r1 and r2
H
Hendrik
Tue, Mar 15, 2022 3:36 PM
<!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {margin:0cm; font-size:11.0pt; font-family:"Calibri",sans-serif;} a:link, span.MsoHyperlink {mso-style-priority:99; color:blue; text-decoration:underline;} .MsoChpDefault {mso-style-type:export-only;} @page WordSection1 {size:612.0pt 792.0pt; margin:72.0pt 72.0pt 72.0pt 72.0pt;} div.WordSection1 {page:WordSection1;} -->Hi
When I use r1 and r2 in a cylinder which one of the radius is at [0,0,0].
Cylinder(r1=10, r2=20,h=25);
Is the r1= 10 at the 0,0,0 or the r2?
Thank you
Sent from Mail for Windows
Tue, Mar 15, 2022 3:42 PM
r1 is the one at the bottom, circle around [0, 0, 0]
r2 is at the top, the bigger circle around [0, 0, 25]
On 15.03.22 16:36, Hendrik wrote: > Cylinder(r1=10, r2=20,h=25); r1 is the one at the bottom, circle around [0, 0, 0] r2 is at the top, the bigger circle around [0, 0, 25] ciao, Torsten.
BR
Bob Roos
Wed, Mar 16, 2022 1:43 AM
Hi Torsten,
I struggle with that because it seems backwards to me, but I am coping.....
Bob
have Fun,
Hi Torsten, I struggle with that because it seems backwards to me, but I am coping..... Bob Tuesday, March 15, 2022, 11:42:55 AM, you wrote: > On 15.03.22 16:36, Hendrik wrote: >> Cylinder(r1=10, r2=20,h=25); > r1 is the one at the bottom, circle around [0, 0, 0] > r2 is at the top, the bigger circle around [0, 0, 25] > ciao, > Torsten. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org -- have Fun, Bob mailto:roosbob@wybatap.com
Wed, Mar 16, 2022 1:46 AM
I had a go at clarifying the wiki.
Sent: Wed, 16 Mar 2022 12:43
Subject: [OpenSCAD] Re: r1 and r2
Hi Torsten,
Bob
have Fun,
I had a go at clarifying the wiki. > -----Original Message----- > From: Bob Roos [mailto:roosbob@wybatap.com] > Sent: Wed, 16 Mar 2022 12:43 > To: OpenSCAD general discussion > Subject: [OpenSCAD] Re: r1 and r2 > > Hi Torsten, > > I struggle with that because it seems backwards to me, but I am coping..... > > Bob > > Tuesday, March 15, 2022, 11:42:55 AM, you wrote: > > On 15.03.22 16:36, Hendrik wrote: > >> Cylinder(r1=10, r2=20,h=25); > > > r1 is the one at the bottom, circle around [0, 0, 0] > > > r2 is at the top, the bigger circle around [0, 0, 25] > > > ciao, > > Torsten. > > _______________________________________________ > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org > > > -- > have Fun, > Bob mailto:roosbob@wybatap.com > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org -- This email has been checked for viruses by AVG. https://www.avg.com
Wed, Mar 16, 2022 4:04 AM
Most things in OpenSCAD extend by default from the origin into +Z:
cylinder, cube, linear_extrude, et cetera.  I think of the origin as the
"first" part of the object, so it makes sense to me that r1 controls the
radius on the origin plane.
If you set center=true then that logic goes out the window and it
becomes arbitrary whether the top or the bottom is "first".
On 3/15/2022 6:43 PM, Bob Roos wrote: > I struggle with that because it seems backwards to me, but I am coping..... Most things in OpenSCAD extend by default from the origin into +Z:  cylinder, cube, linear_extrude, et cetera.  I think of the origin as the "first" part of the object, so it makes sense to me that r1 controls the radius on the origin plane. If you set center=true then that logic goes out the window and it becomes arbitrary whether the top or the bottom is "first".
DS
David Schooley
Wed, Mar 16, 2022 4:26 AM
The difference between how cubes are handled vs.cylinders has always been interesting. I have a lot of code that is more of a mess than necessary because cubes don’t center on the X-Y plane but cylinders do. I think what OpenSCAD does is correct, but a “centerxy” parameter for cubes would be a good thing.
