3BDF328DFB11> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x7fff8ea6a000 - 0x7fff8ea6eff7 libsystem_stats.dylib (93.90.3) <2304C7C2-BE45-35DE-BCC6-707D61B7AE7E> /usr/lib/system/libsystem_stats.dylib 0x7fff8ea6f000 - 0x7fff8ea7cff4 com.apple.Librarian (1.2 - 1) <F1A2744D-8536-32C7-8218-9972C6300DAE> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian 0x7fff8eaa4000 - 0x7fff8eb95ff9 libiconv.2.dylib (41) <BB44B115-AC32-3877-A0ED-AEC6232A4563> /usr/lib/libiconv.2.dylib 0x7fff8eb96000 - 0x7fff8ec26ff7 com.apple.Metadata (10.7.0 - 800.30) <E107CE36-FBC3-35A5-84E0-864B4178FC5D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x7fff8ec27000 - 0x7fff8ec68fff com.apple.PerformanceAnalysis (1.47 - 47) <95435F84-C251-3C48-B6CD-9EE7A63D6E26> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis 0x7fff8ec9f000 - 0x7fff8eca0fff libsystem_sandbox.dylib (278.11.2) <0C93EB23-7364-3670-B511-212A7A524695> /usr/lib/system/libsystem_sandbox.dylib 0x7fff8eca1000 - 0x7fff8ecdaff7 com.apple.QD (3.50 - 298) <C1F20764-DEF0-34CF-B3AB-AB5480D64E66> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x7fff8ed62000 - 0x7fff8ee33ff1 com.apple.DiskImagesFramework (10.9.6 - 373) <4EA5A3C8-13E2-309C-8FAB-C21A4C316802> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages 0x7fff8eee8000 - 0x7fff8f25fff6 com.apple.JavaScriptCore (9537 - 9537.78.1) <8623A109-9E9D-3E3B-A8E1-6EE447C0110C> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore 0x7fff8f260000 - 0x7fff8f34efff libJP2.dylib (1048) <19B37CB6-C864-3830-87FE-BB53F8542FB0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x7fff8f34f000 - 0x7fff8f37efd2 libsystem_m.dylib (3047.16) <B7F0E2E4-2777-33FC-A787-D6430B630D54> /usr/lib/system/libsystem_m.dylib 0x7fff8f37f000 - 0x7fff8f38ffff libbsm.0.dylib (33) <2CAC00A2-1352-302A-88FA-C567D4D69179> /usr/lib/libbsm.0.dylib 0x7fff8f3a3000 - 0x7fff8f3a6fff com.apple.TCC (1.0 - 1) <32A075D9-47FD-3E71-95BC-BFB0D583F41C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC 0x7fff8f3a7000 - 0x7fff8f471ff7 com.apple.LaunchServices (572.32 - 572.32) <A4699DED-5101-3068-94F8-8D0B7A84BC79> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x7fff8f472000 - 0x7fff8f47cff7 libcsfde.dylib (380.70.2) <3ACB87D7-A81C-3C45-B648-AD27F1B9D841> /usr/lib/libcsfde.dylib 0x7fff8f5c5000 - 0x7fff8f5ccffb libcopyfile.dylib (103.92.1) <CF29DFF6-0589-3590-834C-82E2316612E8> /usr/lib/system/libcopyfile.dylib 0x7fff8f615000 - 0x7fff8f616fff libunc.dylib (28) <62682455-1862-36FE-8A04-7A6B91256438> /usr/lib/system/libunc.dylib 0x7fff8f67e000 - 0x7fff8f680ff3 libsystem_configuration.dylib (596.15) <4998CB6A-9D54-390A-9F57-5D1AC53C135C> /usr/lib/system/libsystem_configuration.dylib 0x7fff8f681000 - 0x7fff8f955fc7 com.apple.vImage (7.0 - 7.0) <D241DBFA-AC49-31E2-893D-EAAC31890C90> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x7fff8f963000 - 0x7fff8f998ffc com.apple.LDAPFramework (2.4.28 - 194.5) <5E501783-06E8-390C-AF34-A7FAD402F3E6> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP 0x7fff9029c000 - 0x7fff9029efff libCVMSPluginSupport.dylib (9.6.5) <9DE29AD9-5F59-3B9B-899C-4DED190CB817> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib 0x7fff9029f000 - 0x7fff903a6ff7 com.apple.ImageIO.framework (3.3.0 - 1048) <FDFAFDEA-3559-330F-9578-40F4F62F51B3> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x7fff903a7000 - 0x7fff903ccff7 com.apple.CoreVideo (1.8 - 117.2) <4674339E-26D0-35FA-9958-422832B39B12> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x7fff90462000 - 0x7fff904a0ff7 libGLImage.dylib (9.6.5) <C242B319-6F4B-3FB3-8FCE-0B77424F0BED> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x7fff904a1000 - 0x7fff912f5ff7 com.apple.WebCore (9537 - 9537.78.1) <56C3D4BF-2495-3FD2-8212-91AF7DF693B8> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore 0x7fff912f6000 - 0x7fff91305ff8 com.apple.LangAnalysis (1.7.0 - 1.7.0) <8FE131B6-1180-3892-98F5-C9C9B79072D4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x7fff91312000 - 0x7fff91351fff libGLU.dylib (9.6.5) <7463B411-2DB0-3338-BC8D-403293E2CA34> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x7fff91352000 - 0x7fff91359fff com.apple.NetFS (6.0 - 4.0) <8E26C099-CE9D-3819-91A2-64EA929C6137> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS 0x7fff91389000 - 0x7fff9139aff7 libz.1.dylib (53) <42E0C8C6-CA38-3CA4-8619-D24ED5DD492E> /usr/lib/libz.1.dylib 0x7fff9139b000 - 0x7fff913e9ff7 com.apple.opencl (2.3.59 - 2.3.59) <E37E2219-6EA7-3666-8DB5-8FC60EFB0BC9> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL 0x7fff9141b000 - 0x7fff9146cff7 com.apple.audio.CoreAudio (4.2.1 - 4.2.1) <07F2B103-AE29-3118-BBC4-9A72E13B013B> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x7fff9146d000 - 0x7fff914f6fff libsystem_c.dylib (997.90.4) <EA812F03-8AD2-3776-AD50-6BEBC90F1F5F> /usr/lib/system/libsystem_c.dylib 0x7fff914fb000 - 0x7fff91533ff7 com.apple.RemoteViewServices (2.0 - 94) <3F34D630-3DDB-3411-BC28-A56A9B55EBDA> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices 0x7fff91534000 - 0x7fff9153dfff com.apple.speech.synthesis.framework (4.7.1 - 4.7.1) <383FB557-E88E-3239-82B8-15F9F885B702> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x7fff9153e000 - 0x7fff9156dff9 com.apple.GSS (4.0 - 2.0) <27FCA2B4-0767-3002-8755-862B19B5CF92> /System/Library/Frameworks/GSS.framework/Versions/A/GSS 0x7fff916b0000 - 0x7fff916f2ff7 libauto.dylib (185.5) <F45C36E8-B606-3886-B5B1-B6745E757CA8> /usr/lib/libauto.dylib 0x7fff916f3000 - 0x7fff919ddfff com.apple.CoreServices.CarbonCore (1077.17 - 1077.17) <3A2E92FD-DEE2-3D45-9619-11500801A61C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x7fff919eb000 - 0x7fff919ecff7 libDiagnosticMessagesClient.dylib (100) <4CDB0F7B-C0AF-3424-BC39-495696F0DB1E> /usr/lib/libDiagnosticMessagesClient.dylib 0x7fff919ed000 - 0x7fff91a51fff com.apple.datadetectorscore (5.0 - 354.5) <D4DBCCF4-9622-3AB9-9076-32579FCC2E39> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore 0x7fff91a52000 - 0x7fff91a6dff7 libsystem_malloc.dylib (23.10.1) <A695B4E4-38E9-332E-A772-29D31E3F1385> /usr/lib/system/libsystem_malloc.dylib 0x7fff91ab3000 - 0x7fff91acdfff libdispatch.dylib (339.92.1) <C4E4A18D-3C3B-3C9C-8709-A4270D998DE7> /usr/lib/system/libdispatch.dylib 