It displays the initial popup but when I select either a previously
edited .scad file or select "new" it displays a blank screen of uniform
pale grey with no toolbar or other screen parts.
The last release doesn't have the problem.
Running under WIN 7 64bit
Regards,
Dave
Confirmed. I get a transparent window-frame with title-bar.
If you type Alt-f the file menu appears, then Q to quit, it then crashes.
Sent: Sat, 13 Mar 2021 23:58
Subject: [OpenSCAD] Problem with latest nightly build.
Regards,
Dave
Softfoot,
I tried another W7/64 system which works OK. Works for Nophead too.
What version was the snapshot?
Can you try clicking up-top-left where the menus would be.
If you get menus please attach content of help/library-info.
Is your system a-typical in someway?
OK a few minutes ago I downloaded the latest "Development Snapshots" BOTH 64 and 32 bit windows variants :-
OpenSCAD-2021.03.12.ci7607-x86-32-Installer
OpenSCAD-2021.03.12.ci7606-x86-64-Installer
They both behave as before on my laptop - a blank frame - no buttons or window structure.
When I click where the buttons should be I get a drop-down menu but most of the entries do nothing (things like "show library folder" work - but that is a straight forward windows function).
WIN7 64bit (up to date), on a Levono T410 with 8GB of memory.
The last 64 bit release works fine.
Dave
pale grey with no toolbar or other screen parts.Softfoot,
If you get menus please attach content of help/library-info.Is your system a-typical in someway? OpenSCAD Admin - email* me if you need anything, or if I've done something stupid...
* on the Forum, click on my MichaelAtOz label, there is a link to email me.Unless specifically shown otherwise above, my contribution is in the Public Domain;
to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work.
<pre class="moz-quote-pre" wrap="">_______________________________________________ OpenSCAD mailing list To unsubscribe send an email to <a class="moz-txt-link-abbreviated" href="mailto:discuss-leave@lists.openscad.org">discuss-leave@lists.openscad.org</a>
Thanks.
I'm drilling down & getting warmer. Github issue
https://github.com/openscad/openscad/issues/3719 .
Could you try command-line 'openscad --info' and post the results.
Don't bother downloading others until I report back.