On Mar 15, 2022, at 11:04 PM, Jordan Brown openscad@jordan.maileater.net wrote:
The difference between how cubes are handled vs.cylinders has always been interesting. I have a lot of code that is more of a mess than necessary because cubes don’t center on the X-Y plane but cylinders do. I think what OpenSCAD does is correct, but a “centerxy” parameter for cubes would be a good thing. > On Mar 15, 2022, at 11:04 PM, Jordan Brown <openscad@jordan.maileater.net> wrote: > > On 3/15/2022 6:43 PM, Bob Roos wrote: >> I struggle with that because it seems backwards to me, but I am coping..... > > Most things in OpenSCAD extend by default from the origin into +Z: cylinder, cube, linear_extrude, et cetera. I think of the origin as the "first" part of the object, so it makes sense to me that r1 controls the radius on the origin plane. > > If you set center=true then that logic goes out the window and it becomes arbitrary whether the top or the bottom is "first". > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Wed, Mar 16, 2022 8:46 AM
But still it'd be very odd if the orientation would "flip" when you
add center=true !
On Wed, Mar 16, 2022 at 04:04:51AM +0000, Jordan Brown wrote: > If you set center=true then that logic goes out the window and it > becomes arbitrary whether the top or the bottom is "first". But still it'd be very odd if the orientation would "flip" when you add center=true ! Roger. -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a is going up. -- Chris Hadfield about flying up the space shuttle.
Wed, Mar 16, 2022 12:03 PM
Easy enough to roll your own CubeCXY() which centers in XY.
Easy enough to roll your own CubeCXY() which centers in XY. On 3/16/2022 12:26 AM, David Schooley wrote: > The difference between how cubes are handled vs.cylinders has always been interesting. I have a lot of code that is more of a mess than necessary because cubes don’t center on the X-Y plane but cylinders do. I think what OpenSCAD does is correct, but a “centerxy” parameter for cubes would be a good thing. >
Douglas Miller
Wed, Mar 16, 2022 12:14 PM
Bob,
Here ya go.
module cube(size,center=false) {
    x = is_list(size) ? size[0] : size;
    y = is_list(size) ? size[1] : size;
    z = is_list(size) ? size[2] : size;
    DeltaZ = center ? -z/2 : 0;
    translate([0,0,DeltaZ]) linear_extrude(height=z) square([x,y],true);
center true gives you a rectangular solid with its geometric center at
the origin; center false (or omitted) gives you the same solid with its
base centered at the origin, extending upward in +z. size can be either
a scalar (true cube) or a list (x, y, z values independent), same as in
the standard cube() function.
Bob, Here ya go. module cube(size,center=false) {     x = is_list(size) ? size[0] : size;     y = is_list(size) ? size[1] : size;     z = is_list(size) ? size[2] : size;     DeltaZ = center ? -z/2 : 0;     translate([0,0,DeltaZ]) linear_extrude(height=z) square([x,y],true); } center true gives you a rectangular solid with its geometric center at the origin; center false (or omitted) gives you the same solid with its base centered at the origin, extending upward in +z. size can be either a scalar (true cube) or a list (x, y, z values independent), same as in the standard cube() function. On 3/16/2022 12:26 AM, David Schooley wrote: > The difference between how cubes are handled vs.cylinders has always been interesting. I have a lot of code that is more of a mess than necessary because cubes don’t center on the X-Y plane but cylinders do. I think what OpenSCAD does is correct, but a “centerxy” parameter for cubes would be a good thing. >
Wed, Mar 16, 2022 12:19 PM
linear_extrude(height=z, center=center) square([x,y],true);
No need for translate(), linear_extrude() has a center
parameter too.
On 16.03.22 13:14, Douglas Miller wrote: >     DeltaZ = center ? -z/2 : 0; >     translate([0,0,DeltaZ]) linear_extrude(height=z) square([x,y],true); linear_extrude(height=z, center=center) square([x,y],true); No need for translate(), linear_extrude() has a center parameter too. ciao, Torsten.
