Torsten:
I explained why I think they are useful; you just said "no". Please
explain yourself
On 3/25/2020 2:43 PM, Torsten Paul wrote:
On 25.03.20 19:37, jon wrote:
Does the compiler have source code pragmas, so that you can
say "this code uses lazy unions"?
No, and I don't think it should have one.
said "no". Please explain yourself
Please see that issue for the discussion:
https://github.com/openscad/openscad/issues/3142
Thank you for the confirmation.
Since my original path is blocked, and I would prefer not to use a solution
that will be broken in the future, I have found an alternate way forward.
The attached code shows an alternate, working solution to the problem I was
trying to solve:
Drivers=[
[3.81,34.55,7.18,13.9],//Largest Philips Jewelers Screwdriver
[2.98,30.02,6.19,12.81],
[2.38,25,5.52,11.62],
[1.97,20.85,4.5,10.49],
[1.57,18.47,3.85,9.46],
[1.37,17.35,3.27,8.53] //Smallest Philips Jewelers Screwdriver
Disperse(n=len(Drivers)-1,Drivers=Drivers,Position=5);
module Disperse(n=3,Index=0,Drivers,Position=0){
translate([Position,0,0])DriverHole(Driver=Drivers[Index]);
if(n>0){
Disperse(n=n-1,Index=Index+1,Drivers=Drivers,Position=Position+10+Drivers[Index][3]);
module DriverHole(Driver=[1,20,4,6],HeightOfRow=25,HandleHoleDepth=30){
translate([0,0,-1])cylinder(d=Driver[0],h=HeightOfRow+1);
//Transition to make it easier to put the screwdriver in the hole
translate([0,0,HeightOfRow-.1])cylinder(d1=Driver[0],d2=Driver[2],h=(Driver[2]-Driver[0])/2+.2);
translate([0,0,HeightOfRow+(Driver[2]-Driver[0])/2])cylinder(d=Driver[2],h=HandleHoleDepth+1);
On 3/25/2020 11:39 AM, A. Craig West wrote:
Are you sure about the if (false) case? I'm sure I've used that
successfully to avoid creating a child
Well, check out the output that I included, where the "if" case said it
had two children (one for the if(true) and one for the if(false)).
Consider also:
if (true) sphere();
if (false) cube();
where the CSG tree is (slightly reformatted for readability):
group() {
sphere($fn = 0, $fa = 12, $fs = 2, r = 1);
group();
On Wed, 25 Mar 2020, 11:59 Jordan Brown,
<openscad@jordan.maileater.net mailto:openscad@jordan.maileater.net>
On 3/25/2020 12:25 AM, nop head wrote:
You can't because /*for*/ implicitly unions it results, so only
ever makes one child.
More generally, all modules/operators make one child.
A "for" always makes one child.
An "if" always makes one child (even if it's false).
A module always makes one child (even if it doesn't generate any
geometry).
module how_many(label, ) {
echo(label, $children);
how_many("if") {
if (true) cube();
if (false) sphere();
how_many("for") {
for (i=[0:10:20]) translate([i,i,i]) cube();
module empty() {
how_many("empty") {
empty();
yields
ECHO: "if", 2
ECHO: "for", 1
ECHO: "empty", 1
I don't know the rules for the new lazy union mode that Paul
describes.
(Note: One might think that an empty module should yield no
children, but then you couldn't have a "placeholder" child in an
invocation of a module that takes multiple children with different
purposes, where children[1] and children[2] are not treated the same.)
You can do something kind of similar using $ variables to communicate
with the children.
Your top-level module would repeatedly invoke the children, with
different values of a $ variable, and the children would behave
differently depending on the values.
For instance:
module foreach(list) {
for ($i=[0:len(list)-1]) {
$val = list[$i];
module mychild() {
translate([0,$i*20,0]) text($val);
foreach(["alpha","beta","gamma"])
mychild();
Here's one that's a bit more similar to your example:
module distribute(separation, list) {
$val = list[$i];
translate($i * separation)
module mychild() {
text($val);
distribute([0,20,0], ["alpha","beta","gamma", "delta"])
mychild();
