(newbie 1st post) Cutout with rounded edges
W
wellidontknow@gmx.net
Sun, Oct 13, 2019 2:50 PM
Hey there,
new to OpenSCAD (and CNC in general).
I have found a couple tutorials of how to make a cube with rounded edges, but that's not what I'm after ;)
I have a wooden plate for an enclosure, and it needs a cutout in the shape of the cross section of a typical pill / capsule, i.e. a long-ish rectangle with a half circle at each end.
The out-side of that plate should have rounded-off edges (i.e. that side will be pointing UP on the CNC table)
How would I do that with OpenSCAD primitives?
A box for the plate, and then subtract a box and 2 cylinders from it, sometihg like that? (ok, that would not have rounded edges)
And how would I, in a clever way automatically calculating this independently from some detail changes, (re-)position the whole thing such that the center of that cutout is at the origin (0,0) of the model?
(I have no clue, but my gut feeling tells, me, homing in on that (center marking) should be easier, after getting the orientation of a clamped-down wood plate right enough, than going from corners with some edge sensing tool, that I don't have yet anyway)
OT side note: any recommendations for free or affordable CAM software for this kind of stuff, and tools helping to calculate feed parameters and such?
I have zero clue about all of this.
Sun, Oct 13, 2019 3:03 PM
To make the outside I would take the hull of four rounded cylinders placed
at the corners. You can find those in my library:
https://github.com/nophead/NopSCADlib#Rounded_cylinder
To make the slot I would subtract the hull of two cylinders, or use my slot
module https://github.com/nophead/NopSCADlib#Polyholes
If I wanted the slot at the origin I would simply model it at 0,0 and place
the corners where they should be relative to that.
On Sun, 13 Oct 2019 at 15:51, wellidontknow@gmx.net wrote:
Hey there,
To make the outside I would take the hull of four rounded cylinders placed at the corners. You can find those in my library: https://github.com/nophead/NopSCADlib#Rounded_cylinder To make the slot I would subtract the hull of two cylinders, or use my slot module https://github.com/nophead/NopSCADlib#Polyholes If I wanted the slot at the origin I would simply model it at 0,0 and place the corners where they should be relative to that. On Sun, 13 Oct 2019 at 15:51, <wellidontknow@gmx.net> wrote: > Hey there, > > new to OpenSCAD (and CNC in general). > > I have found a couple tutorials of how to make a cube with rounded edges, > but that's not what I'm after ;) > I have a wooden plate for an enclosure, and it needs a cutout in the shape > of the cross section of a typical pill / capsule, i.e. a long-ish rectangle > with a half circle at each end. > The out-side of that plate should have rounded-off edges (i.e. that side > will be pointing UP on the CNC table) > > How would I do that with OpenSCAD primitives? > A box for the plate, and then subtract a box and 2 cylinders from it, > sometihg like that? (ok, that would not have rounded edges) > > And how would I, in a clever way automatically calculating this > independently from some detail changes, (re-)position the whole thing such > that the center of that cutout is at the origin (0,0) of the model? > (I have no clue, but my gut feeling tells, me, homing in on that (center > marking) should be easier, after getting the orientation of a clamped-down > wood plate right enough, than going from corners with some edge sensing > tool, that I don't have yet anyway) > > OT side note: any recommendations for free or affordable CAM software for > this kind of stuff, and tools helping to calculate feed parameters and such? > I have zero clue about all of this. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sun, Oct 13, 2019 3:29 PM
Polyholes should always print the correct size if square holes print the
right size on your printer. If not the printers needs calibrating or the
slicer settings are wrong.
The way it works is the vertex count is reduced enough to ensure the
corners don't cut into the circle even when the plastic cuts the corner, so
the hole diameter is set by the flat sides of the polygon. They are outset
correctly to be on the circle, so if your printer prints straight lines in
the right place the hole should be accurate.
On Sun, 13 Oct 2019 at 16:23, adrianv avm4@cornell.edu wrote:
slot
Has this evolved since the original hydroraptor post?  I tried it a month
ago on my Prusa Mk3 and the polyholes weren't even close to the right
size.
Of course, at this point I don't remember exactly what was wrong, and I
have
three unmarked test prints with different size holes.
Polyholes should always print the correct size if square holes print the right size on your printer. If not the printers needs calibrating or the slicer settings are wrong. The way it works is the vertex count is reduced enough to ensure the corners don't cut into the circle even when the plastic cuts the corner, so the hole diameter is set by the flat sides of the polygon. They are outset correctly to be on the circle, so if your printer prints straight lines in the right place the hole should be accurate. On Sun, 13 Oct 2019 at 16:23, adrianv <avm4@cornell.edu> wrote: > nophead wrote > > To make the slot I would subtract the hull of two cylinders, or use my > > slot > > module https://github.com/nophead/NopSCADlib#Polyholes > > Has this evolved since the original hydroraptor post? I tried it a month > ago on my Prusa Mk3 and the polyholes weren't even close to the right > size. > Of course, at this point I don't remember exactly what was wrong, and I > have > three unmarked test prints with different size holes. > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sun, Oct 13, 2019 3:31 PM
slot
ago on my Prusa Mk3 and the polyholes weren't even close to the right size.
