Is it possible to conditionally enable/disable operations without duplicating
the code? For example render some 3d objects while previewing others within
the same OpenSCAD file if a variable is set, something like this;
$renderit=1
color("Green")
if($renderit ? render() )
cube([5,5,5]); //Render this if $renderit=1
color("Blue")
cube([3,3,3]); //Always preview this unless F6 is used
instead of what I end up doing;
$renderit=1
if($renderit) {
color("Green")
render()
} else {
color("Green")
cube([5,5,5]);
color("Blue")
I guess I could make a "proxy" module and go through that. Any other ideas?
$renderit=1;
module renderfunc() {
if ($renderit) {
color("Green")
render()
} else {
color("Blue")
renderfunc() cube([5,5,5]); //Render this if $renderit=1
Yes that is the way I would would apply conditional operations without
duplication. Example here:
https://github.com/nophead/NopSCADlib/blob/34a9b0e87bd5bc7fb301c2f409381d120799a77e/utils/core/bom.scad#L54
The other way is to wrap the duplicated code in a module so it can be used
in both paths of the if. The module can be nested inside another. An
example here:
https://github.com/nophead/NopSCADlib/blob/34a9b0e87bd5bc7fb301c2f409381d120799a77e/vitamins/toggle.scad#L150
$renderit=1;
if ($renderit) {
color("Green")
render()
} else {
color("Blue")
I went for this approach as well. My proxy module does pretty much
everything, conditionally...:
The hull case is particularly ugly. It is possible there is a better
way to do this in general now, I ran into the same problem
intersection_for solves, which is that for iterations are implicitly
grouped, which makes it difficult to handle things like intersection
and hull. Openscad could use some sort of ungrouped for loop
(intersection_for wouldn't be necessary then, I don't think).
Something like Bash's "$@" expansion, which solves a similar problem
module draw(hide = false, shadow = false, highlight = false, singular
= false, render = false, difference = false, intersection = false,
hull = false, minkowski = false, union = true, color, alpha,
convexity) {
if (!hide) {
if (!is_undef(color) || !is_undef(alpha)) {
color(color, alpha = alpha) {
draw(shadow = shadow, highlight = highlight, singular =
singular, render = render, difference = difference, intersection =
intersection, hull = hull, minkowski = minkowski, union = union,
convexity = convexity) {
if ($children > 0) {
children(0);
if ($children > 1) {
if (intersection) {
intersection_for (i = [1 : $children - 1]) {
children(i);
} else {
children(i);
} else if (singular) {
!draw(shadow = shadow, highlight = highlight, render = render,
difference = difference, intersection = intersection, hull = hull,
minkowski = minkowski, union = union, convexity = convexity) {
children(0);
if (intersection) {
children(i);
} else {
children(i);
} else if (shadow) {
%draw(render = render, difference = difference, intersection =
children(0);
if (intersection) {
children(i);
} else {
children(i);
} else if (highlight) {
#draw(render = render, difference = difference, intersection =
children(0);
if (intersection) {
children(i);
} else {
children(i);
} else if (render) {
render(convexity = convexity) {
draw(difference = difference, intersection = intersection,
hull = hull, minkowski = minkowski, union = union) {
children(0);
if (intersection) {
children(i);
} else {
children(i);
} else if (difference) {
children(0);
children(i);
} else if (minkowski) {
minkowski() {
children(0);
children(i);
} else if (intersection) {
children(0);
children(i);
} else if (hull) {
hull() {
children(0);
children(1);
if ($children > 2) {
children(2);
if ($children > 3) {
children(3);
if ($children > 4) {
children(4);
if ($children > 5) {
children(5);
if ($children > 6) {
children(6);
if ($children > 7) {
children(7);
if ($children > 8) {
children(8);
if ($children > 9) {
children(9);
if ($children > 10) {
children(10);
if ($children > 11) {
children(11);
if ($children > 12) {
for (i = [12 : $children - 1]) {
children(i);
} else if (union) {
for (i = [0 : $children - 1]) {
children(i);
} else {
children(i);
On Fri, Jun 14, 2019 at 6:48 AM nop head nop.head@gmail.com wrote:
Yes that is the way I would would apply conditional operations without duplication. Example here: https://github.com/nophead/NopSCADlib/blob/34a9b0e87bd5bc7fb301c2f409381d120799a77e/utils/core/bom.scad#L54
The other way is to wrap the duplicated code in a module so it can be used in both paths of the if. The module can be nested inside another. An example here: https://github.com/nophead/NopSCADlib/blob/34a9b0e87bd5bc7fb301c2f409381d120799a77e/vitamins/toggle.scad#L150
$renderit=1;
if ($renderit) {
color("Green")
render()
} else {
color("Blue")
Why is
hull() { ... }
different from
hull() { union { ... } }
Hull just stretches shrink plastic over its children; why does it matter
whether they are one object or many?
Because hull is fast but union is very slow, so you have to avoid any
implicit unions in hull's children.
On Fri, 14 Jun 2019 at 17:08, Jordan Brown openscad@jordan.maileater.net
Why is
hull() { ... }
different from
That may well have been the problem
On Fri, Jun 14, 2019 at 12:20 PM nop head nop.head@gmail.com wrote:
Because hull is fast but union is very slow, so you have to avoid any implicit unions in hull's children.
On Fri, 14 Jun 2019 at 17:08, Jordan Brown openscad@jordan.maileater.net wrote:
Why is
hull() { ... }
different from
Hull just stretches shrink plastic over its children; why does it matter whether they are one object or many?
