I often find myself generating objects using for() and later wanting to
perform additional operations on individual child-objects of the result.
For example consider:
This does not work as expected since the loop returns a single child...
How difficult would it be to allow children generated inside the loop to be
returned as a group of children rather than a single child? Either by adding
a option to the for() command or introducing a new command
"children_for()"...
Any thoughts?
Roy
View this message in context: http://forum.openscad.org/Any-thoughts-on-a-new-command-children-for-tp21116.html
That's not a simple change, but certainly one from the "most
wanted" list.
See https://github.com/openscad/openscad/issues/350 for some
discussion about that...
Which is why I assume that each iteration is actually independent
"children_for()"...
Any thoughts?
Roy
ah right so that does blow it out of the water, if unions are applied
each loop then each iteration isn't a truly independent event as I
thought it might be...
wanted" list.
applied each loop then each iteration isn't a truly independent
event as I thought it might be...
Not sure, but I don't think that's the case. One big challenge
is to get this working without breaking lots of existing
scripts. In general both parallel calculation and returning
the object list instead of the implicit union should be
possible, but needs quite some work.
you can go too far with backwards compatibility - especially if to
update an old script needs only minimal changes.
I'm not saying this is they way to go, but equally it maybe shouldn't be
discarded out of hand...
Just reading through the list at the wiki... Details... details... Thank you.
View this message in context: http://forum.openscad.org/Any-thoughts-on-a-new-command-children-for-tp21116p21122.html
If you introduce a new grammar unit in some new major release, e.g. "every"
which is equal to "for" but returns a list - you will break only the
scripts, which already use this very word.
8 апр. 2017 г. 2:31 пользователь "royasutton" roy_sutton@hotmail.com
написал:
you.
I can't imagine many, if any, scripts relying on for to make one child and
it would be very easy to fix by adding union and that would still work with
older versions.
"every" which is equal to "for" but returns a list - you will break only
the scripts, which already use this very word.
написал:
you.