0x7fff91ace000 - 0x7fff91ad3ff7 libunwind.dylib (35.3) <78DCC358-2FC1-302E-B395-0155B47CB547> /usr/lib/system/libunwind.dylib 0x7fff91ad7000 - 0x7fff91b8fff7 com.apple.DiscRecording (8.0 - 8000.4.6) <CDAAAD04-A1D0-3C67-ABCC-EFC9E8D44E7E> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording 0x7fff922e0000 - 0x7fff922e6ff7 libsystem_platform.dylib (24.90.1) <3C3D3DA8-32B9-3243-98EC-D89B9A1670B3> /usr/lib/system/libsystem_platform.dylib 0x7fff9230a000 - 0x7fff9230ffff com.apple.DiskArbitration (2.6 - 2.6) <A4165553-770E-3D27-B217-01FC1F852B87> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x7fff923e5000 - 0x7fff92437fff libc++.1.dylib (120) <4F68DFC5-2077-39A8-A449-CAC5FDEE7BDE> /usr/lib/libc++.1.dylib 0x7fff92438000 - 0x7fff92445fff com.apple.Sharing (132.2 - 132.2) <F983394A-226D-3244-B511-FA51FDB6ADDA> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing 0x7fff92446000 - 0x7fff92746ff7 com.apple.Foundation (6.9 - 1056.17) <E0B0FAF6-5CA8-3EEB-8BF2-104C0AEEF925> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x7fff92790000 - 0x7fff92930ff7 GLEngine (9.6.5) <30643C97-7EBB-36EE-BEEA-13844EA0F680> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine 0x7fff929b5000 - 0x7fff929ddffb libRIP.A.dylib (599.35.13) <944F001B-C045-3784-8720-38D6F1272845> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib 0x7fff92a56000 - 0x7fff92a59fff com.apple.help (1.3.3 - 46) <AE763646-D07A-3F9A-ACD4-F5CBD734EE36> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x7fff92a67000 - 0x7fff92bcdfff libGLProgrammability.dylib (9.6.5) <53BCF254-3014-33DC-94EF-72C7270F14F2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib 0x7fff92bce000 - 0x7fff92bf5ffb libsystem_info.dylib (449.1.4) <12CD9E42-8CEE-3A8D-B006-F8A6EB98804D> /usr/lib/system/libsystem_info.dylib 0x7fff92bf6000 - 0x7fff92c06ffb libsasl2.2.dylib (170) <C8E25710-68B6-368A-BF3E-48EC7273177B> /usr/lib/libsasl2.2.dylib 0x7fff92c55000 - 0x7fff92df1ff3 com.apple.QuartzCore (1.8 - 332.4) <CFB972D1-FA37-380C-9A47-2A67A84B7442> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x7fff92df8000 - 0x7fff92df9ffb libremovefile.dylib (33) <3543F917-928E-3DB2-A2F4-7AB73B4970EF> /usr/lib/system/libremovefile.dylib 0x7fff92f57000 - 0x7fff9308dff5 com.apple.WebKit (9537 - 9537.78.2) <EB8D3D78-92E7-3B67-8AAF-B51A181461E0> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit 0x7fff93144000 - 0x7fff9319dff7 libTIFF.dylib (1048) <923096A6-02CC-311D-9596-1961430C0EF7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x7fff9319e000 - 0x7fff93211fff com.apple.securityfoundation (6.0 - 55122.3) <0AFCF575-97C3-3458-A72E-39DA07804EB9> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation 0x7fff93212000 - 0x7fff9327ffff com.apple.SearchKit (1.4.0 - 1.4.0) <B9B8D510-A27E-36B0-93E9-17146D9E9045> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x7fff93286000 - 0x7fff93287fff liblangid.dylib (117) <9546E641-F730-3AB0-B3CD-E0E2FDD173D9> /usr/lib/liblangid.dylib 0x7fff9340a000 - 0x7fff9342efff libxpc.dylib (300.90.2) <AB40CD57-F454-3FD4-B415-63B3C0D5C624> /usr/lib/system/libxpc.dylib 