are there easier ways to get round edges?
K
kaefert
Mon, Aug 10, 2015 8:47 AM
Hi there!
I've spent a few hours designing this rounding for a part of mine, which
already is quite complex (to my eyes at least):
and now I've found that it sadly won't do since I need it angled - I'll try
to explain: at the moment it hits the smaller part in 90° angle on both
sides, but i need it in 75° on the one side and in 105° on the other.
If the discription is unclear, or you wanna take a look at the bigger
picture, this is my work in progress quadcopter frame for which arm this
rounding is for:  playground_v5.scad
http://forum.openscad.org/file/n13495/playground_v5.scad
View this message in context: http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495.html
Hi there! I've spent a few hours designing this rounding for a part of mine, which already is quite complex (to my eyes at least): and now I've found that it sadly won't do since I need it angled - I'll try to explain: at the moment it hits the smaller part in 90° angle on both sides, but i need it in 75° on the one side and in 105° on the other. If the discription is unclear, or you wanna take a look at the bigger picture, this is my work in progress quadcopter frame for which arm this rounding is for: playground_v5.scad <http://forum.openscad.org/file/n13495/playground_v5.scad> -- View this message in context: http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495.html Sent from the OpenSCAD mailing list archive at Nabble.com.
CL
Chow Loong Jin
Mon, Aug 10, 2015 9:18 AM
On Mon, Aug 10, 2015 at 01:47:42AM -0700, kaefert wrote:
Hi there!
Clothbot's fillet.scad is great stuff for this purpose.
https://github.com/clothbot/ClothBotCreations/blob/master/utilities/fillet.scad
Unfortunately, it uses multiple minkowski()s which makes it horribly expensive
to use, so I try to avoid using it whenever there is a simple enough way to
implement it (e.g. 90° fillets using filleted_cylinder() and filleted_cube() in
https://github.com/hyperair/deltabob/blob/master/utils.scad).
Kind regards,
Loong Jin
On Mon, Aug 10, 2015 at 01:47:42AM -0700, kaefert wrote: > Hi there! > > I've spent a few hours designing this rounding for a part of mine, which > already is quite complex (to my eyes at least): > > > > and now I've found that it sadly won't do since I need it angled - I'll try > to explain: at the moment it hits the smaller part in 90° angle on both > sides, but i need it in 75° on the one side and in 105° on the other. > > If the discription is unclear, or you wanna take a look at the bigger > picture, this is my work in progress quadcopter frame for which arm this > rounding is for: playground_v5.scad > <http://forum.openscad.org/file/n13495/playground_v5.scad> Clothbot's fillet.scad is great stuff for this purpose. https://github.com/clothbot/ClothBotCreations/blob/master/utilities/fillet.scad Unfortunately, it uses multiple minkowski()s which makes it horribly expensive to use, so I try to avoid using it whenever there is a simple enough way to implement it (e.g. 90° fillets using filleted_cylinder() and filleted_cube() in https://github.com/hyperair/deltabob/blob/master/utils.scad). -- Kind regards, Loong Jin
K
kaefert
Mon, Aug 10, 2015 9:37 AM
thanks for your reply!
Is there some getting started guide or something like that for how to use
these libraries?
Regards, Thomas Käfer
2015-08-10 11:19 GMT+02:00 Chow Loong Jin [via OpenSCAD] <
ml-node+s1091067n13496h39@n5.nabble.com>:
Hi there!
