Re: [OpenSCAD] Looking for rocket-HAACK.scad
F
fred_dot_u
Fri, May 19, 2017 10:43 AM
I didn't open the five results of the search I performed, to determine if
they contain the library you seek, but consider to use  Thingiverse
https://www.thingiverse.com/search?q=openscad+nose+cones&sa=&dwh=47591ecba89e962
and search for "openscad nose cone" for similar results. To make it easier,
the link in the previous sentence performs that search.
View this message in context: http://forum.openscad.org/Looking-for-rocket-HAACK-scad-tp21543p21551.html
I didn't open the five results of the search I performed, to determine if they contain the library you seek, but consider to use Thingiverse <https://www.thingiverse.com/search?q=openscad+nose+cones&sa=&dwh=47591ecba89e962> and search for "openscad nose cone" for similar results. To make it easier, the link in the previous sentence performs that search. -- View this message in context: http://forum.openscad.org/Looking-for-rocket-HAACK-scad-tp21543p21551.html Sent from the OpenSCAD mailing list archive at Nabble.com.
jamorhous
Fri, May 19, 2017 3:21 PM
Fred,
Thanks,
I did try Thingverse but didn't get the same results.
Thanks!
Jeff
On Fri, May 19, 2017 at 3:43 AM, fred_dot_u [via OpenSCAD] <
ml+s1091067n21551h88@n5.nabble.com> wrote:
View this message in context: http://forum.openscad.org/Looking-for-rocket-HAACK-scad-tp21543p21556.html
Fred, Thanks, I did try Thingverse but didn't get the same results. Thanks! Jeff On Fri, May 19, 2017 at 3:43 AM, fred_dot_u [via OpenSCAD] < ml+s1091067n21551h88@n5.nabble.com> wrote: > I didn't open the five results of the search I performed, to determine if > they contain the library you seek, but consider to use Thingiverse > <https://www.thingiverse.com/search?q=openscad+nose+cones&sa=&dwh=47591ecba89e962> and > search for "openscad nose cone" for similar results. To make it easier, the > link in the previous sentence performs that search. > > ------------------------------ > If you reply to this email, your message will be added to the discussion > below: > http://forum.openscad.org/Looking-for-rocket-HAACK-scad-tp21543p21551.html > To unsubscribe from Looking for rocket-HAACK.scad, click here > <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=21543&code=amFtb3Job3VzQGdtYWlsLmNvbXwyMTU0M3wtOTk5NTg4MDE5> > . > NAML > <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> > -- View this message in context: http://forum.openscad.org/Looking-for-rocket-HAACK-scad-tp21543p21556.html Sent from the OpenSCAD mailing list archive at Nabble.com.
