julianstirling
Thu, Apr 1, 2021 5:40 PM
Do you know when the OpenSCAD PPA will be updated with OpenSCAD 2021? We
generally do a lot of testing and rendering on our CI which instals from the
PPA. Would be great to think about moving.
Julian
Julian
CL
Chow Loong Jin
Fri, Apr 2, 2021 4:36 AM
Whoops, this slipped my notice entirely, sorry. Working on it now.
Kind regards,
Loong Jin
Kind regards,
Loong Jin
julianstirling
Fri, Apr 2, 2021 6:13 PM
Fantastic!! It is all online and broke my CI pipeline . Careful what you wish
for . I now need to fix my OpenSCAD unit tests.
Fri, Apr 2, 2021 7:34 PM
What fixes are needed? Is there anything that could go on a
checklist of things that should not change across releases?
julianstirling
Fri, Apr 2, 2021 8:39 PM
I need to work out exactly what failed. I'll let you know.
julianstirling
Sun, Apr 25, 2021 11:50 AM
Hi @tp3, we now know what happened in our unit tests so I thought I would
report back.
We have our own OpenSCAD dictionary library inside the OpenFlexure
Micrsocope project, and we test it really carefully because I am worried
about edge cases causing things to fail. We also always have hardwarnings
on, so it must run without warnings.
We use the C-style for loop list comprehensions quite a bit, iterating more
than one value in the last section. An dummy example of some code that
generates the warnings we were getting is:
Here on the last iteration i becomes equal to b, so the loop will exit. But
the next value of j is calculated before the loop exits. This means that
OpenSCAD 2021 throws a the warning:
We have just adjusted our library so we no longer set off this warning. Our
resulting code is actually nicer.
I am not sure if I would class this as unexpected behaviour from OpenSCAD.
Warning about undef in arithmetic is so important, but then it does make it
slightly harder to iterate over all values in an array. But perhaps there is
a nicer way that I am missing.
report back.
Sun, Apr 25, 2021 4:48 PM
That is a well-known design issue of the C-like for. The last iteration is
useless. See: https://github.com/openscad/openscad/issues/3227
The only way I know to handle the issue is to protect the expressions in
the loop avoiding illegal operations in the last iteration.
b= [1,2,3];
a = [for (i=-1, j=0; i<len(b); i=i+1, j= (i==len(b)) ? j : j+b[i]) j];
echo(a);
Em dom., 25 de abr. de 2021 às 12:50, julianstirling <
julian@julianstirling.co.uk> escreveu:
report back.
more than one value in the last section. An dummy example of some code that
b= [1,2,3];
a = [for (i=-1, j=0; i<len(b); i=i+1, j=j+b[i]) j];
echo(a);
But the next value of j is calculated before the loop exits. This means
that OpenSCAD 2021 throws a the warning:
WARNING: undefined operation (number + undefined)
Our resulting code is actually nicer.
is a nicer way that I am missing.
at Nabble.com.
b= [1,2,3];
echo(a);
> report back.
> b= [1,2,3];
> echo(a);
> at Nabble.com.
Sun, Apr 25, 2021 5:09 PM
I did some timing tests with C-like for vs recursion and found that actually
C-like for was slower. I don't know how broadly applicable those test
results were, but it seems like in many cases (most cases?) it's better to
just use recursion.
I do not understand how undef in arithmetic makes it "slightly harder to
iterate over all values in an array". I don't even see any connection
between these things. To iterate over all values in an array you do
for(entry=array) ....
b= [1,2,3];
echo(a);
report back.
that
b= [1,2,3];
OpenSCAD.
it
at Nabble.com.
just use recursion.
> b= [1,2,3];
> echo(a);
> julian@.co
> > escreveu:
>> report back.
>> that
>> b= [1,2,3];
> > echo(a);
>> OpenSCAD.
>> it
>> at Nabble.com.
>> To unsubscribe send an email to
> discuss-leave@.openscad
Sun, Apr 25, 2021 5:15 PM
You need to use the C style loop to be able to accumulate j in the loop. Or
use recursion.
actually C-like for was slower. I don't know how broadly applicable those
test results were, but it seems like in many cases (most cases?) it's
better to just use recursion.
b= [1,2,3];
echo(a);
[hidden email] http:///user/SendEmail.jtp?type=email&email=julian%40.co>
escreveu:
report back.
b= [1,2,3];
echo(a);
at Nabble.com.
use recursion.
> b= [1,2,3];
> echo(a);
> [hidden email] <http:///user/SendEmail.jtp?type=email&email=julian%40.co>>
> escreveu:
> would
> > report back.
> hardwarnings
> that
> > b= [1,2,3];
> > echo(a);
> OpenSCAD.
> it
> there
> > at Nabble.com.
> <http:///user/SendEmail.jtp?type=email&email=discuss-leave%40.openscad>
> at Nabble.com.
Sun, Apr 25, 2021 5:45 PM
Are you saying that has something to do with iterating over all the elements
in an array?
The problem with the orphan iteration in for loops is almost always a
problem that requires some special handling, whether or not undef is silent
in arithmetic. The problem is the stupid behavior of c-style for, not
undefs. And in my experience the code is harder to read for c-style for
than for recursion. I think the quoted example, a vector sum code, is
harder to read than a basic recursive version. And also, vector sum can be
done non-recursively by vector multiplication: b * [for(x=b) 1]
Or
use recursion.
those
is
b= [1,2,3];
j];
[hidden email]
escreveu:
report back.
b= [1,2,3];
at Nabble.com.
at Nabble.com.
in an array?
> Or
> use recursion.
> avm4@
>> those
>> is
>> b= [1,2,3];
>> j];
> > echo(a);
>> [hidden email]
>> escreveu:
>> would
>> > report back.
>> worried
>> hardwarnings
>> that
>> > b= [1,2,3];
> > > echo(a);
>> OpenSCAD.
>> make
>> it
>> there
>> > at Nabble.com.
>> at Nabble.com.