try
expensive
to
filleted_cube() in
Kind regards,
Loong Jin
[hidden email] http:///user/SendEmail.jtp?type=node&node=13496&i=0
signature.asc (836 bytes) Download Attachment
http://forum.openscad.org/attachment/13496/0/signature.asc
below:
http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495p13496.html
To unsubscribe from are there easier ways to get round edges?, click here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=13495&code=a2FlZmVydEBnbWFpbC5jb218MTM0OTV8MTk2MTMwNjk3MQ==
NAML
View this message in context: http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495p13497.html
thanks for your reply! Is there some getting started guide or something like that for how to use these libraries? Regards, Thomas Käfer 2015-08-10 11:19 GMT+02:00 Chow Loong Jin [via OpenSCAD] < ml-node+s1091067n13496h39@n5.nabble.com>: > On Mon, Aug 10, 2015 at 01:47:42AM -0700, kaefert wrote: > > > Hi there! > > > > I've spent a few hours designing this rounding for a part of mine, which > > already is quite complex (to my eyes at least): > > > > > > > > and now I've found that it sadly won't do since I need it angled - I'll > try > > to explain: at the moment it hits the smaller part in 90° angle on both > > sides, but i need it in 75° on the one side and in 105° on the other. > > > > If the discription is unclear, or you wanna take a look at the bigger > > picture, this is my work in progress quadcopter frame for which arm this > > rounding is for: playground_v5.scad > > <http://forum.openscad.org/file/n13495/playground_v5.scad> > Clothbot's fillet.scad is great stuff for this purpose. > > > https://github.com/clothbot/ClothBotCreations/blob/master/utilities/fillet.scad > > Unfortunately, it uses multiple minkowski()s which makes it horribly > expensive > to use, so I try to avoid using it whenever there is a simple enough way > to > implement it (e.g. 90° fillets using filleted_cylinder() and > filleted_cube() in > https://github.com/hyperair/deltabob/blob/master/utils.scad). > > -- > Kind regards, > Loong Jin > > _______________________________________________ > OpenSCAD mailing list > [hidden email] <http:///user/SendEmail.jtp?type=node&node=13496&i=0> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > *signature.asc* (836 bytes) Download Attachment > <http://forum.openscad.org/attachment/13496/0/signature.asc> > > > ------------------------------ > If you reply to this email, your message will be added to the discussion > below: > > http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495p13496.html > To unsubscribe from are there easier ways to get round edges?, click here > <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=13495&code=a2FlZmVydEBnbWFpbC5jb218MTM0OTV8MTk2MTMwNjk3MQ==> > . > NAML > <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> > -- View this message in context: http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495p13497.html Sent from the OpenSCAD mailing list archive at Nabble.com.
CL
Chow Loong Jin
Mon, Aug 10, 2015 10:45 AM
these libraries?
You use fillet() like you would use a union(), and fillet will try to fillet any
joints it sees. It doesn't work too well with individual concave children
becauses it uses hull(), but it works very well at generating fillets at concave
joints between children.
For filleted_cylinder() and filleted_cube(), they just work like their cube()
and cylinder() counterparts, but with an additional fillet_r parameter (and in
the case of cube(), fillet_sides which allows you to specify which sides to
fillet (sometimes you don't want all the sides filleted). filleted_cube() also
has an extended "center" argument that takes an 3-element vector of sides to
center upon. MCAD's X, Y, and Z constants work well for this, like
filleted_cube(..., center = X + Y, ...);
Kind regards,
Loong Jin
On Mon, Aug 10, 2015 at 02:37:42AM -0700, kaefert wrote: > thanks for your reply! > Is there some getting started guide or something like that for how to use > these libraries? You use fillet() like you would use a union(), and fillet will try to fillet any joints it sees. It doesn't work too well with individual concave children becauses it uses hull(), but it works very well at generating fillets at concave joints between children. For filleted_cylinder() and filleted_cube(), they just work like their cube() and cylinder() counterparts, but with an additional fillet_r parameter (and in the case of cube(), fillet_sides which allows you to specify which sides to fillet (sometimes you don't want all the sides filleted). filleted_cube() also has an extended "center" argument that takes an 3-element vector of sides to center upon. MCAD's X, Y, and Z constants work well for this, like filleted_cube(..., center = X + Y, ...); -- Kind regards, Loong Jin
K
kaefert
Mon, Aug 10, 2015 11:04 AM
thanks for your reply. I got filet to work but its incredibly slow, and I'm
not even close to the resolution I was thinking about....
The deltabob/utils.scad if I understood it correctly won't do angled
roundings between two objects, but only round one or multiple sides of a
single object?
Also I guess I would need to find out about this MCAD library that it seems
to depend on...
2015-08-10 12:46 GMT+02:00 Chow Loong Jin [via OpenSCAD] <
ml-node+s1091067n13498h1@n5.nabble.com>:
use
these libraries?
