Fwd: convert STL?
Ray West
Sun, Dec 27, 2020 2:45 PM
Hi David,
Is it a bltouch bracket for an ender 3 you are looking for, or for some
other printer? If you don't want to construct a new cad model, and you
only want one bracket, it will most likely be printed solid infill. You
are allowed to physically drill holes wherever you want. If it is for
the ender3, there are plenty of printable brackets, assuming it's the
original hot end. They normally use the same fixing holes as the hot-end
shroud, so you may need longer screws. It is not an ideal arrangement.
To make the bracket, using cad, it is basically an 'L' shape.my process,
would be based on  that angle piece being constructed by using two
cubes, offsetting one by the wall thickness, and subtracting from the
other. To get the profile shape, cut pieces away by subtracting more
cubes, say. The fixing holes, lar3ry has explained. No need to worry
about rounded corners, or any of the fancy stuff. Print the thing, use
it, then decide if you really want to do something better. It may take a
few iterations to get the fixing holes correctly positioned, and the
correct diameter, but the bracket can be printed in a fairly short time,
so don't waste time initially making it look pretty.
Best wishes,
Ray
On 27/12/2020 01:28, David wrote:
Tried several from thingiverse.  Also tried modeling the CR-10 (metal)
one that comes with the Creality kits.  While it was not wonderful,
the CR-10 model could be used in a pinch on an Ender 3, for example,
if you didn't have a real, metal one.  My attempt at duplicating it
with changes never got past the drawing board.  I'm very new to OpenSCAD.
Thanks,
David
On 12/26/20 4:57 PM, fred via Discuss wrote:
What resource are you using for the bracket? Is it open
source/thingiverse/other?
On Saturday, December 26, 2020, 5:48:54 PM EST, David
ainut@hiwaay.net wrote:
I tried the "ground up" approach.  I sucked.
Hi David, Is it a bltouch bracket for an ender 3 you are looking for, or for some other printer? If you don't want to construct a new cad model, and you only want one bracket, it will most likely be printed solid infill. You are allowed to physically drill holes wherever you want. If it is for the ender3, there are plenty of printable brackets, assuming it's the original hot end. They normally use the same fixing holes as the hot-end shroud, so you may need longer screws. It is not an ideal arrangement. To make the bracket, using cad, it is basically an 'L' shape.my process, would be based on  that angle piece being constructed by using two cubes, offsetting one by the wall thickness, and subtracting from the other. To get the profile shape, cut pieces away by subtracting more cubes, say. The fixing holes, lar3ry has explained. No need to worry about rounded corners, or any of the fancy stuff. Print the thing, use it, then decide if you really want to do something better. It may take a few iterations to get the fixing holes correctly positioned, and the correct diameter, but the bracket can be printed in a fairly short time, so don't waste time initially making it look pretty. Best wishes, Ray On 27/12/2020 01:28, David wrote: > > Tried several from thingiverse.  Also tried modeling the CR-10 (metal) > one that comes with the Creality kits.  While it was not wonderful, > the CR-10 model could be used in a pinch on an Ender 3, for example, > if you didn't have a real, metal one.  My attempt at duplicating it > with changes never got past the drawing board.  I'm very new to OpenSCAD. > > Thanks, > > David > > > On 12/26/20 4:57 PM, fred via Discuss wrote: >> What resource are you using for the bracket? Is it open >> source/thingiverse/other? >> >> On Saturday, December 26, 2020, 5:48:54 PM EST, David >> <ainut@hiwaay.net> wrote: >> >> >> I tried the "ground up" approach.  I sucked. >> >> >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Ray West
Sun, Dec 27, 2020 3:51 PM
Antclabs have full documentation on bl touch, including fixing holes,
etc https://www.antclabs.com/manual
On 27/12/2020 14:45, Ray West wrote:
Hi David,
and you only d.org/mailman/listinfo/discuss_lists.openscad.org
Antclabs have full documentation on bl touch, including fixing holes, etc https://www.antclabs.com/manual On 27/12/2020 14:45, Ray West wrote: > Hi David, > > Is it a bltouch bracket for an ender 3 you are looking for, or for > some other printer? If you don't want to construct a new cad model, > and you only d.org/mailman/listinfo/discuss_lists.openscad.org >
D
David
Sun, Dec 27, 2020 10:53 PM
Could find no reference to an OpenSCAD model in their manual or on their
website.
David
Hi David,
Could find no reference to an OpenSCAD model in their manual or on their website. David On 12/27/20 9:51 AM, Ray West wrote: > Antclabs have full documentation on bl touch, including fixing holes, > etc https://www.antclabs.com/manual > > On 27/12/2020 14:45, Ray West wrote: >> Hi David, >> >> Is it a bltouch bracket for an ender 3 you are looking for, or for >> some other printer? If you don't want to construct a new cad model, >> and you only d.org/mailman/listinfo/discuss_lists.openscad.org >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Ray West
Mon, Dec 28, 2020 1:41 AM
their website.
David
Why did you expect references to openscad? Their manuals contain the
dimensions you need to make your own bracket, and connection
information. You should be able to apply that to the openscad code I
gave earlier, or any other design you may have. If your firmware is
Marlin based, you will enjoy altering it to take account of your bltouch.
On 27/12/2020 22:53, David wrote: > Could find no reference to an OpenSCAD model in their manual or on > their website. > > David > > Why did you expect references to openscad? Their manuals contain the dimensions you need to make your own bracket, and connection information. You should be able to apply that to the openscad code I gave earlier, or any other design you may have. If your firmware is Marlin based, you will enjoy altering it to take account of your bltouch.
