Rendering cancelled. UI-WARNING: No top level geometry to render
JM
Jaacov Molcho
Thu, Apr 9, 2020 4:34 PM
I have a relatively simple model. Preview (F5) is done in less than a second.
Rendering (F6) does not finish overnight.
It fails.
Last time after many attempts and changes in the preferences It stoped with
the error:
Rendering canceled.
UI-WARNING: No top-level geometry to render.
This is my code:
//Ellipse Pendant.
module cir(){
r=0.8;
$fn=32;
translate([-3.5,3.5,0])
rotate_extrude(convexity = 10)
translate([2, 0, 0])
circle(r);
translate([3.5,3.5,0])
circle(r);
translate([0,-1.8,0])
translate([2.4, 0, 0])
circle(r);
module glob(){
r=0.8;
$fn=32;
for (i=[0:360/6:360]){
rotate([i,0,0])
translate([10, 0, 0])
circle(r);}
for (i=[0:360/8:360]){
rotate([0,0,i])
rotate([90,0,0])
circle(r);}
scale([1,1.5,1]){//
translate([0,0,-1])
glob();
translate([0,0,-25])
cube(50,true);}
r=1;
$fn=32;
translate([18, 0, 0])
circle(r);
for (i=[0:360/10:360]){
rotate([0,0,i])
translate([0,17,0])
cir();}
translate([11.5, 0, 0])
circle(r);
module mitle(){
r=0.5;
$fn=32;
rotate([-40,0,0]){
color("brown")
translate([3, 0, 0])
circle(r);
translate([0,10.6,0])
cube(20,true);}
translate([0,100,0])
scale([1,2,1])
color("brown")
translate([50, 0, 0])
circle(.25);
cylinder(20,3,3,true);}
//translate([0,33,-1])
//mitle(); http://forum.openscad.org/file/t533/Ellipse_Pendant.png
I have a relatively simple model. Preview (F5) is done in less than a second. Rendering (F6) does not finish overnight. It fails. Last time after many attempts and changes in the preferences It stoped with the error: Rendering canceled. UI-WARNING: No top-level geometry to render. This is my code: //Ellipse Pendant. //================ module cir(){ r=0.8; $fn=32; translate([-3.5,3.5,0]) rotate_extrude(convexity = 10) translate([2, 0, 0]) circle(r); translate([3.5,3.5,0]) rotate_extrude(convexity = 10) translate([2, 0, 0]) circle(r); translate([0,-1.8,0]) rotate_extrude(convexity = 10) translate([2.4, 0, 0]) circle(r); } module glob(){ r=0.8; $fn=32; for (i=[0:360/6:360]){ rotate([i,0,0]) rotate_extrude(convexity = 10) translate([10, 0, 0]) circle(r);} for (i=[0:360/8:360]){ rotate([0,0,i]) rotate([90,0,0]) rotate_extrude(convexity = 10) translate([10, 0, 0]) circle(r);} } scale([1,1.5,1]){//=================================== translate([0,0,-1]) difference(){ glob(); translate([0,0,-25]) cube(50,true);} { r=1; $fn=32; rotate_extrude(convexity = 10) translate([18, 0, 0]) circle(r); for (i=[0:360/10:360]){ rotate([0,0,i]) translate([0,17,0]) cir();} rotate_extrude(convexity = 10) translate([11.5, 0, 0]) circle(r); } }//============================================= module mitle(){ r=0.5; $fn=32; rotate([-40,0,0]){ difference(){ color("brown") rotate_extrude(convexity = 10) translate([3, 0, 0]) circle(r); translate([0,10.6,0]) cube(20,true);} } difference(){ translate([0,100,0]) scale([1,2,1]) color("brown") rotate_extrude(convexity = 10) translate([50, 0, 0]) circle(.25); cylinder(20,3,3,true);} } //translate([0,33,-1]) //mitle(); <http://forum.openscad.org/file/t533/Ellipse_Pendant.png> -- Sent from: http://forum.openscad.org/
Thu, Apr 9, 2020 5:25 PM
Worked fine for me in about 11 minutes:
OpenSCAD 2019.05
Saved backup file:
C:/Users/ChrisP/Documents/OpenSCAD/backups/unsaved-backup-dxVfaOqJ.scad
Geometries in cache: 32
Geometry cache size in bytes: 3400584
CGAL Polyhedrons in cache: 19
CGAL cache size in bytes: 332219616
Total rendering time: 0 hours, 10 minutes, 50 seconds
Simple: yes
Vertices: 39792
Halfedges: 214600
Edges: 107300
Halffacets: 134766
Facets: 67383
Volumes: 2
Rendering finished.