0x7fff9342f000 - 0x7fff9342ffff com.apple.Accelerate (1.9 - Accelerate 1.9) <509BB27A-AE62-366D-86D8-0B06D217CF56> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x7fff93430000 - 0x7fff934b9fff com.apple.ColorSync (4.9.0 - 4.9.0) <B756B908-9AD1-3F5D-83F9-7A0B068387D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x7fff93566000 - 0x7fff93570ff7 com.apple.CrashReporterSupport (10.9 - 539) <B25A09EC-A021-32EC-86F8-05B4837E0EDE> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport 0x7fff93571000 - 0x7fff93571fff com.apple.Carbon (154 - 157) <EFC1A1C0-CB07-395A-B038-CFA2E71D3E69> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x7fff93572000 - 0x7fff93574fff com.apple.EFILogin (2.0 - 2) <8D651894-B7AD-3F23-9B93-472EEA3D292F> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin 0x7fff93575000 - 0x7fff93587fff com.apple.ImageCapture (9.0 - 9.0) <BE0B65DA-3031-359B-8BBA-B9803D4ADBF4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x7fff93588000 - 0x7fff9358cfff com.apple.CommonPanels (1.2.6 - 96) <6B434AFD-50F8-37C7-9A56-162C17E375B3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x7fff938d1000 - 0x7fff938deff7 libxar.1.dylib (202) <5572AA71-E98D-3FE1-9402-BB4A84E0E71E> /usr/lib/libxar.1.dylib 0x7fff93e0c000 - 0x7fff93e0effb libutil.dylib (34) <DAC4A6CF-A1BB-3874-9569-A919316D30E8> /usr/lib/libutil.dylib 0x7fff93ea6000 - 0x7fff93ea6ff7 libkeymgr.dylib (28) <3AA8D85D-CF00-3BD3-A5A0-E28E1A32A6D8> /usr/lib/system/libkeymgr.dylib 0x7fff93ea7000 - 0x7fff93eb0ffd com.apple.CommonAuth (4.0 - 2.0) <BD720379-757B-305C-A7BE-E00E680F8218> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth 0x7fff93eb1000 - 0x7fff93eb1fff com.apple.Cocoa (6.8 - 20) <E90E99D7-A425-3301-A025-D9E0CD11918E> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa 0x7fff9424b000 - 0x7fff94286fff com.apple.bom (14.0 - 193.1) <EF24A562-6D3C-379E-8B9B-FAE0E4A0EF7C> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom 0x7fff94287000 - 0x7fff94288ff7 libSystem.B.dylib (1197.1.1) <F727296D-D066-31BD-A9F9-5CAA1BD7A6A7> /usr/lib/libSystem.B.dylib 0x7fff942df000 - 0x7fff942edfff com.apple.opengl (9.6.5 - 9.6.5) <4FAEADD8-EEB3-3FD9-ADC6-BA65806228CC> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x7fff9430c000 - 0x7fff94c3512b com.apple.CoreGraphics (1.600.0 - 599.35.13) <142EF2C9-6B8F-3ACB-9C46-B20628DFE134> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x7fff94c36000 - 0x7fff94c3eff7 com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <98BBB3E4-6239-3EF1-90B2-84EA0D3B8D61> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x7fff94c3f000 - 0x7fff94c44fff libmacho.dylib (845) <1D2910DF-C036-3A82-A3FD-44FF73B5FF9B> /usr/lib/system/libmacho.dylib 0x7fff94cd5000 - 0x7fff94cddffc libGFXShared.dylib (9.6.5) <FCCD0CD3-02FD-3A79-B048-A14745D76CC8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib 0x7fff95118000 - 0x7fff95120ff3 libCGCMS.A.dylib (599.35.13) <2B9BCBE1-4376-374E-B5C1-75672854B5D8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib 0x7fff9516d000 - 0x7fff95179ff7 com.apple.OpenDirectory (10.9 - 