TG
Tony Godshall
Wed, Jan 31, 2018 9:12 PM
The tail recursion optimization is only applied in two very specific
circumstances. It is not implemented in a general way.
Best Regards.
This is unedited.
This message came out of me
via a suboptimal keyboard.
https://en.wikipedia.org/wiki/Tail_call#cite_note-aim-443-1
The rest of the footnotes there are also good.
> Do you have any pointers to documentation about how to implement tail
> recursion or how it's implemented in some language?
> I was searching for that some time ago and there's lots of discussion
> about how to use tail recursion but not so much about how to actually
> implement it.
> ciao,
> Torsten.
Best Regards.
This is unedited.
Wed, Jan 31, 2018 9:19 PM
In order to implement generalized tail recursion optimization, you need to
add a compilation pass that compiles the code into an executable form that
is different from the original parse tree. This executable form is a
sequence of instructions. These are traditionally byte codes, but you could
also use a linked list of instruction objects, or an array of pointers to
instruction objects. This is like compiling into abstract machine code.
The interpreter uses a separate stack data structure to store argument
values and local variables for each function call. A linked list of
dynamically allocated stack frame objects is one possibility.
The interpreter is a state machine with a set of registers. You need at
least: a current instruction pointer IP, a current stack frame pointer FP.
After each instruction is executed, these registers are updated. The IP is
updated to the next instruction to be executed. The FP is updated after a
call or return.
Instructions need operands: some way to access the data that is to be
operated on. In a parse tree interpreter, like what OpenSCAD uses, a tree
node like "+" contains child nodes for the left and right operands of "+".
However, in this style of interpreter, an expression like 'A+B' is compiled
into:
evaluate A, store the result
evaluate B, store the result
fetch the A result, fetch the B result, add them, store the result
There are two basic styles that can be used for fetching and storing data:
One is a "stack machine", where you are pushing and popping intermediate
results on the stack. In this style, 'A+B' compiles into:
- push A on the stack
- push B on the stack
- pop 2 values from the stack, add them, push the result on the stack
Another style is a "register machine", where there is an array of slots
indexed by integers that hold values. Each operation has slot indexes
indicating which slots it should load and store data from. Register
machines are currently more popular. It seems you can generate faster code,
and they aren't any more difficult to implement. Even with a stack machine,
you need a slot array to store local variables.
A?B:C expressions are compiled into an instruction sequence that contains
conditional and unconditional jumps. Like machine code.
In Curv, my stack is a linked list of dynamically allocated stack frame
objects. Each frame contains an array of slots. The number of slots for a
particular function call frame is determined by the compiler. A function
object contains the number of slots needed for a call to that function.
To compile a function call, you first emit instructions to evaluate the
arguments (which are either pushed on the stack, or stored in one or more
slots), then you emit a function-call instruction, which allocates stack
space for the function call, possibly copies the arguments into the new
stack frame, depending on your design, then it sets the FP to point to the
new stack frame and it sets the IP to point to the first instruction of the
function. The old IP needs to be stored somewhere, eg in the return address
field of the new stack frame, so that it can be restored by the return
instruction.
To return from a function call, you execute a return instruction. This
takes the return value and places it somewhere where it can be found by the
function-call instruction that called the current function. You need to
restore the FP to its previous value (pop the current frame off the stack),
and set the IP to the next instruction following the original function
call. Deallocate the current frame, which is no longer needed.
There is also a tail-call instruction. In the general case, you can perform
a tail call to the same function, or to a different function. Suppose that
your stack is a linked list of dynamically allocated frame objects. A
general tail call instruction will create and initialize the new stack
frame, just like regular function call. But then it will set the return
address field of the new stack frame to the same value as the return
address of the current stack frame. Then it destroys the current stack
frame, replacing it with the new stack frame.
Now, your compiler needs a strategy for figuring out when it can safely
replace a regular function-call instruction with a tail-call instruction.
- The body of a function is in tail-position.
- If a let expression is in tail-position, then the body of the let is also
in tail-position.
- If A?B:C is in tail position, then B and C are also in tail-position.
- These rules for marking an expression as "in tail-position" are applied
recursively to the parse tree of a function body.