On Thu, 9 Apr 2020 at 17:35, Jaacov Molcho via Discuss <
second.
It fails.
the error:
Rendering canceled.
This is my code:
//Ellipse Pendant.
module cir(){
r=0.8;
$fn=32;
circle(r);
circle(r);
circle(r);
module glob(){
r=0.8;
$fn=32;
rotate([i,0,0])
circle(r);}
rotate([0,0,i])
rotate([90,0,0])
circle(r);}
scale([1,1.5,1]){//
translate([0,0,-1])
glob();
cube(50,true);}
r=1;
$fn=32;
circle(r);
rotate([0,0,i])
translate([0,17,0])
cir();}
circle(r);
module mitle(){
r=0.5;
$fn=32;
rotate([-40,0,0]){
color("brown")
circle(r);
cube(20,true);}
scale([1,2,1])
color("brown")
circle(.25);
Worked fine for me in about 11 minutes: OpenSCAD 2019.05 Parsing design (AST generation)... Saved backup file: C:/Users/ChrisP/Documents/OpenSCAD/backups/unsaved-backup-dxVfaOqJ.scad Compiling design (CSG Tree generation)... Rendering Polygon Mesh using CGAL... Geometries in cache: 32 Geometry cache size in bytes: 3400584 CGAL Polyhedrons in cache: 19 CGAL cache size in bytes: 332219616 Total rendering time: 0 hours, 10 minutes, 50 seconds Top level object is a 3D object: Simple: yes Vertices: 39792 Halfedges: 214600 Edges: 107300 Halffacets: 134766 Facets: 67383 Volumes: 2 Rendering finished. On Thu, 9 Apr 2020 at 17:35, Jaacov Molcho via Discuss < discuss@lists.openscad.org> wrote: > I have a relatively simple model. Preview (F5) is done in less than a > second. > Rendering (F6) does not finish overnight. > It fails. > Last time after many attempts and changes in the preferences It stoped with > the error: > Rendering canceled. > UI-WARNING: No top-level geometry to render. > This is my code: > //Ellipse Pendant. > //================ > > > module cir(){ > r=0.8; > $fn=32; > translate([-3.5,3.5,0]) > rotate_extrude(convexity = 10) > translate([2, 0, 0]) > circle(r); > > translate([3.5,3.5,0]) > rotate_extrude(convexity = 10) > translate([2, 0, 0]) > circle(r); > > translate([0,-1.8,0]) > rotate_extrude(convexity = 10) > translate([2.4, 0, 0]) > circle(r); > } > module glob(){ > r=0.8; > $fn=32; > for (i=[0:360/6:360]){ > rotate([i,0,0]) > rotate_extrude(convexity = 10) > translate([10, 0, 0]) > circle(r);} > > for (i=[0:360/8:360]){ > rotate([0,0,i]) > rotate([90,0,0]) > rotate_extrude(convexity = 10) > translate([10, 0, 0]) > circle(r);} > } > > scale([1,1.5,1]){//=================================== > translate([0,0,-1]) > difference(){ > glob(); > translate([0,0,-25]) > cube(50,true);} > > > > { > r=1; > $fn=32; > rotate_extrude(convexity = 10) > translate([18, 0, 0]) > circle(r); > > for (i=[0:360/10:360]){ > rotate([0,0,i]) > translate([0,17,0]) > cir();} > > rotate_extrude(convexity = 10) > translate([11.5, 0, 0]) > circle(r); > } > }//============================================= > > module mitle(){ > r=0.5; > $fn=32; > rotate([-40,0,0]){ > difference(){ > color("brown") > rotate_extrude(convexity = 10) > translate([3, 0, 0]) > > circle(r); > translate([0,10.6,0]) > cube(20,true);} > } > > difference(){ > translate([0,100,0]) > scale([1,2,1]) > color("brown") > rotate_extrude(convexity = 10) > translate([50, 0, 0]) > circle(.25); > cylinder(20,3,3,true);} > } > //translate([0,33,-1]) > //mitle(); <http://forum.openscad.org/file/t533/Ellipse_Pendant.png> > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
PR
Peter Ragosch
Thu, Apr 9, 2020 5:53 PM
Am Thu, 9 Apr 2020 09:34:17 -0700 (MST)
schrieb Jaacov Molcho via Discuss discuss@lists.openscad.org:
It fails.
