I am experimenting with drawing polyhedrons and encountered this problem.
When I preview everything works, but when I render it the polyhedron doesn't
draw properly. If I draw only the polyhedron it works, but if I also draw
another cube or something else it fails when rendering.
Here is a bit of code:
union(){
polyhedron(
points=[[0,0,0], [0,8,0], [4,0,0], [4,8,0], [4,0,4], [4,8,4]],
faces=[[0,1,3,2],[0,1,5,4],[5,4,2,3],[0,4,2],[1,5,3]]
translate([4,0,0]) cube([2,8,4],false);
What is going on here? I'm not sure what I did wrong.
Have a look at it with View/Thrown-together, see the purple triangles.
See here
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/FAQ#Why_is_my_model_showing_up_with_F5_but_not_F6?
I'm not a whiz when it comes to OpenSCAD, but I like challenges. I read the wiki page and have quoted a portion that applies here.
I also created a crib sheet to help me understand the point and faces of the model described.
The CW aspect was missed on three faces. Once corrected, all is good.
union(){
polyhedron(
//faces=[[0,1,3,2],[0,1,5,4],[5,4,2,3],[0,4,2],[1,5,3]]
faces=[[0,2,3,1],[0,1,5,4],[5,3,2,4],[0,4,2],[1,3,5]]
points
0 - 0 0 0 = origin
1 - 0 8 0 = top left flat
2 - 4 0 0 = lower right flat
3 - 4 8 0 = upper right flat
4 - 4 0 4 = top point front
5 - 4 8 4 = top point rear
faces
bottom rectangle
0132 = origin, top left flat, upper right flat, lower right flat
left angled rectangle
0154 = origin, top left flat, top point rear, top point front
vertical right rectangle
5423 = top point rear, top point front, lower right flat, upper right flat
front triangle
042 = origin, top point front, lower right flat
rear triangle
153 = top left flat, top point rear, upper right flat
When viewed from the outside, the points describing each face must be in the same order . OpenSCAD prefers CW, and provides a mechanism for detecting CCW. When the thrown together view (F12) is used with F5, CCW faces are shown in pink. Reorder the points for incorrect faces. Rotate the object to view all faces. The pink view can be turned off with F10.
On Wednesday, January 23, 2019, 5:05:52 PM EST, TacoSupreme <ian@microwizard.com> wrote:
union(){
polyhedron(
Thanks for the help when I reordered some of the points it works perfectly
now.
faces=[[2,3,1,0],[3,2,4,5],[0,1,5,4],[0,4,2],[3,5,1]]
Hello check this out was working for me
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Primitive_Solids
