I see "Module cache size: 27 modules" when there are 96 modules in my code.
Is 27 the maximum size of the cache, if so why so small? Is it the current
number of modules cached, again why so small?
On Nov 22, 2016, at 07:11, nop head nop.head@gmail.com wrote:
I see "Module cache size: 27 modules" when there are 96 modules in my code. Is 27 the maximum size of the cache, if so why so small? Is it the current number of modules cached, again why so small?
It’s just a debug message: The module cache in an internal cache of already parsed FileModules, i.e. .scad files that are “use”’d in your design.
AFAIK they should all be used by use statements, not all instantiated but a
lot more than 27 instantiated.
design.
On Nov 22, 2016, at 10:39, nop head nop.head@gmail.com wrote:
AFAIK they should all be used by use statements, not all instantiated but a lot more than 27 instantiated.
The module cache only deals with caching parsed FileModules, it has nothing to do with instantiation of named modules in your design. I would guess your design consists of 27 use’d files + the main scad file.
Reading it again I see that these are used files, not OpenSCAD modules,
hence the number is much smaller.
design.