fillet any
concave
cube()
(and in
to
also
to
Kind regards,
Loong Jin
[hidden email] http:///user/SendEmail.jtp?type=node&node=13498&i=0
http://forum.openscad.org/attachment/13498/0/signature.asc
below:
http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495p13498.html
NAML
View this message in context: http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495p13499.html
thanks for your reply. I got filet to work but its incredibly slow, and I'm not even close to the resolution I was thinking about.... The deltabob/utils.scad if I understood it correctly won't do angled roundings between two objects, but only round one or multiple sides of a single object? Also I guess I would need to find out about this MCAD library that it seems to depend on... 2015-08-10 12:46 GMT+02:00 Chow Loong Jin [via OpenSCAD] < ml-node+s1091067n13498h1@n5.nabble.com>: > On Mon, Aug 10, 2015 at 02:37:42AM -0700, kaefert wrote: > > thanks for your reply! > > Is there some getting started guide or something like that for how to > use > > these libraries? > > You use fillet() like you would use a union(), and fillet will try to > fillet any > joints it sees. It doesn't work too well with individual concave children > becauses it uses hull(), but it works very well at generating fillets at > concave > joints between children. > > For filleted_cylinder() and filleted_cube(), they just work like their > cube() > and cylinder() counterparts, but with an additional fillet_r parameter > (and in > the case of cube(), fillet_sides which allows you to specify which sides > to > fillet (sometimes you don't want all the sides filleted). filleted_cube() > also > has an extended "center" argument that takes an 3-element vector of sides > to > center upon. MCAD's X, Y, and Z constants work well for this, like > filleted_cube(..., center = X + Y, ...); > > -- > Kind regards, > Loong Jin > > _______________________________________________ > OpenSCAD mailing list > [hidden email] <http:///user/SendEmail.jtp?type=node&node=13498&i=0> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > *signature.asc* (836 bytes) Download Attachment > <http://forum.openscad.org/attachment/13498/0/signature.asc> > > > ------------------------------ > If you reply to this email, your message will be added to the discussion > below: > > http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495p13498.html > To unsubscribe from are there easier ways to get round edges?, click here > <http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=13495&code=a2FlZmVydEBnbWFpbC5jb218MTM0OTV8MTk2MTMwNjk3MQ==> > . > NAML > <http://forum.openscad.org/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml> > -- View this message in context: http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495p13499.html Sent from the OpenSCAD mailing list archive at Nabble.com.
CL
Chow Loong Jin
Mon, Aug 10, 2015 11:10 AM
You can increase the resolution by specifying the radius and steps.
single object?
to depend on...
It's just a shortcut to make a cube with a filleted base, and a cylinder with a
filleted base, because it's simple to do and much faster than using fillet (...)
{ cube (...); base (); }
Kind regards,
Loong Jin
On Mon, Aug 10, 2015 at 04:04:42AM -0700, kaefert wrote: > thanks for your reply. I got filet to work but its incredibly slow, and I'm > not even close to the resolution I was thinking about.... You can increase the resolution by specifying the radius and steps. > The deltabob/utils.scad if I understood it correctly won't do angled > roundings between two objects, but only round one or multiple sides of a > single object? > Also I guess I would need to find out about this MCAD library that it seems > to depend on... It's just a shortcut to make a cube with a filleted base, and a cylinder with a filleted base, because it's simple to do and much faster than using fillet (...) { cube (...); base (); } -- Kind regards, Loong Jin
PF
Peter Falke
Mon, Aug 10, 2015 6:04 PM
As long as you can work in 2d, you can use the offset() command.
Its very fast.
2015-08-10 13:10 GMT+02:00 Chow Loong Jin hyperair@debian.org:
I'm
single object?
seems
to depend on...
with a
Kind regards,
Loong Jin
schreiben.
Enjoy!
As long as you can work in 2d, you can use the offset() command. Its very fast. 2015-08-10 13:10 GMT+02:00 Chow Loong Jin <hyperair@debian.org>: > On Mon, Aug 10, 2015 at 04:04:42AM -0700, kaefert wrote: > > thanks for your reply. I got filet to work but its incredibly slow, and > I'm > > not even close to the resolution I was thinking about.... > > You can increase the resolution by specifying the radius and steps. > > > The deltabob/utils.scad if I understood it correctly won't do angled > > roundings between two objects, but only round one or multiple sides of a > > single object? > > Also I guess I would need to find out about this MCAD library that it > seems > > to depend on... > > It's just a shortcut to make a cube with a filleted base, and a cylinder > with a > filleted base, because it's simple to do and much faster than using fillet > (...) > { cube (...); base (); } > > -- > Kind regards, > Loong Jin > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > -- stempeldergeschichte@googlemail.com <karsten@rohrbach.de> P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu schreiben. Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. P.S. In case my e-mail is shorter than you enjoy: I am currently trying short replies instead of no replies at all. Please let me know, if you like to read more. Enjoy!
PF
Peter Falke
Mon, Aug 10, 2015 6:08 PM
Have a look at some code I once wrote:
http://www.thingiverse.com/thing:142798
It does a fillet between any (concave) shape and a plane.
It is slow, as it uses minkowsky(), but as long as you increase fn_fillet
slowly you should be fine.
