Thu, Feb 20, 2020 2:28 PM
Honestly, I'm a little surprised that polyhedron doesn't just handle it.
It's not a super challenging thing to have the computer fix as long as the
surface is simply connected and orientable.
It is not a simple task to find whether a consistent winding is reversed or
not. The only way I have found was to compute the polyhedron volume by:
function polyhedron_volume(v,f) =
// based on
https://iconline.ipleiria.pt/bitstream/10400.8/1433/1/artigo-7.pdf
let( crx = [for(fi=f, j=[1:1:len(fi)-2])
let( v0=v[fi[0]],
v1=v[fi[j]],
v2=v[fi[(j+1)%len(fi)]] )
(cross(v1-v0, v2-v0)*((v0+v1+v2).x)).x ] )
-sum(crx)/6;
where sum() computes the sum of the vectors in a list. If
polyhedron_volume() is negative, the winding is reversed. It works provided
the winding is consistent.
// based on
let( v0=v[fi[0]],
v1=v[fi[j]],
-sum(crx)/6;
Thu, Feb 20, 2020 4:04 PM
It seems that a consistent wrong orientation is being handled. At least if
you do a Boolean operation on a purple object and a regular one or on two
purple objects you don't get a CGAL error.
The only miracle is indeed that:
scale([1,1,-1])
cube(100);
like other regular (cylinder() or xxx_extrude()) objects aren't display
purple by F12. I guess that F12 just ignores them.
scale([1,1,-1])
cube(100);
>> the
Thu, Feb 20, 2020 4:42 PM
On 2/20/2020 8:04 AM, Parkinbot wrote:
It seems that a consistent wrong orientation is being handled. At least if you do a Boolean operation on a purple object and a regular one or on two purple objects you don't get a CGAL error.
scale([1,1,-1])
cube(100);
I built a cube with polyhedron() and mirrors and negative scales don't
turn it purple. When I flip one of the faces, it's consistently purple
across the various reflections.
It seems like it would be easy enough to fix a polyhedron after an
arbitrary scale(); you'd just reverse the winding order of all of the
faces if there were an odd number of negative scales.
I expect that you could derive the same information from a
transformation matrix, but right now I'm not up to the math to do it.
I've reverted my change to the manual, restoring the "same direction" /
"prefers clockwise" version.
Did we ever get an authoritative resolution on the negative scale question?
> scale([1,1,-1])
> cube(100);
Thu, Feb 20, 2020 5:13 PM
I expect that you could derive the same information from a transformation
A 4x4 transformation matrix includes some sort of mirroring if its
determinant is less than 0. If the determinant is zero, the
transformation is a projection on a lower dimension space and may or may
not include a mirroring. It seems that multmatrix doesn't computes the
matrix determinant or, at least, ignores if it is zero and does a
projection on a lower dimension space but considers it a 3D object!
multmatrix( [ [1,0,0,0], [1,0,0,0],[0,0,-1,0]]) cube(10);
square();
square();
Thu, Feb 20, 2020 6:03 PM
An exploit of the sign of the determinant of the multmatrix would be an
explanation.
question?
the ultimate authority is always the compiler ;-)
another place to check is the source code ...
explanation.
> question?
Thu, Feb 20, 2020 9:21 PM
question?
Not so much for "sometimes produces bad results" problems. Better to
have somebody (or some documentation) that says "X is expected to work
and Y is expected to be unreliable".
Yeah, maybe, if you speak C++ and you understand how the 3D guts all
interact.
But, looking at it with my very marginal C++ knowledge, it sure looks
like all mirror() does is to set up a transformation matrix.
https://github.com/openscad/openscad/blob/master/src/transform.cc#L171
... which suggests that negative scale and the multmatrix equivalents
would be fine.
>> question?
interact.
would be fine.
Thu, Feb 20, 2020 10:51 PM
Since all affine operations are converted into multmatrix before being
interpreted by the CSG subsystem there can't be much difference if
mirror([0,0,1]) and scale([1,1,-1]) are mapped to the same expression.
Further
https://github.com/openscad/openscad/blob/master/src/polyset.cc##L160
shows that the determinant is used to check inside-outs as proposed by
Ronaldo.
Further
Ronaldo.
Fri, Feb 21, 2020 5:43 AM
Further
Ronaldo.
Everybody seems to agree that negative scales are OK, so I removed that
note from the manual.
> Further
> Ronaldo.
TLC123
Wed, Nov 18, 2020 5:38 PM
check out the latest pull request on this upcoming feature
Implement offset_extrude
https://github.com/openscad/openscad/pull/2079
