I can't open 2019.02.20 (macOS 10.11.6)
B
Benjamin
Thu, Feb 21, 2019 9:02 AM
There's no crash, nothing happens after right-click open.
Weird (when you don't know what's going on) I can no longer open 2019.01.30.
But 2018.11.25 is fine.
I've found those errors in system.log:
Feb 21 09:21:23 Peurls-MacBook-Pro com.apple.xpc.launchd[1]
(org.openscad.OpenSCAD.391712[684]): Service exited with abnormal code: 1
Feb 21 09:21:30 Peurls-MacBook-Pro com.apple.xpc.launchd[1]
(org.openscad.OpenSCAD.391072[685]): Service exited with abnormal code: 1
It has been relevant by the past, maybe I should mention that it's a
2007 MacBook Pro, can't go highier than 10.11. It's perfectly acceptable
for me to stay with 2018.11.25
Benjamin
Hi, There's no crash, nothing happens after right-click open. Weird (when you don't know what's going on) I can no longer open 2019.01.30. But 2018.11.25 is fine. I've found those errors in system.log: Feb 21 09:21:23 Peurls-MacBook-Pro com.apple.xpc.launchd[1] (org.openscad.OpenSCAD.391712[684]): Service exited with abnormal code: 1 Feb 21 09:21:30 Peurls-MacBook-Pro com.apple.xpc.launchd[1] (org.openscad.OpenSCAD.391072[685]): Service exited with abnormal code: 1 It has been relevant by the past, maybe I should mention that it's a 2007 MacBook Pro, can't go highier than 10.11. It's perfectly acceptable for me to stay with 2018.11.25 Benjamin
Thu, Feb 21, 2019 2:43 PM
Would you mind opening a ticket?
These following things would be helpful:
  • What exact CPU do you have?
  • Can you find a stack trace, e.g in Console.app?
  • Do you see any output when running OpenSCAD on the cmd-line?
Benjamin
Would you mind opening a ticket? These following things would be helpful: * What exact CPU do you have? * Can you find a stack trace, e.g in Console.app? * Do you see any output when running OpenSCAD on the cmd-line? -Marius > On Feb 21, 2019, at 04:02, Benjamin <benjamin@chaaawa.com> wrote: > > Hi, > > There's no crash, nothing happens after right-click open. > Weird (when you don't know what's going on) I can no longer open 2019.01.30. > But 2018.11.25 is fine. > > I've found those errors in system.log: > Feb 21 09:21:23 Peurls-MacBook-Pro com.apple.xpc.launchd[1] (org.openscad.OpenSCAD.391712[684]): Service exited with abnormal code: 1 > Feb 21 09:21:30 Peurls-MacBook-Pro com.apple.xpc.launchd[1] (org.openscad.OpenSCAD.391072[685]): Service exited with abnormal code: 1 > > It has been relevant by the past, maybe I should mention that it's a 2007 MacBook Pro, can't go highier than 10.11. It's perfectly acceptable for me to stay with 2018.11.25 > > Benjamin > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
B
Benjamin
Thu, Feb 21, 2019 3:17 PM
OK
2.4 GHz Intel Core 2 Duo
All I've found with Console are the two lines in my previous message.
Nothing in "Diagnostic and usage information".
Sorry, "OpenSCAD" can not be run on this version of macOS. Qt requires
macOS 10.12.0 or later, you have macOS 10.11.6.
Benjamin
Benjamin
> Would you mind opening a ticket? OK > These following things would be helpful: > * What exact CPU do you have? 2.4 GHz Intel Core 2 Duo > * Can you find a stack trace, e.g in Console.app? All I've found with Console are the two lines in my previous message. Nothing in "Diagnostic and usage information". > * Do you see any output when running OpenSCAD on the cmd-line? Sorry, "OpenSCAD" can not be run on this version of macOS. Qt requires macOS 10.12.0 or later, you have macOS 10.11.6. Benjamin > > -Marius > > >> On Feb 21, 2019, at 04:02, Benjamin <benjamin@chaaawa.com> wrote: >> >> Hi, >> >> There's no crash, nothing happens after right-click open. >> Weird (when you don't know what's going on) I can no longer open 2019.01.30. >> But 2018.11.25 is fine. >> >> I've found those errors in system.log: >> Feb 21 09:21:23 Peurls-MacBook-Pro com.apple.xpc.launchd[1] (org.openscad.OpenSCAD.391712[684]): Service exited with abnormal code: 1 >> Feb 21 09:21:30 Peurls-MacBook-Pro com.apple.xpc.launchd[1] (org.openscad.OpenSCAD.391072[685]): Service exited with abnormal code: 1 >> >> It has been relevant by the past, maybe I should mention that it's a 2007 MacBook Pro, can't go highier than 10.11. It's perfectly acceptable for me to stay with 2018.11.25 >> >> Benjamin >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Thu, Feb 21, 2019 3:20 PM
Thanks, that was the key.
This is likely a build issue, as we've recently added a few more dependencies. I'll see if I can locate an older Mac VM and do some testing.
A ticket to track this would still be useful!
FYI: Our goal is to support 10.9 and up.
On Feb 21, 2019, at 10:17, Benjamin <benjamin@chaaawa.com> wrote: > > Sorry, "OpenSCAD" can not be run on this version of macOS. Qt requires macOS 10.12.0 or later, you have macOS 10.11.6. > Thanks, that was the key. This is likely a build issue, as we've recently added a few more dependencies. I'll see if I can locate an older Mac VM and do some testing. A ticket to track this would still be useful! FYI: Our goal is to support 10.9 and up. -Marius
B
Benjamin
Thu, Feb 21, 2019 3:40 PM
> A ticket to track this would still be useful! https://github.com/openscad/openscad/issues/2805 Thank you. Benjamin