2015-08-10 20:04 GMT+02:00 Peter Falke stempeldergeschichte@googlemail.com
Its very fast.
I'm
single object?
seems
to depend on...
with a
fillet (...)
Kind regards,
Loong Jin
schreiben.
Enjoy!
schreiben.
Enjoy!
Have a look at some code I once wrote: http://www.thingiverse.com/thing:142798 It does a fillet between any (concave) shape and a plane. It is slow, as it uses minkowsky(), but as long as you increase fn_fillet slowly you should be fine. 2015-08-10 20:04 GMT+02:00 Peter Falke <stempeldergeschichte@googlemail.com> : > As long as you can work in 2d, you can use the offset() command. > Its very fast. > > > > 2015-08-10 13:10 GMT+02:00 Chow Loong Jin <hyperair@debian.org>: > >> On Mon, Aug 10, 2015 at 04:04:42AM -0700, kaefert wrote: >> > thanks for your reply. I got filet to work but its incredibly slow, and >> I'm >> > not even close to the resolution I was thinking about.... >> >> You can increase the resolution by specifying the radius and steps. >> >> > The deltabob/utils.scad if I understood it correctly won't do angled >> > roundings between two objects, but only round one or multiple sides of a >> > single object? >> > Also I guess I would need to find out about this MCAD library that it >> seems >> > to depend on... >> >> It's just a shortcut to make a cube with a filleted base, and a cylinder >> with a >> filleted base, because it's simple to do and much faster than using >> fillet (...) >> { cube (...); base (); } >> >> -- >> Kind regards, >> Loong Jin >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > > -- > stempeldergeschichte@googlemail.com <karsten@rohrbach.de> > > P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: > Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu > schreiben. > Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. > > P.S. In case my e-mail is shorter than you enjoy: > I am currently trying short replies instead of no replies at all. > Please let me know, if you like to read more. > > Enjoy! > -- stempeldergeschichte@googlemail.com <karsten@rohrbach.de> P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu schreiben. Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. P.S. In case my e-mail is shorter than you enjoy: I am currently trying short replies instead of no replies at all. Please let me know, if you like to read more. Enjoy!
S
sgraves
Mon, Aug 10, 2015 6:12 PM
Look at the sweep function made possible with the newest OpenSCAD.  There are
several ways to create a path.  In your case directly creating the path with
list comprehensions is the probably the best way.
A path is simply a list of transformation matrices like the multimatrix.  In
the scad-utils library you can see how they are done in
"transformations.scad".  Each transformation can not only have a translation
for a point on the path, it can have rotations and scaling as well.  By
mathematically defining the shape you want using the scaling you can create
almost any shape.  In your case the math is fairly simple.
For some reason the sweep is not part of the scad utils.  It is in the list
comprehension demos.  Both can be found in the OpenSCAD github
https://github.com/openscad https://github.com/openscad
Sweep uses the transformation list created for the path to transform a 2D
shape at each point.  It connects the corresponding vertices of the
transformed shape back to the transformed 2D shape at the previous step
forming a polyhedron 3D shape.  You could use a half circle or quarter
circle which is scaled as needed.  You probably want a straight path.
The path can be almost anything. I have used this technique to fillet
unusual paths.  For example, I added fillets to fins on a jet ski impeller.
The fins were sweeps as well.  I could use the same base path for both.
Just change the 2D shapes and the scaling.
BTW, another great way to create paths are trajectories.  They are pretty
easy to understand. The quantize_trajectories will turn the trajectories
into a path.  There may be a way to add scaling directly to the trajectory,
but I usually take that path and apply the scaling in another list
comprehension.
I didn't recommend using the trajectories in your case, because I believe
you will be translating on a straight line.  Your math needs to relate to
the translation values.  You should do it all together.
Steve
kaefert wrote
Hi there!
