Ok,
I need to go to kinko's and print out a drill and wood cut mask and it's
holding up my 3d printer build. I need a file that will export to scale.
please help
terramir
Respectfully,
R. Daniel Borkan
727 S. Coronado St. 201
Los Angeles, CA 90057
H: (213) 739-1863
C: (213) 271-6721
All written content of this e-mail is confidential and only intended for
the named recipient. This message is subject to copyright and is
intellectual property of the sender. All rights reserved (c) 2015
Model your part in 2d, include a 1cm square square([10,10]), render,
export as SVG, open in your favorite vector program, use the 1cm square
to find the scale, apply that scale, print.
~ Yona
r.d. terramir mailto:terramircomputers@gmail.com
December 17, 2016 at 12:21
Ok,
it's holding up my 3d printer build. I need a file that will export
to scale.
please help
terramir
Respectfully,
R. Daniel Borkan
H: (213) 739-1863 tel:%28213%29%20739-1863
C: (213) 271-6721 tel:%28213%29%20271-6721
for the named recipient. This message is subject to copyright and is
I dun have any vector programs :S
I do all my modeling in openscad seriously
I need detailed instructions as I dun evwen know how vector programs work
and well right now I got someone elses model I modified the model to only
have a 1mm height .
so basically 2D
terramir
Respectfully,
R. Daniel Borkan
H: (213) 739-1863
C: (213) 271-6721
export as SVG, open in your favorite vector program, use the 1cm square to
~ Yona
r.d. terramir terramircomputers@gmail.com
Ok,
please help
terramir
Respectfully,
R. Daniel Borkan
H: (213) 739-1863
C: (213) 271-6721
Your web browser can open and print SVGs. Use that to calibrate the
scale and update it in OpenSCAD (print a square and measure it, then
adjust in OpenSCAD)
You can make a 2d porjection by using the projection() function.
Best of luck.
December 17, 2016 at 12:30
work and well right now I got someone elses model I modified the model
to only have a 1mm height .
so basically 2D
terramir
Respectfully,
R. Daniel Borkan
H: (213) 739-1863
C: (213) 271-6721
Ok,
to scale.
please help
terramir
Respectfully,
R. Daniel Borkan
actually I solved it by using the export image function after viewing
the right angle and removing the crosshairs and then resizing in gimp
to 10 px per mm and auto cropping the image so I ended up with a
3500x4041 px image that is the right scale.
35 cm x 40.41cm which is the perfect size for a hexagon with a 202mm
side. so let's mark this as solved but a function to export the image
to scale would be good.
adjust in OpenSCAD)
Best of luck.
so basically 2D
terramir
Respectfully,
R. Daniel Borkan
H: (213) 739-1863
C: (213) 271-6721
Ok,
to scale.
please help
terramir
Respectfully,
R. Daniel Borkan
Respectfully,
R. Daniel Borkan
H: (213) 739-1863
C: (213) 271-6721
You should maybe consider downloading and learning InkScape in the time
it takes to do all this trial and error stuff, and have a purpose
designed program for 2-D, sub-millimetre accuracy printouts straight off
the bat. It will also be very handy for you to feed 2D work back into
OpenScad.
Rob
so basically 2D
terramir
Respectfully,
R. Daniel Borkan
H: (213) 739-1863
C: (213) 271-6721
On Sat, Dec 17, 2016 at 12:26 PM, Yona Appletree <hypher@gmail.com
mailto:hypher@gmail.com> wrote:
Model your part in 2d, include a 1cm square `square([10,10])`,
render, export as SVG, open in your favorite vector program, use
the 1cm square to find the scale, apply that scale, print.
~ Yona
r.d. terramir <mailto:terramircomputers@gmail.com>
Ok,
and it's holding up my 3d printer build. I need a file that will
export to scale.
please help
terramir
Respectfully,
R. Daniel Borkan
H: (213) 739-1863 <tel:%28213%29%20739-1863>
C: (213) 271-6721 <tel:%28213%29%20271-6721>
intended for the named recipient. This message is subject to
copyright and is intellectual property of the sender. All rights
reserved (c) 2015
Rob Ward
Lake Tyers Beach, 3909
Ubuntu Mate - A great OS https://ubuntu-mate.org/
I export to SVG, open with Inkscape, File/Document_properties - Select 'A4'
(or whatever you use), drag the image to position on page as needed,
File/Export_Bitmap (select 'Page', Filename, click 'Export'). Done.
View this message in context: http://forum.openscad.org/emergency-question-time-sensitive-exporting-an-image-to-scale-tp19610p19618.html