173.90.1) <383F96FF-1DF3-37E8-8540-03A697C873F6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory 0x7fff9517a000 - 0x7fff95262ff7 libxml2.2.dylib (26.8) <75424553-B02C-37FB-BCDD-19A288D3F306> /usr/lib/libxml2.2.dylib 0x7fff95263000 - 0x7fff95267ff7 libcache.dylib (62) <BDC1E65B-72A1-3DA3-A57C-B23159CAAD0B> /usr/lib/system/libcache.dylib 0x7fff95268000 - 0x7fff9526bfff libCoreVMClient.dylib (58.1) <EBC36C69-C896-3C3D-8589-3E9023E7E56F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib 0x7fff9526c000 - 0x7fff95277fff libGL.dylib (9.6.5) <A5F36623-33E8-379D-A423-8F873018CD79> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x7fff95278000 - 0x7fff9527fff7 libsystem_pthread.dylib (53.1.4) <AB498556-B555-310E-9041-F67EC9E00E2C> /usr/lib/system/libsystem_pthread.dylib 0x7fff95280000 - 0x7fff9536afff libsqlite3.dylib (158) <00269BF9-43BE-39E0-9C85-24585B9923C8> /usr/lib/libsqlite3.dylib 0x7fff953eb000 - 0x7fff953ebfff com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <F8D0CC77-98AC-3B58-9FE6-0C25421827B6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x7fff9552f000 - 0x7fff95576ffb libFontRegistry.dylib (127.0.1) <F267F500-6E4A-3BE3-97C1-08AAA649E02E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib 0x7fff955cd000 - 0x7fff95625ff7 com.apple.Symbolication (1.4 - 129.0.2) <3DCCAB8A-6FA1-3BB9-B4D3-A3CBDB3BDF04> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication 0x7fff95665000 - 0x7fff956b3fff libcorecrypto.dylib (161.1) <F3973C28-14B6-3006-BB2B-00DD7F09ABC7> /usr/lib/system/libcorecrypto.dylib 0x7fff95a7d000 - 0x7fff95ad8ffb com.apple.AE (665.5 - 665.6) <9B17E7B7-D493-346A-827E-6DF1474E4977> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x7fff95af0000 - 0x7fff95b43fff com.apple.ScalableUserInterface (1.0 - 1) <CF745298-7373-38D2-B3B1-727D5A569E48> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface 0x7fff95b44000 - 0x7fff95cfcffb libicucore.A.dylib (511.36) <9AAC5980-2C1F-3B86-8A16-DB533F5E7C84> /usr/lib/libicucore.A.dylib 0x7fff95d02000 - 0x7fff95d8dff7 libCoreStorage.dylib (380.70.2) <BD993BC8-ED54-3DC1-B28B-3B6AC77E8E5C> /usr/lib/libCoreStorage.dylib 0x7fff95d8e000 - 0x7fff95e88fff libFontParser.dylib (111.1.6) <77253632-B3F6-3151-ABA0-C1EF458668A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib 0x7fff95e89000 - 0x7fff95e8aff7 libsystem_blocks.dylib (63) <FB856CD1-2AEA-3907-8E9B-1E54B6827F82> /usr/lib/system/libsystem_blocks.dylib 0x7fff95fba000 - 0x7fff95fbafff com.apple.CoreServices (59 - 59) <7A697B5E-F179-30DF-93F2-8B503CEEEFD5> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x7fff95fcd000 - 0x7fff95fd5fff libsystem_dnssd.dylib (522.92.3) <1418DF66-01BE-3A87-8553-09EAA945F4FE> /usr/lib/system/libsystem_dnssd.dylib 0x7fff95fd6000 - 0x7fff95fe1fff libkxld.dylib (2422.115.15) <8850BC2B-EB64-3B0F-8047-DCC113021292> /usr/lib/system/libkxld.dylib 0x7fff95fe2000 - 0x7fff95fe3ff7 com.apple.print.framework.Print (9.0 - 260) <EE00FAE1-DA03-3EC2-8571-562518C46994> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x7fff95fe4000 - 0x7fff960a8ff7 com.apple.backup.framework (1.5.5 - 