Trojan warning
mikeonenine@web.de
Tue, Jun 3, 2025 1:25 AM
Hi.
a warning has just appeared for a trojan in the nightly build that I installed a couple of days ago.
Seems a bit wierd that the warning should pop up only now.
Anyone else found any trojans in their nightly build? Or is my antivirus program overreacting?
Hi. a warning has just appeared for a trojan in the nightly build that I installed a couple of days ago. Seems a bit wierd that the warning should pop up only now. Anyone else found any trojans in their nightly build? Or is my antivirus program overreacting?
Tue, Jun 3, 2025 1:32 AM
It appears that some virus scanners are prone to issue false positives for software containing installers. If this is the Windows installer of OpenSCAD, that’s likely the case.
Best recommendation I can think of is to open a bug report against the scanner in question, and hopefully they’ll figure it out.
On Jun 2, 2025, at 21:25, Caddiy via Discuss discuss@lists.openscad.org wrote:
Hi.
It appears that some virus scanners are prone to issue false positives for software containing installers. If this is the Windows installer of OpenSCAD, that’s likely the case. Best recommendation I can think of is to open a bug report against the scanner in question, and hopefully they’ll figure it out. -Marius > On Jun 2, 2025, at 21:25, Caddiy via Discuss <discuss@lists.openscad.org> wrote: > > Hi. > > a warning has just appeared for a trojan in the nightly build that I installed a couple of days ago. > > Seems a bit wierd that the warning should pop up only now. > > Anyone else found any trojans in their nightly build? Or is my antivirus program overreacting? > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
mikeonenine@web.de
Tue, Jun 3, 2025 1:49 AM
Hi.
Thanks. I’ll do that.
Marius Kintel wrote: > It appears that some virus scanners are prone to issue false positives for software containing installers. If this is the Windows installer of OpenSCAD, that’s likely the case. > Best recommendation I can think of is to open a bug report against the scanner in question, and hopefully they’ll figure it out. > > \-Marius > > > On Jun 2, 2025, at 21:25, Caddiy via Discuss [discuss@lists.openscad.org](mailto:discuss@lists.openscad.org) wrote: > > > > Hi. > > > > a warning has just appeared for a trojan in the nightly build that I installed a couple of days ago. > > > > Seems a bit wierd that the warning should pop up only now. > > > > Anyone else found any trojans in their nightly build? Or is my antivirus program overreacting? > > > > --- > > > > OpenSCAD mailing list > > To unsubscribe send an email to discuss-leave@lists.openscad.org Thanks. I’ll do that.