- If a function call is in tail position, then it can be compiled using a
One caveat. In the style of language interpreter I'm familiar with,
variable and argument references are lexically scoped. In Curv, I compile
variable and argument references into slot indexes, which index into the
slot array of the current stack frame. So the scope of a variable name is
fixed at compile time, before the program is evaluated. This is probably
why the Curv interpreter is so much faster than the OpenSCAD interpreter:
array indexing is faster than hash table lookup. By contrast, OpenSCAD is
dynamically scoped. Variable and argument references are names, and these
names are looked up dynamically during evaluation, which leads to semantics
that are different from lexical scoping. The same variable name node in the
parse tree may have different scopes in different calls to the same
function or module. So you'll have to figure out how to preserve these
dynamic scoping semantics if you implement this style of compiler, and I'm
not sure there are any references to help you, because the dynamic scoping
semantics of OpenSCAD seem utterly unique to me.
call or return.
into:
1. One is a "stack machine", where you are pushing and popping intermediate
* push A on the stack
* push B on the stack
* pop 2 values from the stack, add them, push the result on the stack
2. Another style is a "register machine", where there is an array of slots
instruction.
* The body of a function is in tail-position.
* If a let expression is in tail-position, then the body of the let is also
in tail-position.
* If A?B:C is in tail position, then B and C are also in tail-position.
* These rules for marking an expression as "in tail-position" are applied
* If a function call is in tail position, then it can be compiled using a
> implement it.
> ciao,
> Torsten.
SV
Simeon Veldstra
Thu, Feb 1, 2018 4:37 PM
Emacs lisp is another place where dynamic scope is found. This is
considered a mistake by some, and lexical scoping has been added
to recent versions.
https://www.emacswiki.org/emacs/DynamicBindingVsLexicalBinding
I suppose you could index into a global table of slots to
implement dynamic scope in the compiler you describe, but it
would not be an improvement, except perhaps if your goal was
compatibility. Dynamically scoped programs are considerably
harder to reason about than lexically scoped programs. This is
true both for humans and optimizing compilers.
You can get dynamic scope by accident in an interpreter with a
slight change in how you handle the environment.
The best explanation I've seen for this is published here:
http://cs.brown.edu/courses/cs173/2012/book/From_Substitution_to_Environments.html
In Shriram Krishnamurthi's excellent book
Programming Languages: Application and Interpretation
sim
to recent versions.
sim
Thu, Feb 1, 2018 5:13 PM
Yes, but what I call "dynamic scoping" in OpenSCAD is not the same as
dynamic scoping in Lisp. So I don't think that references to the theory of
Lisp interpreters helps much.
Example 1.
1 a = 0;
2 module m()
3 {
4 function f() = a;
5 x = f();
6 a = 1;
7 y = f();
8 echo(x,y);
9 }
10 m();
Look at line 4. In a lexically scoped language, the variable name 'a' would
statically refer to either the outer definition on line 1, or the inner
definition on line 6. One or the other. But in OpenSCAD the scope of 'a'
seems to be chosen at runtime, and varies dynamically. So the output is:
ECHO: 0,1
Example 2.
1 a = 0;
2 function f() = a;
3 module m()
4 {
5 x = f();
6 a = 1;
7 y = f();
8 echo(x,y);
9 }
10 m();
Here, the output is "ECHO: 0,0". In this case, the variable 'a' is
lexically scoped within the function 'f'. In the previous case, the
variable 'a' was dynamically scoped within the function 'f'.
To me, this looks like a bug. It's as if the intention was to implement
lexical scoping, but the implementation is buggy. Marius has previously
stated that we can't fix this bug in a way that changes the behaviour of
existing programs.
to recent versions.
sim
Example 1.
1 a = 0;
2 module m()
3 {
4 function f() = a;
5 x = f();
6 a = 1;
7 y = f();
8 echo(x,y);
9 }
10 m();
ECHO: 0,1
Example 2.
1 a = 0;
2 function f() = a;
3 module m()
4 {
5 x = f();
6 a = 1;
7 y = f();
8 echo(x,y);
9 }
10 m();
existing programs.
> semantics
> the
> I'm
> scoping
> to recent versions.
> sim
SV
Simeon Veldstra
Fri, Feb 2, 2018 3:21 AM
Oh, I see, "broken scoping" might be a clearer term perhaps.
The docs pretty clearly discourage reassignment at least, and the
language gives us let.
I was happy to discover OpenSCAD. Despite its warts, it suits my
style of thinking. ImplicitCAD and Ruckus were exciting to
find, but appear to be dead projects. I'm enjoying digging into
Curv, keep up the good work!
