I'm assuming you are talking about the common issue that for OpenSCAD "up" is
the Z-axis and in many other modeling programs "up" is Y-axis.
If you need to swap these axes, you can apply this matrix operation to your
model:
multmatrix(m=[[1,0,0,0],[0,0,1,0],[0,1,0,0],[0,0,0,1]]) {
// your model code here
You could also define a module like this as a shorthand:
module swapYZ() { multmatrix(m=[[1,0,0,0],[0,0,1,0],[0,1,0,0],[0,0,0,1]])
children(); }
swapYZ() {
cube([1,2,3]); // cube example, put your model here
View this message in context: http://forum.openscad.org/change-global-coordinate-system-tp19487p19498.html
Um, if swapping the Z for the Y axis is indeed your issue, then I'd suggest a
rotate, not a mirror. Otherwise you will find yourself in the mirror
universe where you're model has a beard. 😜
View this message in context: http://forum.openscad.org/change-global-coordinate-system-tp19487p19499.html
Ah, yeah you're right adrian. Sorry for the confusion, I should have
tested that before suggesting it. I had to go find a program that used
Y-up to convince myself, took me a while to remember but Wings3D is one of
those programs(and free), which I tested in.
If you rotate about X axis -90 degrees before exporting, then the model
should display in the desired orientation once imported into the other
program.
So my revised answer is this instead:
rotate([-90]) {
// your code here.
I guess the thing that tripped me up was that OpenSCAD's +Z axis maps to
other program's +Y axis, but OpenSCAD's +Y axis necessarily have to map to
the negative Z axis for it to work in the other coordinate system (both
of which are "right-handed").
suggest a
