Sat, Jan 28, 2023 6:48 PM
Good day! I am attempting to use NopSCADlib to model a PC board and I have
some questions. Is it just me, or is the documentation for modeling PC
boards a bit sparse?
I spent most of yesterday examining the PC board example. It seems that you
start by building a PC board descriptor that is a list of the board
characteristics and includes a sublist of the components that you wish to
place on the board. For example, here is the list of components from the
example LIPO_fuel_gauge board:
[ // components*
[17, 5, 90, "jst_ph", 2, true],*
[2.54 + 5.27, 1.5 * 2.54 + 5, 0, "-2p54joiner", 3, 1],*
[2.54 + 5.27, -1.5 * 2.54 + 5, 0, "-2p54joiner", 3, 1],*
[3 * 2.54 + 5.27, 5, 0, "-2p54joiner", 1, 2],*
[6.4 + 1.5, 5, 0, "chip", 3, 2, 0.8],*
[1.2, 2.5, 90, "smd_res", RES0603, "472"],*
[2.4, 2.5, 90, "smd_res", RES0603, "472"],*
[1.2, -2.5, 90, "smd_res", RES0603, "472"],*
[2.4, -2.5, 90, "smd_res", RES0603, "472"],*
[10.35, -4, -90, "smd_res", RES0603, "181"],*
[10.35, 4, -90, "smd_res", RES0603, "102"],*
[12.89, 1.5 * 2.54 + 5, 0, "smd_cap", CAP0603, 0.85],*
[12.89,-1.5 * 2.54 + 5, 0, "smd_cap", CAP0603, 0.85],*
I have inferred from the examples that the first three values for each
component specify the X offset, the Y offset, and any rotation angle.
The fourth value is the type of component and if the first character of the
type is “-”, the part is to be placed on the bottom of the board.
The remaining values are specific to the type of component. The difficulty
I’m having is determining the string type of the part and the remaining
parameters. From what I can tell, this is the process for determining
those values:
- First, based on the component that you wish to place, search
through the module
pcb_component() in vitamins/pcb.scad to find the string name for the
component. For example, let’s say I wanted to place a surface mounted
capacitor. In pcb_component() I find the line:
if(show(comp, "smd_cap")) smd_capacitor(comp[4], comp[5], param(6,
undef));
…so I know that the component entry will be made up of seven values. So
far, then the entry is:
[ offsetX, offsetY, rotation, “smd_cap”, … ],
- Now I search for the TWO library files that contain the info that I need
for the remaining values. For this example, these are vitamins/smds.scad
and vitamins/smd.scad.
In vitamin/smds.scad I find:
CAP0603 = ["CAP0603", [1.6, 0.8], 0.3];
CAP0805 = ["CAP0805", [2.0, 1.2], 0.4];
CAP1206 = ["CAP1206", [3.1, 1.6], 0.5];
These are the predefined package types that I can choose from. In this
example, I will use CAP0603 (even though, at this point I have no idea what
the numbers [1.6, 0.8], 0.3] refer to.
Now my component descriptor is:
[ offsetX, offsetY, rotation, “smd_cap”, CAP0603 … ]
- Now I look in vitamins*/smd.scad*. I find:
function smd_cap_size(type) = type[1]; //! Body length, width
function smd_cap_end_cap(type) = type[2]; //! End cap width
Now I know what those numbers ( [1.6, 0.8], 0.3] refer to: length, width
and end cap width.
- I also see:
module smd_capacitor(type, height, value = undef) { //! Draw an SMD
capacitor with specified height
Now, I finally know what the last two values of the component descriptor
need to be: Height and an optional capacitance value.
So, my component descriptor is now:
[ offsetX, offsetY, rotation, “smd_cap”, CAP0603, 0.85 ]
- If I wanted to specify the capacitance value, I still don’t know if I
should specify a numeric value (1000), or a string value (“1000”), or a
string description (“1000uF”).
