Re: [OpenSCAD] MeshLab Unexpected end of file in 2015.02.05
K
kintel
Mon, Feb 23, 2015 3:45 PM
That STL is fine.
It looks like you have a broken MeshLab.
I've tested it in meshlab, admesh as well as reading it back to OpenSCAD
itself. It all works.
View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11729.html
That STL is fine. It looks like you have a broken MeshLab. I've tested it in meshlab, admesh as well as reading it back to OpenSCAD itself. It all works. -Marius -- View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11729.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Feb 23, 2015 9:01 PM
View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11730.html
----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11730.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Feb 23, 2015 9:02 PM
OOps...
kintel wrote
That STL is fine.
No it is not fine according to NetFabb:
http://forum.openscad.org/file/n11731/Circle_NOT.jpg
View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11731.html
OOps... kintel wrote > That STL is fine. No it is not fine according to NetFabb: <http://forum.openscad.org/file/n11731/Circle_NOT.jpg> ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11731.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Feb 23, 2015 9:19 PM
However, using 2015.02.20/64 on W7/64, I used the above 'fails' code and it
exports a clean STL, as far as NetFabb knows.
View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11733.html
MichaelAtOz wrote > No it is not fine according to NetFabb: However, using 2015.02.20/64 on W7/64, I used the above 'fails' code and it exports a clean STL, as far as NetFabb knows. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11733.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Feb 23, 2015 9:45 PM
...and just to complete the circle, the STL above (Circle_-_NOT-Test) give me
the error in Meshlab. My exported stls are OK in Meshlab.
View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11734.html
...and just to complete the circle, the STL above (Circle_-_NOT-Test) give me the error in Meshlab. My exported stls are OK in Meshlab. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11734.html Sent from the OpenSCAD mailing list archive at Nabble.com.
K
kintel
Mon, Feb 23, 2015 10:45 PM
Right, I think I see the problem.
In the STL:
facet normal nan nan nan
MeshLab under Windows might not like that.
I'll look into it.
View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11736.html
Right, I think I see the problem. In the STL: facet normal nan nan nan MeshLab under Windows might not like that. I'll look into it. -- View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11736.html Sent from the OpenSCAD mailing list archive at Nabble.com.
K
kintel
Tue, Feb 24, 2015 12:13 AM
See https://github.com/openscad/openscad/issues/1225
View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11741.html
See https://github.com/openscad/openscad/issues/1225 -- View this message in context: http://forum.openscad.org/MeshLab-Unexpected-end-of-file-in-2015-02-05-tp11666p11741.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Feb 24, 2015 2:29 AM
Should be fixed in master.
Should be fixed in master. -Marius
