Creating a series of translated primitives from table/matrix
W
wwatts
Wed, Apr 13, 2016 12:37 AM
Hi all,
I'm attempting create some semi-automated functionality in OpenSCAD. What I
would like to do is be able to read in a table of positional, size and type
(sphere etc) data created in another program and generate a single stl file
containing said objects. My suspicion is that I might have to use python to
get this to work, especially if I want to read in a csv or similar file to
get the data, but I figured someone here might have a solution for a more
native way to achieve this. I really appreciate any help you can give.
Thanks,
View this message in context: http://forum.openscad.org/Creating-a-series-of-translated-primitives-from-table-matrix-tp17096.html
Hi all, I'm attempting create some semi-automated functionality in OpenSCAD. What I would like to do is be able to read in a table of positional, size and type (sphere etc) data created in another program and generate a single stl file containing said objects. My suspicion is that I might have to use python to get this to work, especially if I want to read in a csv or similar file to get the data, but I figured someone here might have a solution for a more native way to achieve this. I really appreciate any help you can give. Thanks, -- View this message in context: http://forum.openscad.org/Creating-a-series-of-translated-primitives-from-table-matrix-tp17096.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Apr 13, 2016 12:50 AM
Use an external program (eg written in Python) to convert the parameter
table into an OpenSCAD script called 'parameters.scad' which contains a
sequence of parameter definitions of the form
name = value;
Then use 'include <parameters.scad>' to read the parameters into another
OpenSCAD script which then uses the parameters to generate the geometry.
On 12 April 2016 at 20:37, wwatts will@featherfab.com wrote:
Hi all,
Thanks,
Use an external program (eg written in Python) to convert the parameter table into an OpenSCAD script called 'parameters.scad' which contains a sequence of parameter definitions of the form name = value; Then use 'include <parameters.scad>' to read the parameters into another OpenSCAD script which then uses the parameters to generate the geometry. On 12 April 2016 at 20:37, wwatts <will@featherfab.com> wrote: > Hi all, > > I'm attempting create some semi-automated functionality in OpenSCAD. What I > would like to do is be able to read in a table of positional, size and type > (sphere etc) data created in another program and generate a single stl file > containing said objects. My suspicion is that I might have to use python to > get this to work, especially if I want to read in a csv or similar file to > get the data, but I figured someone here might have a solution for a more > native way to achieve this. I really appreciate any help you can give. > > Thanks, > > > > -- > View this message in context: > http://forum.openscad.org/Creating-a-series-of-translated-primitives-from-table-matrix-tp17096.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
