I get dozens of warning like this on Mendel90 now:
WARNING: pulley_type was assigned on line 78 of "config.scad" but was
overwritten on line 64 of "dibond_config.scad"
This is deliberate, values are given a default that can be overridden in a
specific machine configuration or not. I thought that it was only supposed
to only warn if you redefined in the same file?
Other observations are that the console should be a lot bigger now that we
have a lot more warnings.
There should be a stop on first error option as well as stop on first
warning as I had so many warnings I could not see an error.
Actually I see that it always stops on the first error. The problem I had
was I had two windows open, so the error occurred in the first one and it
stopped but the second one used the cached module, so doesn't see the error
and just carries on.
in a specific machine configuration or not. I thought that it was only
supposed to only warn if you redefined in the same file?
I would like to see the minimum example that causes this warning so that
we can discuss whether the warning is justified or not.
here is the whole code
I think you are running into that one:
https://github.com/openscad/openscad/blob/707043efe658e9bf41ea102fafad1c093c7fdbfd/src/parser.y#L238
I would like to see an example, where is makes sense to assign a
variable in the currently open main file beeing overwritten by an
include. The assignment in the main file should not have any effect, as
it is always overwritten by the included file.
(except when you start commenting out includes to get different configs)
Note that the reverse (included variable overwritten by the main file)
should not cause a warning.
Maybe it is an issue with use<>;, nested use and include are tricky to
setup and test.
that we have a lot more warnings.
Trace (https://github.com/openscad/openscad/pull/2645) should motivate
people to turn on stopp on first warning
I agree with that, but the Error Messages are a bit more complicated
then the warnings.
I include config.scad in every file of my project. It defines default
values and then includes machine.scad, which is generated by Python and
simply includes any one of several machine specific configurations that
override some of the defaults. In this case dibond_config.scad.
It does normally work as expected. In this case I opened config.scad in
OpenSCAD to look for an error, so in that window it was the main file, so
it generated a wall of warnings.
It is probably quite an unusual use case and I don't normally open
config.scad in OpenSCAD because I use an external editor to modify it, so I
can live with it now that I know the reason why.
The console is limited to 500 lines, which is totally arbitrary. It could
easily be 100 times bigger and not cause any performance issues.
I would like to see an example, where is makes sense to assign a variable
in the currently open main file beeing overwritten by an include. The
assignment in the main file should not have any effect, as it is always
setup and test.
I agree with that, but the Error Messages are a bit more complicated then
the warnings.
