Hello, i want to ask in what unit the program calulates the dimensions of an
object .
example :
cube({10,10,10])
Is this means that cube 10mm by 10 mm by10mm,or by anthor unit like cm ?
View this message in context: http://forum.openscad.org/Calulate-REal-Dimensions-tp12424.html
OpenSCAD (and the STL file format) are dimension-less, so “10” means whatever you want it to mean.
That’s why you need to specify your units when you upload models to services like Shapeways.
object .
example :
cube({10,10,10])
OpenSCAD does not need to work with a specific unit of distance, you can make
that decision for yourself.
When importing an STL created with OpenSCAD, the importing program will
typically ask how to interpret the units in the file, as cm or mm for
instance.
View this message in context: http://forum.openscad.org/Calulate-REal-Dimensions-tp12424p12426.html
Presently, most people interpret one unit of OpenSCAD to 1mm.
2015-04-19 17:04 GMT+02:00 Ivo ivo.knutsel@gmail.com:
make
instance.
schreiben.
Enjoy!
Except for some really backward peoples who use inch or thou (inch/1000) or
worse describe that as a mil (not to be confused with mill).
View this message in context: http://forum.openscad.org/Calulate-REal-Dimensions-tp12424p12434.html
