On Thu, Jul 21, 2022 at 06:04:40AM -0700, Jordan Brown wrote:
A larger sample, a filial for a curtain rod, yields 176,000 instructions
using a simple infill and 551,000 instructions with a gyroid infill.
That's the simple approach to converting Gcode to SCAD.
Still some "processing" is required. How thick and wide a layer are
you depositing? That's detmined by the previous layer! Some
configuration would be required: For 1mm of extrusion distance, how
much volume of plastic is extruded?
Anyway, To get something realistic, much more processing would need to
be done: recognize outer peripherals and connect the dots. Simplify.
A much more non-trivial job than just assuming a .4 x .2mm extruded box
for every move-with-extrusion.
Yes.
It's hard (because of the data volume, but also because of the extrusion
characteristics you describe) to do a naïve job.
It's much harder (because of the need to recognize the overall shape of
the object) to do anything better.
I vaguely remember there is a program to go from gcode to STL but I can't
remember the name or if it is free.
On Thu, 21 Jul 2022 at 17:25, Jordan Brown openscad@jordan.maileater.net
Yes.
can't remember the name or if it is free.
Lots of hits on Google. Search "gcode to stl" (with quotes).
