Multiple windows
Sun, Feb 8, 2015 4:27 PM
When I use file open I now get a new window with the previous file still
open in the old window. It seems to be the same OpenScad instance though as
I can't work on one file while the other is rendering, or even close it.
This isn't my expected behaviour on Windows. I expect file open to replace
the current file in the same window. I expect a second window to be a new
instance, not tied to the first one. Is this correct behaviour on a Mac or
more recent versions of Windows, I haven't used anything past 7. Or is is
an OpenScad anomaly?
When I use file open I now get a new window with the previous file still open in the old window. It seems to be the same OpenScad instance though as I can't work on one file while the other is rendering, or even close it. This isn't my expected behaviour on Windows. I expect file open to replace the current file in the same window. I expect a second window to be a new instance, not tied to the first one. Is this correct behaviour on a Mac or more recent versions of Windows, I haven't used anything past 7. Or is is an OpenScad anomaly?
IB
ian bradley
Sun, Feb 8, 2015 4:31 PM
Can't comment on OpenScad, but Office 2013 (Tested Excel) running on
Windows 8 does this:
  1. Create New. Add data, don't save.
  2. File New, as expected opens a new window.
  3. File Open, also opens a new window leaving the original window open
    and with its data in.
Notepad++ does the same and looks more traditional. I think it's just
different behaviour from ye olde apps.
ian bradley ianbradley@operamail.com
OpenSCAD mailing list Discuss@lists.openscad.org
Can't comment on OpenScad, but Office 2013 (Tested Excel) running on Windows 8 does this: 1) Create New. Add data, don't save. 2) File New, as expected opens a new window. 3) File Open, also opens a new window leaving the original window open and with its data in. Notepad++ does the same and looks more traditional. I think it's just different behaviour from ye olde apps. -- ian bradley ianbradley@operamail.com On Sun, 8 Feb 2015, at 04:27 PM, nop head wrote: > When I use file open I now get a new window with the previous file > still open in the old window. It seems to be the same OpenScad > instance though as I can't work on one file while the other is > rendering, or even close it. > > This isn't my expected behaviour on Windows. I expect file open to > replace the current file in the same window. I expect a second window > to be a new instance, not tied to the first one. Is this correct > behaviour on a Mac or more recent versions of Windows, I haven't used > anything past 7. Or is is an OpenScad anomaly? > _________________________________________________ > OpenSCAD mailing list Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
If you have “Advanced->Allow to open multiple documents” enabled, it will be possible to have multiple documents open in the same process.
One one document can render at the same time.
We don’t have a way of managing multiple instances. To do that, disable that feature and do what you used to do.
On Feb 8, 2015, at 11:27 AM, nop head <nop.head@gmail.com> wrote: > When I use file open I now get a new window with the previous file still open in the old window. It seems to be the same OpenScad instance though as I can't work on one file while the other is rendering, or even close it. > If you have “Advanced->Allow to open multiple documents” enabled, it will be possible to have multiple documents open in the same process. One one document can render at the same time. We don’t have a way of managing multiple instances. To do that, disable that feature and do what you used to do. -Marius
