Hello everyone,
As many of you I sometimes suffer from these difficult CGALL errors. I
managed to deal with them this time and maybe it can help others to fix
their problems.
It's a long time since I added something to this forum. So maybe this is old
news. Sorry for that.
http://forum.openscad.org/file/n21738/cgal_errors.jpg
I designed an object that is in fact some kind of soprano saxophone.
The object the combination of
The first sequence I tried was:
What I found out that the sequence
I changed the sequence
1a) make the body shape
1b) use difference to make the deepened planes
1c) use difference to take out the toneholes
1d) intersect with a cube of 20cm to divide it into 4 printable parts.
add the raised edges by first
2a) making the raised planes
2b) use difference to take out the toneholes
2c) intersect with a cube of 20cm to divide it into 4 printable parts.
add solid posts by
3a) create the posts
3b) use difference to take out the holes from the posts
3c) intersect with a cube of 20cm to divide it into 4 printable parts.
This appears to render without CGAL errors without any change in the shape.
Conclusion: It is better to use the multiple times the same
difference/intersection function on a lower level of the shape than once on
the end of a completed complex construction.
View this message in context: http://forum.openscad.org/CGAL-error-the-sequence-matters-tp21738.html
That is weird because I think all boolean expressions are factored in a
normalization form. And you would have the same normalized expression in
both cases.
Maybe. I will try to reproduce it with an example.
Op 26-6-2017 om 19:03 schreef Ronaldo [via OpenSCAD]:
a normalization form. And you would have the same normalized
expression in both cases.
[hidden email] </user/SendEmail.jtp?type=node&node=21758&i=0>
If you reply to this email, your message will be added to the
discussion below:
http://forum.openscad.org/CGAL-error-the-sequence-matters-tp21738p21758.html
To unsubscribe from CGAL error - the sequence matters, click here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=21738&code=am9oYW5nam9ua2VyQHpvbm5ldC5ubHwyMTczOHwtMTMyMDk2NjY0Mg==.
NAML
View this message in context: http://forum.openscad.org/CGAL-error-the-sequence-matters-tp21738p21759.html
I have built a simple code, based on your two strategies, to test my
assumption.
module A() cube();
module B() cube();
module C() cube();
module D() cube();
module E() cube();
module F() cube();
module G() cube();
module initial()
difference() { A(); B(); }
C();
D();
difference() { E(); F(); }
G();
module modified() {
difference() { A(); B(); D(); }
G();
difference(){ C(); D(); }
G();
G();
initial();
//modified();
The modules A() to G() represent parts of your design (simplifyed here to
be just a cube() ). The last two modules represent the two strategies for
building the whole thing. If we preview this code and see the expression by
Design/Display CSG Products.. we get:
previewing initial():
CSG before normalization:
(((((cube9 - cube11) + cube13) - cube15) + (cube18 - cube20)) * cube22)
CSG after normalization:
(((((cube9 * cube22) - cube11) - cube15) + ((cube13 * cube22) - cube15)) +
((cube18 * cube22) - cube20))
previewing modified() :
(((((cube6 * cube12) - cube8) - cube10) + ((cube16 * cube20) - cube18)) +
((cube24 * cube28) - cube26))
Note that in both cases the normalization leads to the same expression.
Remains to know if CGAL is called with the normalized expression.
CGAL is not normalised.
OpenCSG preview is.
reference
https://github.com/openscad/openscad/pull/1980#issuecomment-296511710
View this message in context: http://forum.openscad.org/CGAL-error-the-sequence-matters-tp21738p21761.html
Well, that answers my question. Let us wait for the Johan's case study.
2017-06-26 17:29 GMT-03:00 MichaelAtOz oz.at.michael@gmail.com:
OpenCSG preview is.
reference
I am a bit confused now. I tried all my earlier versions of wich I thought
had the problem. They all render without problems. . So I cannot reproduce
the problem to show the difference.
So maybe this post must be seen as some kind of false alarm. Maybe better to
remove the whole topic to prevent more confusion?
View this message in context: http://forum.openscad.org/CGAL-error-the-sequence-matters-tp21738p21765.html
I think you can edit the post, 'More' drop down on the right.
So you can add an update there. Maybe good to have it for posterity.
If you really want the thread deleted let me know.
View this message in context: http://forum.openscad.org/CGAL-error-the-sequence-matters-tp21738p21766.html