1.5.5) <CA77A4FC-7B76-30C7-94BE-FF4B8140D05A> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup 0x7fff9610e000 - 0x7fff9611bff0 libbz2.1.0.dylib (29) <0B98AC35-B138-349C-8063-2B987A75D24C> /usr/lib/libbz2.1.0.dylib 0x7fff961da000 - 0x7fff96209fff com.apple.DebugSymbols (106 - 106) <E1BDED08-523A-36F4-B2DA-9D5C712F0AC7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols 0x7fff9620a000 - 0x7fff96222ff7 com.apple.GenerationalStorage (2.0 - 160.3) <64749B08-0212-3AC8-9B49-73D662B09304> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage 0x7fff96223000 - 0x7fff96227ff7 libGIF.dylib (1048) <53A30C22-410C-3DFF-9236-0CC56D2E64A5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x7fff965fa000 - 0x7fff96686ff7 com.apple.ink.framework (10.9 - 207) <8A50B893-AD03-3826-8555-A54FEAF08F47> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x7fff96687000 - 0x7fff96691fff libcommonCrypto.dylib (60049) <8C4F0CA0-389C-3EDC-B155-E62DD2187E1D> /usr/lib/system/libcommonCrypto.dylib 0x7fff9671b000 - 0x7fff96afcffe libLAPACK.dylib (1094.5) <7E7A9B8D-1638-3914-BAE0-663B69865986> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x7fff96b4b000 - 0x7fff96b67fff libresolv.9.dylib (54) <11C2C826-F1C6-39C6-B4E8-6E0C41D4FA95> /usr/lib/libresolv.9.dylib 0x7fff96baf000 - 0x7fff96d1dff7 libBLAS.dylib (1094.5) <DE93A590-5FA5-32A2-A16C-5D7D7361769F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x7fff96dac000 - 0x7fff96e0fffb com.apple.SystemConfiguration (1.13.1 - 1.13.1) <339A2A90-DA25-33AF-88E5-2FB38A758FEE> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x7fff96e10000 - 0x7fff97986ff7 com.apple.AppKit (6.9 - 1265.21) <9DC13B27-841D-3839-93B2-3EDE66157BDE> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x7fff97987000 - 0x7fff97a37ff7 libvMisc.dylib (423.32) <049C0735-1808-39B9-943F-76CB8021744F> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x7fff97a38000 - 0x7fff97a85ff2 com.apple.print.framework.PrintCore (9.0 - 428) <8D8253E3-302F-3DB2-9C5C-572CB974E8B3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x7fff97a86000 - 0x7fff97a9fff7 com.apple.Ubiquity (1.3 - 289) <C7F1B734-CE81-334D-BE41-8B20D95A1F9B> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity 0x7fff97b7f000 - 0x7fff97bf6fff com.apple.CoreServices.OSServices (600.4 - 600.4) <6BC86B46-AFD3-3F06-8659-2C954CBEBD43> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x7fff97bfa000 - 0x7fff97bfcff7 libquarantine.dylib (71) <7A1A2BCB-C03D-3A25-BFA4-3E569B2D2C38> /usr/lib/system/libquarantine.dylib 0x7fff97c51000 - 0x7fff97c51ffd libOpenScriptingUtil.dylib (157.1) <D3B6E577-3CDB-3139-9B94-19496DFA7318> /usr/lib/libOpenScriptingUtil.dylib 0x7fff97c8f000 - 0x7fff97de3ff3 com.apple.audio.toolbox.AudioToolbox (1.10 - 1.10) <69B273E8-5A8E-3FC7-B807-C16B657662FE> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x7fff97e59000 - 0x7fff97e9eff6 com.apple.HIServices (1.23 - 468) <FD17FE8C-A355-3B6B-B8B7-E56E5C595EDE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x7fff97e9f000 - 0x7fff97ea2ffc com.apple.IOSurface (91.3 - 91.3) <E93485CC-12B1-318E-BAE3-AB532B264935> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface 