A bit of code on thingiverse
"Created by Kevin Gravier
https://www.thingiverse.com/mrkmg/about
My take on a top and bottom fillet for a 3d shape.*
There was a slight error, that may or may not have been corrected.
No need for BOSL2, just basic scad code.
On 23/05/2023 02:43, Revar Desmera wrote:
BOSL2 can do this using rounded_prism():
include <BOSL2/rounding.scad>
rounded_prism(
rect([11,5]),
rect([12,6]),
height=1,
joint_top=0,
joint_bot=0.5,
joint_sides=0.25);
-Revar
On May 21, 2023, at 7:57 AM, Joe Weinpert joe.weinpert@gmail.com wrote:
Have this prismoid:
prismoid( size1 = [11,5], size2 = [12,6], h = 1, rounding = .25 );
How do I add a .5 radius rounded bottom?
Joe Weinpert
skidrowacademy.com http://skidrowacademy.com/
<2023-05-21_10-56-00.jpg>
That fillet library works by making a stairstep "curve" using
projection(). So it's quite slow. And the results look terrible.
There is the result applied to a short text. It took 8s to preview with
four layers. I guess maybe it's OK if you match the fillet steps to your
printing layer height? But if you want a 3mm rounding that means 20
layers. That took 26s to preview for me. So I'd call this a method of
last resort. The rounding methods in BOSL2 are much faster, if you're able
to use them.
It also seems that bottomFillet() doesn't work correctly. I get no fillet
when I try to apply it to the original poster's prismoid example.
rounded_prism(
rect([11,5]),
rect([12,6]),
height=1,
joint_top=0,
joint_bot=0.5,
joint_sides=0.25);
-Revar
Have this prismoid:
Joe Weinpert
skidrowacademy.com
If the stepsize is the size of the layers, then when 3D printing the
result, there is no difference....
That said: lots of disadvantages remain. e.g. resin printers put
objects at an angle and have very high resolutions.
There is no NEED for a mitre saw if you want to cut a 45° angle on a
2x4, but it sure is easier than using a handsaw.
fillet when I try to apply it to the original poster's prismoid example.
Probably that is the error I mentioned b4. If it is, then It was an easy
enough fix.
You can do things with a handsaw, once you learn how to use it, that are
impossible with a mitre saw, and sometimes clamping the piece for the
mitre saw is a pita.
a 2x4, but it sure is easier than using a handsaw.
are impossible with a mitre saw, and sometimes clamping the piece
for the mitre saw is a pita.
Of course, but If you are using the BOSL2 mitre saw, you still have the
handsaw in the form of OpenSCAD.
As I say, there is no NEED, but that's not why I (for one) use it.