I'm quite sure you know more about language design than I do. I
find it a fascinating subject and thought my comments would be of
interest to the list.
Example 1.
1 a = 0;
2 module m()
3 {
4 function f() = a;
5 x = f();
6 a = 1;
7 y = f();
8 echo(x,y);
9 }
10 m();
ECHO: 0,1
Example 2.
1 a = 0;
2 function f() = a;
3 module m()
4 {
5 x = f();
6 a = 1;
7 y = f();
8 echo(x,y);
9 }
10 m();
existing programs.
compile
is
probably
interpreter:
is
these
to recent versions.
sim
> Example 1.
> 1 a = 0;
> 2 module m()
> 3 {
> 4 function f() = a;
> 5 x = f();
> 6 a = 1;
> 7 y = f();
> 8 echo(x,y);
> 9 }
> 10 m();
> ECHO: 0,1
> Example 2.
> 1 a = 0;
> 2 function f() = a;
> 3 module m()
> 4 {
> 5 x = f();
> 6 a = 1;
> 7 y = f();
> 8 echo(x,y);
> 9 }
> 10 m();
> existing programs.
>> > compile
>> > the
>> > is
>> > probably
>> > interpreter:
>> > is
>> > these
>> semantics
>> the
>> I'm
>> scoping
>> to recent versions.
>> sim
sim
TLC123
Fri, Feb 2, 2018 4:08 AM
only in the global scope.
a="GAH";
function x(b)=let(c=b) y();
function y()=c;
echo(x(a));
z();
module z(b){c=b; w();}
module w(){echo(c);}
a="GAH";
function y()=c;
echo(x(a));
z();
Fri, Feb 2, 2018 4:19 AM
Thanks, Simeon. You might also want to look at Matt Keeter's libfive. It's
another implicit-function 3D modelling language, based on the Guile dialect
of Scheme. https://github.com/libfive/libfive
Example 1.
1 a = 0;
2 module m()
3 {
4 function f() = a;
5 x = f();
6 a = 1;
7 y = f();
8 echo(x,y);
9 }
10 m();
ECHO: 0,1
Example 2.
1 a = 0;
2 function f() = a;
3 module m()
4 {
5 x = f();
6 a = 1;
7 y = f();
8 echo(x,y);
9 }
10 m();
existing programs.
compile
is
probably
interpreter:
is
these
to recent versions.
sim
> of
> > Example 1.
> > 1 a = 0;
> > 2 module m()
> > 3 {
> > 4 function f() = a;
> > 5 x = f();
> > 6 a = 1;
> > 7 y = f();
> > 8 echo(x,y);
> > 9 }
> > 10 m();
> would
> > ECHO: 0,1
> > Example 2.
> > 1 a = 0;
> > 2 function f() = a;
> > 3 module m()
> > 4 {
> > 5 x = f();
> > 6 a = 1;
> > 7 y = f();
> > 8 echo(x,y);
> > 9 }
> > 10 m();
> > existing programs.
> >> > compile
> >> > the
> >> > is
> >> > probably
> >> > interpreter:
> >> > is
> >> > these
> >> semantics
> in
> >> the
> >> I'm
> >> scoping
> >> to recent versions.
> >> sim
> sim
Fri, Feb 2, 2018 4:24 AM
Torleif: With macOS version 2017.12.23, I get
WARNING: Ignoring unknown variable 'c'.
ECHO: undef
ECHO: undef
ECHO: undef
ECHO: undef
> a="GAH";
> function y()=c;
> echo(x(a));
> z();
TLC123
Fri, Feb 2, 2018 4:43 AM
So do I on win7. This to me indicates that scope is not nesting besides the
global.
I never had any issues with this as i tend to pass parameters with the
function and i don't try to tricky around no reassign paradigm.
Obviously it would be handy to not pass huge lists down a recursion.
But once again let's remind. Openscad script is not programming it is cad
markup. There are no variables. Only constants defined with evaluated
expressions.
global.
expressions.
TLC123
Fri, Feb 2, 2018 4:45 AM
global. I never had any issues with this as i tend to pass parameters with
the function and i don't try to tricky around no reassign paradigm.Obviously
it would be handy to not pass huge lists down a recursion. But once again
let's remind. Openscad script is not programming it is cad markup. There
are no variables. Only constants defined with evaluated expressions.
