Sun, Jan 2, 2022 4:40 AM
Is there a way, Auto completion or auto suggestion works for custom
functions in openscad.
I have made a library of various function, unfortunately I myself tend to
forget a lot of them and then need to search for the same.
Thanks and Regards
Sanjeev
Thanks and Regards
Sanjeev
MH
Matthieu Hendriks
Mon, Jan 3, 2022 7:01 AM
I'm also very interested if there is such a possibility. No one?
Groet Matthieu
Sanjeev Prabhakar schreef op 2022-01-02 05:40:
to forget a lot of them and then need to search for the same.
Thanks and Regards
Sanjeev
Groet Matthieu
> Hi,
> Thanks and Regards
> Sanjeev
VB
Victor Buciuc
Mon, Jan 3, 2022 8:42 AM
The only option is to use an external editor that supports LSP (the
language server protocol) like Emacs, Vim, Visual Studio, and a
language server like https://github.com/dzhu/openscad-language-server.
I have yet to try this myself, so 'tis purely theoretical.
Regards,
Victor Buciuc
On Mon, Jan 3, 2022 at 9:01 AM Matthieu Hendriks mhendriks@digirent.nl
Groet Matthieu
Thanks and Regards
Sanjeev
Regards,
Victor Buciuc
On Mon, Jan 3, 2022 at 9:01 AM Matthieu Hendriks <mhendriks@digirent.nl>
> Groet Matthieu
> Hi,
> Thanks and Regards
> Sanjeev
Mon, Jan 3, 2022 12:52 PM
Thanks Victor for your reply, although it is quite difficult for me to
understand as to how to apply this.
Regards,
Victor Buciuc
Groet Matthieu
Thanks and Regards
Sanjeev
On Mon, 3 Jan 2022, 14:13 Victor Buciuc, <victor.buciuc@gmail.com> wrote:
> Hi,
> Regards,
> Victor Buciuc
>> Groet Matthieu
>> Hi,
>> Thanks and Regards
>> Sanjeev
VB
Victor Buciuc
Mon, Jan 3, 2022 1:16 PM
Regards,
Victor Buciuc
Groet Matthieu
Thanks and Regards
Sanjeev
Indeed, experience using a text editor for programming would help a lot
here, but it's not impossible to get it working if you don't have it.
The basics steps would be:
1. Choose an editor with LSP support that's known to work with OpenSCAD -
out of
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Using_an_external_Editor_with_OpenSCAD
probably Visual Studio or Sublime could be easier to start with.
2. Install said editor.
3. Follow the installation instructions to install the lsp server:
4. Configure your chosen editor to use said lsp server (check the editor
docs).
5. Profit
Regards,
Victor Buciuc
On Mon, Jan 3, 2022, 2:52 PM Sanjeev Prabhakar <sprabhakar2006@gmail.com>
>> Hi,
>> Regards,
>> Victor Buciuc
>>> Groet Matthieu
>>> Hi,
>>> Thanks and Regards
>>> Sanjeev
Mon, Jan 3, 2022 1:28 PM
Thanks Victor for your detailed explanation.
Will give it a try
Regards,
Victor Buciuc
Groet Matthieu
Thanks and Regards
Sanjeev
Will give it a try
On Mon, 3 Jan 2022, 18:46 Victor Buciuc, <victor.buciuc@gmail.com> wrote:
> Hi,
> out of
> docs).
> 5. Profit
> Regards,
> Victor Buciuc
>>> Hi,
>>> Regards,
>>> Victor Buciuc
>>>> Groet Matthieu
>>>> Hi,
>>>> Thanks and Regards
>>>> Sanjeev
JW
Jim Witte
Tue, Jan 4, 2022 3:47 PM
Where is the autocomplete "list of strings" in the source code?
On Sat, Jan 1, 2022 at 11:41 PM Sanjeev Prabhakar sprabhakar2006@gmail.com
Thanks and Regards
Sanjeev
On Sat, Jan 1, 2022 at 11:41 PM Sanjeev Prabhakar <sprabhakar2006@gmail.com>
> Hi,
> Thanks and Regards
> Sanjeev
Tue, Jan 4, 2022 4:03 PM
It's collected from different places by registering in a class
called Builtins. The autocomplete part retrieving that list is
https://github.com/openscad/openscad/blob/master/src/ScadApi.cc#L52-L62
Some initial work for "Jump to Definition", which needs pretty
much the same data can be found in
https://github.com/openscad/openscad/pull/3283
MH
Matthieu Hendriks
Sun, Jan 9, 2022 3:48 PM
I've succesfully completed the steps, in ubuntu and vim for:
syntax highlighting and autocomplete for custom functions as follows:
Unzip de included zip file in your ~/.vim directory
Create an textfile with your lines for autocomplete. (I've included
an examplem, the first lines are from my own library with custom
functions, but you can fill in anything, followed by all openscad
commands fromn the cheatsheet)
adjust the location after readfile for this autocomplete.txt file in
./vim/ftplugin/openscad.vim
_ let l:data =
readfile("/home/matthieu/openscad_drawings/libraries/autocomplete.txt")_
When you are in vim in your file.scad in insertion mode
type the first letter(s) followed by ctrl-x ctrl-u and make your choice
from the popup list.
Groet Matthieu
Victor Buciuc schreef op 2022-01-03 14:16:
- Choose an editor with LSP support that's known to work with OpenSCAD
- Install said editor.
- Follow the installation instructions to install the lsp server:
- Configure your chosen editor to use said lsp server (check the
editor docs).
- Profit
Regards,
Victor Buciuc
Regards,
Victor Buciuc
Groet Matthieu
Thanks and Regards
Sanjeev
1. Unzip de included zip file in your ~/.vim directory
2. Create an textfile with your lines for autocomplete. (I've included
3. adjust the location after readfile for this autocomplete.txt file in
_ let l:data =
Groet Matthieu
> Hi,
> - out of
> editor docs).
> 5. Profit
> Regards,
> Victor Buciuc
> wrote:
> Hi,
> Regards,
> Victor Buciuc
> Groet Matthieu
> Hi,
> Thanks and Regards
> Sanjeev
Sun, Jan 9, 2022 4:32 PM
Thanks Matthieu for sharing this.
I have no idea how vim works, will learn and give it a try.
On Sun, 9 Jan 2022 at 21:24, Matthieu Hendriks mhendriks@digirent.nl
Create an textfile with your lines for autocomplete. (I've included an
examplem, the first lines are from my own library with custom functions,
but you can fill in anything, followed by all openscad commands fromn the
cheatsheet)
- let l:data =
readfile("/home/matthieu/openscad_drawings/libraries/autocomplete.txt")*
Groet Matthieu
- Choose an editor with LSP support that's known to work with OpenSCAD -
out of
- Configure your chosen editor to use said lsp server (check the editor
docs).
- Profit
Regards,
Victor Buciuc
On Mon, Jan 3, 2022, 2:52 PM Sanjeev Prabhakar sprabhakar2006@gmail.com
Regards,
Victor Buciuc
Groet Matthieu
Thanks and Regards
Sanjeev
On Sun, 9 Jan 2022 at 21:24, Matthieu Hendriks <mhendriks@digirent.nl>
> 2. Create an textfile with your lines for autocomplete. (I've included an
> cheatsheet)
> * let l:data =
> Groet Matthieu
> Hi,
> out of
> docs).
> 5. Profit
> Regards,
> Victor Buciuc
> Hi,
> Regards,
> Victor Buciuc
> Groet Matthieu
> Hi,
> Thanks and Regards
> Sanjeev
