Hi Guys,
I was watching the horrors of the memory use of Chrome, and the
developers there always say, but you need to look at RESident size:
actual use is a lot less. So chrome processes vary between 100 and
800Mb resident memory in use.
Then I saw an odd one out: Openscad: 1.8G ! (and anohter one at 1.0G).
Is it normal for openscad to use that much memory? I haven't touched
them for days...
(By the way: It's my OS's fault to have not swapped most of those
processes out, but getting THAT improved is not going to happen
anytime soon).
(one openscad may have a design loaded with 169 copies of a
button-cap).
them for days...
In my experience yes. OpenSCAD uses lots of memory. It also has a
deliberately included cache to speed up future operations. That (rightly)
isn't thrown away over time but will get swapped out if needed.
anytime soon).
It's probbly not swapped that out because either
or some combination of the three.
What happens if you send it a SIGSTOP and then run other memory heavy
stuff to fill the system memory ?
Alan
Yes, OpenSCAD can use a lot of memory. If you keep changing a model old
bits of the geometry are held in the cache. Sometimes I have to close and
reopen it if I have been working on something for a few days.
On Thu, 8 Oct 2020 at 15:43, Rogier Wolff R.E.Wolff@bitwizard.nl wrote:
Hi Guys,
them for days...
anytime soon).
button-cap).
(rightly) isn't thrown away over time but will get swapped out if needed.
Hey, internals people: is the cache arranged so that the large stuff
(the actual geometry) is kept separately from the smaller stuff (the
metadata that you would match against to select a cache entry)?
I don't know how applicable that is, or how practical it is with typical
memory allocators, but it seems like it would be useful. You could have
a gigabyte of geometry cached, but because you never look at it,
because the metadata doesn't match what you're doing now, it could all
be paged out.
You specify cache sizes in Preferences.
You can also use Design/Flush-caches.
You can see cache size in console after F5/F6.
I set my sizes big and let the OS page out if it needs to.
But I have fast SSD's, when I was on HDD paging was painful.
Buy more memory!
Thanks, but doesn't answer the question.
I'm assuming that a cache entry consists of two parts:
(1) metadata that can be used to identify matching geometry. Exactly
what that looks like I don't know, but whatever it is that you use to
index into the cache to find cached data.
(2) the actual cached data. Triangle soup?
I'm assuming that the actual cached data is much larger than the index
metadata.
Assuming that all of those assumptions are correct, a cache entry might
be arranged in two different structures:
(a) a single memory allocation that contains both metadata and actual
cached data.
(b) a memory allocation that contains metadata, and another that
contains the actual cached data.
You want (b). You don't want the metadata to be "near" the actual
cached data. If the metadata is "near" the actual cached data, then
(maybe) merely searching for a cache hit will mark the page containing
the cache data as recently accessed, and keep it from being paged out.
You want the actual cache data to be kept away from anything that gets
touched on a routine basis, so that if it isn't actually used it's kept
paged out. If it's all mixed up in stuff that gets routinely touched,
then it's more likely to get pulled into RAM and kept in RAM.
Another possible structure is that the cache data consists of a lot of
small allocations, totally mixed in with other allocations. That would
probably be the worst of all worlds, because it would mean that your
cache data would be "diluting" the stuff that you access all the time,
keeping more pages in RAM than really need to be there.
Does that make sense now?
There are two major caches in OpenSCAD, CGALCache f and GeometryCache
for Nef and non-Nef geometry respectively.
Both implement src/cache.h, mapping everything to a
std::unordered_map<std::string, struct with ptr to struct with shared_ptr<data> >
There is no special allocator defined for these unordered_maps.
So to answer your Question:
It is more related yo tour strategy (b), but not entirely, because it is
not all "in a single memory location", but structured as hash bucket map
for fast cache lookups.
So it can be said: There is no explicit swap-friendly implementation of
the general internal data structures.
If you want to help investigate if a better allocation strategy would
help your general workflow, you can start your openscad with
tcmalloc-preloads[1],[2] and tell us if it you can see any difference
for your large projects.
tcmalloc has a better heap locality for similar sized objects and shows
different heap usage, sometimes "better", maybe also in this case..
[1] Overview: https://google.github.io/tcmalloc/overview.html
[2] How to Preload: https://gperftools.github.io/gperftools/tcmalloc.html
metadata.
might be arranged in two different structures:
cached data.
kept paged out. If it's all mixed up in stuff that gets routinely
touched, then it's more likely to get pulled into RAM and kept in RAM.
would probably be the worst of all worlds, because it would mean that
your cache data would be "diluting" the stuff that you access all the
time, keeping more pages in RAM than really need to be there.
I have a 32G workstation and I have definitely watched, nervously, while
openscad grew to 20G during a render. Well, I have a lot of points in my
polygons...
I started out trying to fire up 3 or 4 instances of openscad to get faster
rendering, but the instances silently blew off when memory ran out. Just
luckily I noticed how big they were, and I could only accommodate one at a
time!
richalt2 (so why does the forum show me as OpenSCAD mailing list?)
Rich Altmaier