0x7fff9800a000 - 0x7fff9800affd com.apple.audio.units.AudioUnit (1.10 - 1.10) <68B21135-55A6-3563-A3D6-3E692A7DEB7F> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x7fff9826d000 - 0x7fff986a0ffb com.apple.vision.FaceCore (3.0.0 - 3.0.0) <F42BFC9C-0B16-35EF-9A07-91B7FDAB7FC5> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore 0x7fff986a1000 - 0x7fff986b9fff com.apple.openscripting (1.4.1 - 157.1) <2C6C6498-D88E-3D9B-B933-9873890F382E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x7fff9874e000 - 0x7fff989acff2 com.apple.RawCamera.bundle (5.06 - 753) <7315ED29-77A1-3990-9054-F00B96527C06> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera 0x7fff98ec3000 - 0x7fff98f0aff7 libcups.2.dylib (372.6) <CBD2F0CF-FA10-36E1-A1D5-1B946B45B3B3> /usr/lib/libcups.2.dylib 0x7fff98f0b000 - 0x7fff98f2fff7 libJPEG.dylib (1048) <3C999DC3-8A51-3CA9-9AB8-7F9DBA278FE6> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x7fff98f30000 - 0x7fff991a0ffd com.apple.security (7.0 - 55471.14.40) <58F50B4A-FC1E-3AE0-A5DB-DD737E50AC17> /System/Library/Frameworks/Security.framework/Versions/A/Security 0x7fff991a1000 - 0x7fff991d6fff libssl.0.9.8.dylib (52.8.4) <3F8ADCC3-AE3F-371C-A4D5-FF219D33E507> /usr/lib/libssl.0.9.8.dylib 0x7fff991d9000 - 0x7fff991e4ff7 com.apple.NetAuth (5.0 - 5.0) <C811E662-9EC3-3B74-808A-A75D624F326B> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth 0x7fff99263000 - 0x7fff99340fff libcrypto.0.9.8.dylib (52.8.4) <E03DB1E7-4CC6-3338-B67D-F69BE2FB28FC> /usr/lib/libcrypto.0.9.8.dylib 0x7fff99341000 - 0x7fff993adfff com.apple.framework.IOKit (2.0.1 - 907.100.14) <10932113-9F7E-38A0-A158-A019A555CAC3> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x7fff9943a000 - 0x7fff99441ff8 liblaunch.dylib (842.92.1) <A40A0C7B-3216-39B4-8AE0-B5D3BAF1DA8A> /usr/lib/system/liblaunch.dylib 0x7fff99442000 - 0x7fff99459ff7 com.apple.CFOpenDirectory (10.9 - 173.90.1) <D7F2E159-CF6B-3EB1-9806-3BC59E63D24F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory 0x7fff9946d000 - 0x7fff9959dff7 com.apple.desktopservices (1.8.3 - 1.8.3) <225BEC20-F8E0-3F22-9560-890A1A5B9050> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x7fff9959e000 - 0x7fff995afff7 libsystem_asl.dylib (217.1.4) <655FB343-52CF-3E2F-B14D-BEBF5AAEF94D> /usr/lib/system/libsystem_asl.dylib 0x7fff995b0000 - 0x7fff995b2ff7 com.apple.securityhi (9.0 - 55005) <0CB82072-BA4B-357B-BE46-A96D317C1D91> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x7fff996d6000 - 0x7fff996e2ffb com.apple.AppleFSCompression (56.92.2 - 1.0) <16542F97-9D21-317D-8A50-4C34AAD35F41> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression 0x7fff996e3000 - 0x7fff99708ff7 com.apple.ChunkingLibrary (2.0 - 155.1) <B845DC7A-D1EA-31E2-967C-D1FE0C628036> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary 0x7fff99709000 - 0x7fff9970afff com.apple.TrustEvaluationAgent (2.0 - 25) <334A82F4-4AE4-3719-A511-86D0B0723E2B> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent 0x7fff9970d000 - 0x7fff9973efff com.apple.MediaKit (15 - 709) <23E33409-5C39-3F93-9E73-2B0E9EE8883E> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit External Modification Summary: Calls made by other processes targeting this process: task_for_pid: 1 thread_create: 0 thread_set_state: 0 Calls made by this process: task_for_pid: 0 thread_create: 0 thread_set_state: 0 Calls made by all processes on this machine: task_for_pid: 4652 thread_create: 0 thread_set_state: 0 VM Region Summary: ReadOnly portion of Libraries: Total=242.9M resident=65.5M(27%) swapped_out_or_unallocated=177.4M(73%) Writable regions: Total=146.6M written=15.2M(10%) resident=67.2M(46%) swapped_out=0K(0%) unallocated=79.4M(54%) REGION TYPE VIRTUAL =========== ======= CG backing stores 8760K CG image 80K CG raster data 104K CG shared images 212K CoreImage 8K IOKit 46.2M IOKit (reserved) 4K reserved VM address space (unallocated) Kernel Alloc Once 8K MALLOC 62.8M MALLOC (admin) 32K Memory Tag 242 12K Memory Tag 251 8K OpenCL 20K OpenGL GLSL 1664K SQLite page cache 256K STACK GUARD 56.0M Stack 11.2M VM_ALLOCATE 16.5M __DATA 43.1M __IMAGE 528K __LINKEDIT 75.6M __TEXT 167.3M __UNICODE 544K mapped file 51.2M shared memory 68K =========== ======= TOTAL 541.9M TOTAL, minus reserved VM space 541.9M On 13/07/16 16:34, Marius Kintel wrote: > Hi Benjamin, > > Thanks for reporting; development snapshots do have the occasional weird behavior. > This does, however, work for me, so some more info would be very helpful. > > I assume it actually crashes, not just quits. Are you able to find a crash log in the console (Console.app) ? > > I suspect this to be related to running on a relatively old version of OS X. We do support 10.9, we just don’t have regular tests running in that environment. If you can provide a crash log, it would be easier for me to dig into it. > > -Marius > > >> On Jul 13, 2016, at 09:32 AM, Benjamin <benjamin@chaaawa.com> wrote: >> >> Hi, >> >> Sorry if this has already been mentioned. >> The example below works fine with 2016.03.26. It makes the latest version quit on Preview and Render. >> I've hesitated to attach the problem report, thinking that you might prefer to reproduce it. >> >> Benjamin >> >> >> //-------------------------------------------- >> $fn=12; >> >> hull() { >> cylinder(r=1, h=6, center=true); >> translate([6, 0, 0]) >> cylinder(r=1, h=6, center=true); >> } >> //-------------------------------------------- >> >> >> >> It can be reduced to: >> hull() { >> cylinder(); >> } >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Wed, Jul 13, 2016 3:42 PM
On Jul 13, 2016, at 11:35 AM, Benjamin benjamin@chaaawa.com wrote:
Thanks,
Thx,
We did make some changes in the latest snapshot, most notably discontinuing support for 10.7. It could be that we accidentally broke 10.9 support.
I’ll see if I can dig up a 10.9 VM to test with.
> On Jul 13, 2016, at 11:35 AM, Benjamin <benjamin@chaaawa.com> wrote: > > Thanks, > Here is the crash report (on Preview): > Thx, We did make some changes in the latest snapshot, most notably discontinuing support for 10.7. It could be that we accidentally broke 10.9 support. I’ll see if I can dig up a 10.9 VM to test with. -Marius
