I use hull for building curved tubes
but when I try to replace “for” with chain_hull it does not work
module tube_in(pd,p,n,w){ //internal tube
pbr = resample_path(pd, n+1, closed=false);
// echo(pbr);
for (i=[1:1:n]){
hull(){
path_copies(p, 1,1,pbr[i-1][0], rotate_children=true,closed=false) rotate(90,[0,1,0])translate([0,0,-0.08])cylinder(d=pbr[i-1][1]+w,h=0.1,$fn=tube_fn);
path_copies(p, 1,1,pbr[i][0], rotate_children=true,closed=false) rotate(90,[0,1,0])translate([0,0,-0.08])cylinder(d=pbr[i][1]+w,h=0.1,$fn=tube_fn);
I use hull for building curved tubes\
// echo(pbr);
for (i=[1:1:n]){
hull(){