rounding is for:
playground_v5.scad
View this message in context: http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495p13504.html
Look at the sweep function made possible with the newest OpenSCAD. There are several ways to create a path. In your case directly creating the path with list comprehensions is the probably the best way. A path is simply a list of transformation matrices like the multimatrix. In the scad-utils library you can see how they are done in "transformations.scad". Each transformation can not only have a translation for a point on the path, it can have rotations and scaling as well. By mathematically defining the shape you want using the scaling you can create almost any shape. In your case the math is fairly simple. For some reason the sweep is not part of the scad utils. It is in the list comprehension demos. Both can be found in the OpenSCAD github https://github.com/openscad <https://github.com/openscad> Sweep uses the transformation list created for the path to transform a 2D shape at each point. It connects the corresponding vertices of the transformed shape back to the transformed 2D shape at the previous step forming a polyhedron 3D shape. You could use a half circle or quarter circle which is scaled as needed. You probably want a straight path. The path can be almost anything. I have used this technique to fillet unusual paths. For example, I added fillets to fins on a jet ski impeller. The fins were sweeps as well. I could use the same base path for both. Just change the 2D shapes and the scaling. BTW, another great way to create paths are trajectories. They are pretty easy to understand. The quantize_trajectories will turn the trajectories into a path. There may be a way to add scaling directly to the trajectory, but I usually take that path and apply the scaling in another list comprehension. I didn't recommend using the trajectories in your case, because I believe you will be translating on a straight line. Your math needs to relate to the translation values. You should do it all together. Steve kaefert wrote > Hi there! > > I've spent a few hours designing this rounding for a part of mine, which > already is quite complex (to my eyes at least): > > and now I've found that it sadly won't do since I need it angled - I'll > try to explain: at the moment it hits the smaller part in 90° angle on > both sides, but i need it in 75° on the one side and in 105° on the other. > > If the discription is unclear, or you wanna take a look at the bigger > picture, this is my work in progress quadcopter frame for which arm this > rounding is for: > playground_v5.scad > <http://forum.openscad.org/file/n13495/playground_v5.scad> -- View this message in context: http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495p13504.html Sent from the OpenSCAD mailing list archive at Nabble.com.
K
kaefert
Tue, Aug 11, 2015 6:13 PM
hey there guys!
Thank you for all your answers!
At the moment I've copied the fillet function suggested by Chow Loong Jin
from
(find my current development stage as attachment: )
playground_v7.scad
http://forum.openscad.org/file/n13508/playground_v7.scad
I adapted my code to just intersect the 4 raw cubes that I need it to, to
make the processing time halfway bareable. I am used to processing times of
under a second, with this library I'm at 3,5 minutes (just for the preview,
the rendering takes much longer, I think around 20 minutes but I'm not
sure...)
The suggestion by Peter Falke to use offset() won't work, cause I need a 3D
fillet.
I could not get the library also suggested by Peter Falke
http://www.thingiverse.com/thing:142798 to work. The sample does only render
a fillet for the part2() module, not for the part3() as shown in the
screenshots on thingiverse.com - I am using OpenSCAD 2015.03-1 and when it
runs your code it tells me: "DEPRECATED: child() will be removed in future
releases. Use children() instead. " - My tries to get fillets for self
designed parts all failed, though I tried only for 5 minutes or so. Maybe
you can give some explanations how to use your library. (I don't really
understand how exactly he deciceds where the fillet is needed when you only
call it with one part without the other one it should be intersecting?)
I'm now gonna take a look at the sweep function, but I guess I first need to
find out about how to make my OpenSCAD installation find dependencies like
<scad-utils/linalg.scad> and those from MCAD.
View this message in context: http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495p13508.html
hey there guys! Thank you for all your answers! At the moment I've copied the fillet function suggested by Chow Loong Jin from https://github.com/clothbot/ClothBotCreations/blob/master/utilities/fillet.scad (find my current development stage as attachment: ) playground_v7.scad <http://forum.openscad.org/file/n13508/playground_v7.scad> I adapted my code to just intersect the 4 raw cubes that I need it to, to make the processing time halfway bareable. I am used to processing times of under a second, with this library I'm at 3,5 minutes (just for the preview, the rendering takes much longer, I think around 20 minutes but I'm not sure...) The suggestion by Peter Falke to use offset() won't work, cause I need a 3D fillet. I could not get the library also suggested by Peter Falke http://www.thingiverse.com/thing:142798 to work. The sample does only render a fillet for the part2() module, not for the part3() as shown in the screenshots on thingiverse.com - I am using OpenSCAD 2015.03-1 and when it runs your code it tells me: "DEPRECATED: child() will be removed in future releases. Use children() instead. " - My tries to get fillets for self designed parts all failed, though I tried only for 5 minutes or so. Maybe you can give some explanations how to use your library. (I don't really understand how exactly he deciceds where the fillet is needed when you only call it with one part without the other one it should be intersecting?) I'm now gonna take a look at the sweep function, but I guess I first need to find out about how to make my OpenSCAD installation find dependencies like <scad-utils/linalg.scad> and those from MCAD. -- View this message in context: http://forum.openscad.org/are-there-easier-ways-to-get-round-edges-tp13495p13508.html Sent from the OpenSCAD mailing list archive at Nabble.com.