Of course, at this point I don't remember exactly what was wrong, and I have
nophead wrote > To make the slot I would subtract the hull of two cylinders, or use my > slot > module https://github.com/nophead/NopSCADlib#Polyholes Has this evolved since the original hydroraptor post? I tried it a month ago on my Prusa Mk3 and the polyholes weren't even close to the right size. Of course, at this point I don't remember exactly what was wrong, and I have three unmarked test prints with different size holes. -- Sent from: http://forum.openscad.org/
Sun, Oct 13, 2019 11:09 PM
I scrutinized my code and realized it doesn't match the code on hydraraptor.
It seems the code I actually tested came from here:
https://gilesbathgate.com/2016/02/07/polyholes-revisited/  and it looks like
I got the same result you did when testing this code: all holes too big.
so
avm4@
> wrote:
slot
size.
have
Discuss@.openscad
Discuss@.openscad
I scrutinized my code and realized it doesn't match the code on hydraraptor. It seems the code I actually tested came from here: https://gilesbathgate.com/2016/02/07/polyholes-revisited/ and it looks like I got the same result you did when testing this code: all holes too big. nophead wrote > Polyholes should always print the correct size if square holes print the > right size on your printer. If not the printers needs calibrating or the > slicer settings are wrong. > > The way it works is the vertex count is reduced enough to ensure the > corners don't cut into the circle even when the plastic cuts the corner, > so > the hole diameter is set by the flat sides of the polygon. They are outset > correctly to be on the circle, so if your printer prints straight lines in > the right place the hole should be accurate. > > On Sun, 13 Oct 2019 at 16:23, adrianv &lt; > avm4@ > &gt; wrote: > >> nophead wrote >> > To make the slot I would subtract the hull of two cylinders, or use my >> > slot >> > module https://github.com/nophead/NopSCADlib#Polyholes >> >> Has this evolved since the original hydroraptor post? I tried it a month >> ago on my Prusa Mk3 and the polyholes weren't even close to the right >> size. >> Of course, at this point I don't remember exactly what was wrong, and I >> have >> three unmarked test prints with different size holes. >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> > Discuss@.openscad >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@.openscad > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- Sent from: http://forum.openscad.org/
Sun, Oct 13, 2019 11:15 PM
Yes that was an interesting conversation with Giles.
Have you tried the formula here:
https://github.com/nophead/NopSCADlib/blob/master/utils/core/polyholes.scad#L30
When printed with single outlines, or with the multiple outlines doing the
outer perimeters first, that always gives the correct size for me.
hydraraptor.
like
so
outset
in
avm4@
> wrote:
slot
month
size.
have
Discuss@.openscad
Discuss@.openscad
Yes that was an interesting conversation with Giles. Have you tried the formula here: https://github.com/nophead/NopSCADlib/blob/master/utils/core/polyholes.scad#L30 ? When printed with single outlines, or with the multiple outlines doing the outer perimeters first, that always gives the correct size for me. On Mon, 14 Oct 2019 at 00:01, adrianv <avm4@cornell.edu> wrote: > I scrutinized my code and realized it doesn't match the code on > hydraraptor. > It seems the code I actually tested came from here: > https://gilesbathgate.com/2016/02/07/polyholes-revisited/ and it looks > like > I got the same result you did when testing this code: all holes too big. > > > > nophead wrote > > Polyholes should always print the correct size if square holes print the > > right size on your printer. If not the printers needs calibrating or the > > slicer settings are wrong. > > > > The way it works is the vertex count is reduced enough to ensure the > > corners don't cut into the circle even when the plastic cuts the corner, > > so > > the hole diameter is set by the flat sides of the polygon. They are > outset > > correctly to be on the circle, so if your printer prints straight lines > in > > the right place the hole should be accurate. > > > > On Sun, 13 Oct 2019 at 16:23, adrianv &lt; > > > avm4@ > > > &gt; wrote: > > > >> nophead wrote > >> > To make the slot I would subtract the hull of two cylinders, or use my > >> > slot > >> > module https://github.com/nophead/NopSCADlib#Polyholes > >> > >> Has this evolved since the original hydroraptor post? I tried it a > month > >> ago on my Prusa Mk3 and the polyholes weren't even close to the right > >> size. > >> Of course, at this point I don't remember exactly what was wrong, and I > >> have > >> three unmarked test prints with different size holes. > >> > >> > >> > >> -- > >> Sent from: http://forum.openscad.org/ > >> > >> _______________________________________________ > >> OpenSCAD mailing list > >> > > > Discuss@.openscad > > >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >> > > > > _______________________________________________ > > OpenSCAD mailing list > > > Discuss@.openscad > > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