Rendering canceled.
Successfully run
OpenSCAD Version: 2020.04.05.nightly (git 9ee2faa)
System information: Linux 4.12.14-lp151.28.44-default #1 SMP Fri Mar 20 18:20:20 UTC 2020 (dbf1aea) x86_64 openSUSE Leap 15.1 4 CPUs 31.31 GB RAM
User Agent: OpenSCAD/2020.04.05.nightly (git 9ee2faa) (Linux x86_64; openSUSE Leap 15.1)
Compiler: GCC "7.4.0" 64bit
MinGW build: No
Debug build: No
Boost version: 1_66
Eigen version: 3.3.4
CGAL version, kernels: 4.12.2, Cartesian, Extended_cartesian, Epeck
OpenCSG version: OpenCSG 1.3.2
Qt version: 5.9.7
QScintilla version: 2.10.4
InputDrivers:
GLib version: 2.54.3
lodepng version: 20180910
libzip version:
fontconfig version: 2.12.6
freetype version: 2.9.0
harfbuzz version: 1.7.5
lib3mf version: (not enabled)
Features: input-driver-dbus, function-literals, lazy-union
Application Path: /usr/bin
Console output:
Geometries in cache: 202
Geometry cache size in bytes: 8444104
Total rendering time: 0 hours, 4 minutes, 47 seconds
Simple:        yes
Vertices:    39792
Halfedges:  214600
Edges:      107300
Halffacets: 134766
Facets:      67383
Volumes:        2
Rendering finished.
Mit freundlichen Grüßen
Best Regards
Peter Ragosch
Am Thu, 9 Apr 2020 09:34:17 -0700 (MST) schrieb Jaacov Molcho via Discuss <discuss@lists.openscad.org>: > I have a relatively simple model. Preview (F5) is done in less than a > second. Rendering (F6) does not finish overnight. > It fails. > Last time after many attempts and changes in the preferences It > stoped with the error: > Rendering canceled. > UI-WARNING: No top-level geometry to render. Successfully run OpenSCAD Version: 2020.04.05.nightly (git 9ee2faa) System information: Linux 4.12.14-lp151.28.44-default #1 SMP Fri Mar 20 18:20:20 UTC 2020 (dbf1aea) x86_64 openSUSE Leap 15.1 4 CPUs 31.31 GB RAM User Agent: OpenSCAD/2020.04.05.nightly (git 9ee2faa) (Linux x86_64; openSUSE Leap 15.1) Compiler: GCC "7.4.0" 64bit MinGW build: No Debug build: No Boost version: 1_66 Eigen version: 3.3.4 CGAL version, kernels: 4.12.2, Cartesian, Extended_cartesian, Epeck OpenCSG version: OpenCSG 1.3.2 Qt version: 5.9.7 QScintilla version: 2.10.4 InputDrivers: GLib version: 2.54.3 lodepng version: 20180910 libzip version: fontconfig version: 2.12.6 freetype version: 2.9.0 harfbuzz version: 1.7.5 lib3mf version: (not enabled) Features: input-driver-dbus, function-literals, lazy-union Application Path: /usr/bin .... Console output: Parsing design (AST generation)... Compiling design (CSG Tree generation)... Rendering Polygon Mesh using CGAL... Geometries in cache: 202 Geometry cache size in bytes: 8444104 CGAL Polyhedrons in cache: 19 CGAL cache size in bytes: 332219616 Total rendering time: 0 hours, 4 minutes, 47 seconds Top level object is a 3D object: Simple: yes Vertices: 39792 Halfedges: 214600 Edges: 107300 Halffacets: 134766 Facets: 67383 Volumes: 2 Rendering finished. -- Mit freundlichen Grüßen Best Regards Peter Ragosch
Fri, Apr 10, 2020 11:09 PM
The only way to get *Rendering canceled. *
http://forum.openscad.org/file/t359/Rendering_cancelled.png
The only way to get *Rendering canceled. * <http://forum.openscad.org/file/t359/Rendering_cancelled.png> ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. -- Sent from: http://forum.openscad.org/
