Oh, that makes sense. So it's really caused by invalid arguments to
polyhedron. We should change polyhedron to report when you pass illegal
arguments.
On 17 March 2016 at 19:49, Torsten Paul Torsten.Paul@gmx.de wrote:
On 03/18/2016 12:32 AM, unkerjay wrote:
The import() statements cause the issue because those are the
only thing that force actual mesh calculation by the difference().
Without, there is no CGAL call at all. Even just placing a cube()
into the write functions produces the same effect.
I think the reason is that the model (the polyhedron) is not
a solid object but just an illusion and so it only works in
preview mode.
@Doug:
I'm not generalizing. Sometimes it shows up. Sometimes it doesn't.
When it DOES (and it has on at least one other polyhedra), I've tried
removing
this code and that fixed it.
It may not always be the culprit. But, there's no real harm in trying and
seeing
what happens.
If it resolves the problem, fine.
If not, well, one less thing to try.
View this message in context: http://forum.openscad.org/Previews-but-doesn-t-render-tp16511p16568.html
Well, the source code for the Ditrigonal Dodecacronic Hexecontahedron that
you posted was automatically generated by Kit Wallace's program, based on
polyhedron data from http://dmccooey.com/polyhedra/. In fact, the
polyhedron was generated automatically, on the fly, by accessing that URL
on Kit's web site. So it's reasonable to guess that Kit hasn't actually
tested all of the possible scad scripts that his program can generate.
Certain kinds of errors in the polyhedron data cause the polyhedron itself
to apparently preview and render okay, but when you attempt a CSG operation
(like difference()) then you get an error message or nonsense results.
I'm assuming that Torsten is right. That means some of the polyhedron data
files on dmccooey's web site are "not 2-manifold", which is a technical
term meaning bad. The bug is actually in dmccooey's data, although it's
also bad that OpenSCAD sucks at reporting bad arguments to polyhedron().
On 18 March 2016 at 15:12, unkerjay unkerjay@centurylink.net wrote:
@Doug:
removing
seeing
what happens.
Been a LONG time, it probably applies here:
GIGO
(bad data, bad outcome - (BDBO?)
View this message in context: http://forum.openscad.org/Previews-but-doesn-t-render-tp16511p16571.html
On Fri, 18 Mar 2016 14:56:07 -0700 (MST)
GIGO
Garbage in, gospel out? <grin/>
Reality is just a convenient measure of complexity.
-- Alvy Ray Smith