Q. Is there an easier way to create such a component descriptor?
Thanks! Len
* [ // components*
* [17, 5, 90, "jst_ph", 2, true],*
* [2.54 + 5.27, 1.5 * 2.54 + 5, 0, "-2p54joiner", 3, 1],*
* [2.54 + 5.27, -1.5 * 2.54 + 5, 0, "-2p54joiner", 3, 1],*
* [3 * 2.54 + 5.27, 5, 0, "-2p54joiner", 1, 2],*
* [6.4 + 1.5, 5, 0, "chip", 3, 2, 0.8],*
* [1.2, 2.5, 90, "smd_res", RES0603, "472"],*
* [2.4, 2.5, 90, "smd_res", RES0603, "472"],*
* [1.2, -2.5, 90, "smd_res", RES0603, "472"],*
* [2.4, -2.5, 90, "smd_res", RES0603, "472"],*
* [10.35, -4, -90, "smd_res", RES0603, "181"],*
* [10.35, 4, -90, "smd_res", RES0603, "102"],*
* [12.89, 1.5 * 2.54 + 5, 0, "smd_cap", CAP0603, 0.85],*
* [12.89,-1.5 * 2.54 + 5, 0, "smd_cap", CAP0603, 0.85],*
those values:
1. First, based on the component that you wish to place, search
through the *module
pcb_component()* in *vitamins/pcb.scad* to find the string name for the
capacitor. In *pcb_component()* I find the line:
*if(show(comp, "smd_cap")) smd_capacitor(comp[4], comp[5], param(6,
undef));*
*[ offsetX, offsetY, rotation, “smd_cap”, … ],*
2. Now I search for the TWO library files that contain the info that I need
for the remaining values. For this example, these are *vitamins/smds.scad*
and *vitamins/smd.scad*.
In *vitamin/smds.scad* I find:
*CAP0603 = ["CAP0603", [1.6, 0.8], 0.3];*
*CAP0805 = ["CAP0805", [2.0, 1.2], 0.4];*
*CAP1206 = ["CAP1206", [3.1, 1.6], 0.5];*
*[ offsetX, offsetY, rotation, “smd_cap”, CAP0603 … ]*
3. Now I look in *vitamins**/smd.scad*. I find:
*function smd_cap_size(type) = type[1]; //! Body length, width*
*function smd_cap_end_cap(type) = type[2]; //! End cap width*
and end cap width.
4. I also see:
*module smd_capacitor(type, height, value = undef) { //! Draw an SMD
capacitor with specified height*
*[ offsetX, offsetY, rotation, “smd_cap”, CAP0603, 0.85 ]*
5. If I wanted to specify the capacitance value, I still don’t know if I
*Q. Is there an easier way to create such a component descriptor?*
Thanks! Len
Sat, Jan 28, 2023 7:52 PM
Hi Len,
You seem to have worked out all the details apart from the value is just
a optional string to go on the BOM.
CAP0603 is just a capacitor with a standard 0603 footprint. The number is
just the width and length in 100th of an inch. The numbers in the
descriptor are the size in mm. Unlike SMT resistors, the height of
capacitors varies with the value and voltage rating, so it is specified
with a parameter.
There isn't individual documentation for the components but there is an
example PCB with an instance of each one shown under the PCB heading and a
link to the code. I just noticed that the SMT capacitors don't have values,
so I will add some.
Crystals are on my todo list but they are radial components, so a new a
new vitamin type, that has to cope with the wires having a double bend to
match the hole pitch when mounted on veroboard.
I agree the documentation could be better. The individual component
modules get auto documented but the connection to list of parameters in the
PCB description is missing because it isn't auto documented.
Regards, Chris
On Sat, 28 Jan 2023 at 18:49, Leonard Martin Struttmann <
you start by building a PC board descriptor that is a list of the board
[ // components*
the type is “-”, the part is to be placed on the bottom of the board.
difficulty I’m having is determining the string type of the part and the
remaining parameters. From what I can tell, this is the process for
determining those values:
- First, based on the component that you wish to place, search through
the module pcb_component() in vitamins/pcb.scad to find the string
name for the component. For example, let’s say I wanted to place a surface
mounted capacitor. In pcb_component() I find the line:
undef));
need for the remaining values. For this example, these are
vitamins/smds.scad and vitamins/smd.scad.
and end cap width.
- I also see:
Thanks! Len
Hi Len,
with a parameter.
so I will add some.
Regards, Chris
> * [ // components*
> 1. First, based on the component that you wish to place, search through
> the *module pcb_component()* in *vitamins/pcb.scad* to find the string
> mounted capacitor. In *pcb_component()* I find the line:
> undef));*
> *vitamins/smds.scad* and *vitamins/smd.scad*.
> and end cap width.
> 4. I also see:
> Thanks! Len
Sun, Jan 29, 2023 12:04 AM
Hi Len,
is just the width and length in 100th of an inch. The numbers in the
with a parameter.
so I will add some.
Regards, Chris
have some questions. Is it just me, or is the documentation for modeling
PC boards a bit sparse?
[ // components*
undef));
and end cap width.
- I also see:
Thanks! Len
Thanks, Chris!
On Sat, Jan 28, 2023 at 1:53 PM nop head <nop.head@gmail.com> wrote:
> Hi Len,
> with a parameter.
> so I will add some.
> Regards, Chris
>> * [ // components*
>> undef));*
>> and end cap width.
>> 4. I also see:
>> Thanks! Len
Sun, Jan 29, 2023 3:00 PM
On Sat, Jan 28, 2023 at 07:52:36PM +0000, nop head wrote:
Unlike SMT resistors, the height of capacitors varies with the value
and voltage rating, so it is specified with a parameter.
about two weeks ago I bought some 7W SMT resistors and they are quite
a bit thicker than I expected. That said for getting a 3D impression
of a PCB, that's not very relevant.
I just noticed that the SMT capacitors don't have values, so I will
add some.
I think that is because the "472" is the text on the resistor.
SMT capacitors normally don't have any text printed on them.
> add some.
Sun, Jan 29, 2023 3:09 PM
Yes the value doesn't show on the capacitor but it goes on the BOM if
present and the PCB has the parts on BOM property set to true. So if you
make your own PCB or veroboard assembly you can get a BOM but if you buy
one ready made you don't need the components on the BOM, just the PCB.
I have never seen 7W SMT resistors, what footprint are they on? The
dissipation is mostly to do with surface area, rather than thickness. I.e.
making them thicker would not dissipate much more power.
add some.
> > add some.
> Roger.
> ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110
> f equals m times a. When your f is steady, and your m is going down
Sun, Jan 29, 2023 3:34 PM
Yup.
They are Humungous compared to what you normally see. I looked it up:
4527 is the size code. (I'd written "2512 IIRC" first. Well I did NOT
remember correctly... :-) )
Yup.
Sun, Jan 29, 2023 5:05 PM
They seem to be 11.5 by 7mm and either 1.8mm thick or 2.5mm thick. They
have a heatsink pad in the middle though but you can't see that when
mounted.
They seem to be only very low value current sense resistors, so not quite
the same as normal SMT resistors. Do you want one added to the library?
Yup.
mounted.
> I.e.
> Yup.
> Roger.
Mon, Jan 30, 2023 11:19 AM
mounted.
No, not for me. I usually have enough of an idea what my PCB will look
like. And instead of learning how to use the generic stuff I usually just
do things by hand. e.g.
color ("green") difference () {
cube ([100,50,1.6]);
translate ([3,3,-1]) cylinder (d=3, h=5);
translate ([97,3,-1]) cylinder (d=3, h=5);
translate ([97,47,-1]) cylinder (d=3, h=5);
translate ([3,47,-1]) cylinder (d=3, h=5);
translate ([45.43,12.6,1.6]) color ("darkgrey") cylinder (d=10, h=20);
to check the height of the capacitor and the position of the mounting
holes.
A thermal pad??? Hmm. The PCB doesn't have that. :-(
It is going to be a replacement current-sense-resistor for a
KA3005D lab power supply that I blew up.
> mounted.
holes.
Mon, Jan 30, 2023 11:24 AM
How did you blow it up? It is supposed to have overload protection being a
lab supply.
mounted.
holes.
lab supply.
> > mounted.
> holes.
> Roger.
Mon, Jan 30, 2023 12:19 PM
lab supply.
Apparently it can't handle that you reverse-connect an empty 1200Wh
lithium battery. Who would have thought? :-)
There is a diode that should prevent the voltage going "too negative"
on the positive output terminal. That blew. And the current sense
resistor blew (to pieces!). I'm hoping that's all.
At say 100A, 1kW, the resistor would dissipate enough to start melting
and failing in seconds. It didn't do that. It exploaded. About a kA I'd
guess.
> lab supply.
guess.
